R33 GT R Oil filter relocation and Cooler Installation - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 15th July 2011, 10:36 PM   #1 (permalink)
MMT
MMT is unaware they can edit their status
Just thought I'd do a brief description and stick up a few pics of my oil cooler installation.
I purchased all the components separately.
Oil cooler is an Earls narrow width (150mm) x 34 rows. Its about the same as a standard 19 row except the fittings are on top rather than the side and the capacity is slightly more than the 19 row. £180.00
The take off and relocation plate were from JDM via ebay and came with the correct AN10 fittings. Only slight issue was the relocation plate had an M20x1.5 thread whereas the RB26 is 3/4 UNF so at the moment I have a Subaru filter fitted but may go for an Evo filter next time as its slightly bigger. £25.00
I bought the Mocal sandwich plate from Advanced Automotives. Its a Hi-flow thermostatic type and was supplied with all the correct fittings. £61.00
The Aeroquip type fittings were from Torques via ebay. I bought 2 x 90 deg, 2 x 45 deg, 4 x straights, 3 meters of braided hose and a couple of alloy spanners, all AN10. £220.00
To make room for the cooler we had to remove one of the horn trumpets, cut away a small section of plastic trim and modify the bracket that holds the aircon canister. We then made a couple of brackets to secure the cooler in place.
The relocation plate is held by a bracket that is bolted to where the boost solenoid used to be. We situated it such that the dip stick was still easily accessible.
Anyway, a couple more pics showing the pipe runs. All quite obvious really, bit of a tw4t tightening the fittings on the take off plate and we had to loosen the headlight to help thread the hose.
We did an oil change while we were at it and pre filled the cooler before connecting the hoses to the sandwich plate.
I took it for a blast and it appears to get up to temp the same as before, maybe slightly longer. Where it would normally be creeping up to 100degs it seems to be stable at 80degs. And for some reason the oil pressure is slightly higher now?
Big thanks to [email protected] engines we did this round his gaff, used all his tools and he made all the brackets and stuff as well as helping decide what, where and how. Thanks mate
MMT is offline   Reply With Quote
Old 16th July 2011, 11:04 AM   #2 (permalink)
GavGTR is ,was, and about to be!!!
GavGTR's Avatar
Cars owned: R32 GTR with light modification - Bye Bye MR2 and Celica
Good stuff
Thanks for the heads up!
Oil Cooler is my next move after some rust TLC
GTROCer
"Own a GTR - RESISTENCE IS FUTILE!"
GavGTR is offline   Reply With Quote
Old 16th July 2011, 01:38 PM   #3 (permalink)
Satansbodyguard is .......
Satansbodyguard's Avatar
Cars owned: R32GTR
Looking great mate.......
With the oil filter that way up won't it be very messy at oil change time ?
Nigel
R.I.P Rob
Satansbodyguard is offline   Reply With Quote
Old 16th July 2011, 02:13 PM   #4 (permalink)
MMT
Nigel
Thanks.
To be fair, when you remove the filter in its original position oil spills everywhere. At least with this I can wrap loads of rags/tissue around to soak it all up before it spill over everything.
Old 16th July 2011, 05:15 PM   #5 (permalink)
Clive S-P is RB26 deficient
Clive S-P's Avatar
Cars owned: GT-R34 V-Spec & Stagea 260RS
This is a job on my list too.
Did you manage to fit everything with the plenum in place, or did you remove it?
I can't even see my oil filter, let alone see where to fit the sandwich plate with everything in place.
Subsides de Terra Incendere!
Or
Burning through the world's resources!
... if your Latin is a bit rusty!
Clive S-P is offline   Reply With Quote
Old 16th July 2011, 09:26 PM   #6 (permalink)
MMT
Yes we did it without removing the plenum. We did undo the thing to the left of the relocation plate (I think Andy said it was something to do with the injector controller?) to give a bit more elbow room. When we tightened the take off plate the fittings were at 9 and 3 o'clock. Obviously you need to make sure the connections between the take off plate and relocation plate are correct so oil goes through the filter the correct way. We found it best to connect the 3 o'clock connection first because you cant get a spanner on once the other connection is made. The relocation/ sandwich plate doesn't need to be bolted down until the end, so it can be moved around so you can get the spanners on easily and can be turned through 180degs to suit the pipes coming from the take off. One thing we did notice was that on these particular take off and relocation plates the ports were marked in and out, these were in actual fact marked the wrong way round. However, providing you connect in to in and out to out it will still be correct. You will no doubt know this, but just in case: oil enters the filter through the smaller holes around the outside and comes out from the centre. Hope this makes sense and helps.
Old 16th July 2011, 10:37 PM   #7 (permalink)
Clive S-P's Avatar
Yes it does, thanks.
I am going to put a link to this thread from my how to thread... hope you don't mind!
Or
Old 16th July 2011, 11:13 PM   #8 (permalink)
MMT
That's fine mate.
Old 16th July 2011, 11:19 PM   #9 (permalink)
SmigzyGTR is eating Lambo's in his 588bhp/ton Honda :)
SmigzyGTR's Avatar
Cars owned: R33 GTR, 500hp K20 EG6 Turbo
What sort of oil temps are you seeing now? Might have to plastic bag it in the winter to get the temps up bud, 'tis a big old cooler that
HARDCORE
SmigzyGTR is offline   Reply With Quote
Old 16th July 2011, 11:49 PM   #10 (permalink)
MMT
I was getting just over 100 on a spirited run up and down a 9 mile dual carriageway, It's now around 85. Essentially I've fitted it for a trackday at Donington next Thursday, so I'll see how it goes over the winter. I know the oil needs to get quite hot to burn off condensation, I could easily remove the thermostatic sandwich plate and blank the cooler hoses if need be or bag it like you suggest.
Old 3rd October 2011, 01:24 PM   #11 (permalink)
Sick Puppy is unaware they can edit their status
Does anyone have the relocation kit in a different place, I have the GREX kit and that huge thing is such a pain being right there. Anyone played with moving down in the front bumper area?
Sick Puppy is offline   Reply With Quote
Old 9th November 2011, 09:57 AM   #12 (permalink)
TheDude is missing his Rug
TheDude's Avatar
Nice, gonna take this as my manual
TheDude is offline   Reply With Quote
Old 29th December 2011, 10:45 PM   #13 (permalink)
ColinR33 is Eagerly awaiting spring
Very nice writeup, will use for mine when I do it.
ColinR33 is offline   Reply With Quote
Old 31st December 2011, 09:45 PM   #14 (permalink)
Sniper1st is RH9 Club - 1000 on the way ;)
Sniper1st's Avatar
Cars owned: Skyline GT-R R32 - Aristo JZS161 - Cherokee - GSXR 1000CC 2011
thanks for sharing your thoughts
Sniper1st is offline   Reply With Quote
Old 31st January 2012, 01:07 AM   #15 (permalink)
xzibith46 is Looking into starting an r324 once I got the money saved :)
This was very nice of you!
Thanks for posting this, printed it off for a buddy and he appreciates it!
xzibith46 is offline   Reply With Quote
Old 19th February 2012, 11:22 AM   #16 (permalink)
BCNR33GT-R is scary
BCNR33GT-R's Avatar
from years of own experiance you should go lower on the oil re locater.. No god to have it so high up mate.
Just my tips and tweeks..
BCNR33GT-R is offline   Reply With Quote
