Boost solenoid vacuum confusion - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Register Garage FAQ Members List Calendar Today's Posts Insurance
Old 22nd April 2011, 11:26 AM   #1 (permalink)
andre_gtr is waiting till its Alive again
andre_gtr's Avatar
Cars owned: 1995 R33 GTR
HIGuys
Please help with a vacuum problem i have currently my car is seeing boost of 0.5bar today i had a look at the vacuum to the pcm valve or boost solenoid i have two diagrams that has aided in my confusion here they are
1
2
my vacuum pipe with the restrictor is going to the plenum and actuators like the green in image 2 but no refrence if it is the restrictor pipe or not
in image 1 the blue seems to go to the resirc pipe wich should be the restrictor pipe
there seems to be new gaskets on the throttle bodies and plenum could someone that changed them hooked up the vacuum hoses wrong or are they correct
any help will be appreciated thanks
andre_gtr is offline   Reply With Quote
Old 22nd April 2011, 12:40 PM   #2 (permalink)
MrGT is think I might want a r32 gtr
MrGT's Avatar
Cars owned: series 2 R33 GTR (cold climate spec)
if hoses 8 and 9 in diagram 1 are the wrong way round it will cause your turbos to play up.
the 2 hoses in question are just under the plenum at the back of the engine. (i did it myself when changing my hoses but noticed before i drove the car.) has your plenum been off recently? or new hoses fitted ??
Tib
Behold a white GTR, and the man who sat in it was Death and hell followed with him.
MrGT is offline   Reply With Quote
Old 22nd April 2011, 05:07 PM   #3 (permalink)
andre_gtr's Avatar
Thanks so image 1 is correct the boost restrictor pipe no 2 should end at no 14
so a mixup on the pipework do you think ?
i imported the car recently from japan and was boosting 0.5 bar since i got it
the only thing is the gasket between the head and throtle bodies seems brand new so maybe did some work on the plenum side in japan
if i blow on the boost solenoid on the restrictor side its closed shut but blowing on the no 1 on image 1 connector seems to allow some air to pass and increases with the amount of air coming through so at the moment my boost solenoid is doing nothing
Old 22nd April 2011, 05:22 PM   #4 (permalink)
MrGT's Avatar
remove pipes 1 +2 block them off and fit and aftermarket boost controller problem solved.
Tib
Old 22nd April 2011, 08:35 PM   #5 (permalink)
andre_gtr's Avatar
is that the only way? no problem realy
but please confirm is image 1 the correct way of vacuum setup or image 2
then easy fix or i should just try and let you know but dont realy want to pop a turbo
thanks Andre
Old 6th October 2011, 09:59 AM   #6 (permalink)
rasored is Sudo Everything
rasored's Avatar
Cars owned: Stagea RSV4 & R32 GTR
I know it is a bit of an old thread but I am in the same situation ( just brought a none runner - I FOUND THE BLITZ BOOST CONTROL UNIT BEHIND THE FOOT KICK PANEL ???? , I have 4 tubes that relate to the boost system !! - 2 from the plenum rear and 2 from the AAC valve area under the plenum ?? , and i think that the diagram is wrong !! , the green pipe turns into a blue pipe !! then green again then blue ?? , from the actuators the pipe is the 1 ending with the restrictor collar in it the yellow ring pipe !! , this is the only diagram on the net and i think it is wrong !! , but that still leaves me wondering what to do with the 4 pipes i have .....................
rasored is offline   Reply With Quote
Old 6th October 2011, 10:14 AM   #7 (permalink)
andre_gtr's Avatar
Pic 2 is the nissan manual diagram and is correct
Old 6th October 2011, 10:43 AM   #8 (permalink)
Austrian GTR is now EFR boosted
Austrian GTR's Avatar
Cars owned: CX5 CD175 Revolution Top, R32 GTR
Hey Ted,
Do you have an installation instruction for your boost controller???
Is it a Blitz dual type???
Perhaps you could post a pic
Cheers,
Leo
My GTR
Austrian GTR is offline   Reply With Quote
Old 7th October 2011, 12:12 AM   #9 (permalink)
rasored's Avatar
so if pic 2 is correct , should the blue pipe in pic 2 be blocked off if using an aftermarket Boost control and solenoid ?
Old 7th October 2011, 04:09 AM   #10 (permalink)
andre_gtr's Avatar
block off all pipes and install the EBC as per the manual
just leave the old boost solenoid plugged in to cancel any errors it might give
Old 7th October 2011, 10:40 AM   #11 (permalink)
rasored's Avatar
that would be nice , but that is not the world I am in , there is no standard solenoid and the SBC is in ! , all this was done by the previous owner , including not mounting the control unit and having it behind the kick plate in the foot well . So I am still at square 1 ....
Old 7th October 2011, 10:57 AM   #12 (permalink)
andre_gtr's Avatar
Post some pics of what you have at the moment
Old 7th October 2011, 05:09 PM   #13 (permalink)
rasored's Avatar
It wont help much !
but , this is how mine is set up now !
as you see I have exactly what is in the diagram above - I have removed the restrictor from the tube to the solenoid and placed it into the plenum boost feed pipe 1mm hole
Old 7th October 2011, 06:34 PM   #14 (permalink)
andre_gtr's Avatar
Do you know where the 2 pipes in the pic connected to the EBC solenoid end up
and what model is the ebc
Old 7th October 2011, 10:30 PM   #15 (permalink)
rasored's Avatar
blitz ebc spec. r , the older 1 with the thinner knobs , and the 2 tubes are the green and blue in the diagram , the IN on the solenoid goes to the actuators and has the boost source T`eed in as in diagram , and the out to the blue vacuum control pipe/or to the metal pipes that enter the cold side of the turbos - bov system ! i think ..
the boost gauge , and , after market 1 NEVER point above 0 and the turbos do not spin up by the sound of things , certainly no BOV action !!
Old 9th October 2011, 07:47 PM   #16 (permalink)
andre_gtr's Avatar
IN port Should go to the ressure side of the turbo somewhere on inlet manifold no tee connections to anything else just straight
OUT should go to Actuators straight no tee to anything else
Check Page5 it applies to Spec R
http://www.naikontuning.com/det_tec/...sbc-spec-s.pdf
Old 9th October 2011, 09:58 PM   #17 (permalink)
rasored's Avatar
thanks for that , would have been nice to be able to read the text !? , cheers Andy
Old 9th October 2011, 10:58 PM   #18 (permalink)
Clive S-P is RB26 deficient
Clive S-P's Avatar
Cars owned: GT-R34 V-Spec & Stagea 260RS
On the diagram the green pipe leaves the solenoid, but if you follow it to where the diagram is labelled 8 & 9 the colours are swapped.
Possiblty the cause of some confusion.
Subsides de Terra Incendere!
Or
Burning through the world's resources!
... if your Latin is a bit rusty!
Clive S-P is offline   Reply With Quote
Old 10th October 2011, 10:06 AM   #19 (permalink)
rasored's Avatar
Top diagram is wrong and i have found the original creator/poster ? , and had a word with him !
Old 5th June 2019, 08:25 AM   #20 (permalink)
boomtheroom is boom
boomtheroom's Avatar
i have a ebc connected directly to the intake manifold and to the wast gates
so can i just remove the pcm and the 2 hoses joined to it and just put a small piece of hose linking the 2 pipes together at he bottom of where the pcm hoses were connected?
boomtheroom is offline   Reply With Quote
