#81 (permalink) |
bobel
is testing the limits of adhesion
Cars owned: R35, X5
I wonder is the flash automatically adjusting the cc/tp settings or are the originals retained and the better clutch engagement just means it feels like their higher.
I'll give the adjustment a go tonight and see if it is retained, don't mind the creep to much but when slowing to junctions the car can feel like it's straining against the brakes a little which I take as being unnecessary strain in the packs.
#82 (permalink) |
johnhanton57
is going back to black
I must admit that when i did a full unistall i expected the CTP to go back to 0 when i looked and found them to be 2 i made the change. it felt better at that time but did not check again after a drive cycle and have not been out since then
#83 (permalink) |
bobel
Cars owned: R35, X5
Ok so I got the creep eliminated eventually, firstly checked the tp and they were set to +2, so full uninstalled cobb, reloaded standard firmware, re-installed and set tp to -1 then fully uninstall again, update with alpha and re-install LC4, working much better now creep is gone on driveway at least, ran out of time to check on road but it should be fine, I think the new clutch engagement on the LC4 doesn't require the same amount of tp adjustment as the +2 tp setting was giving very little creep on LC2 but was really excessive on LC4.....all good now though :-)
#84 (permalink) | |
JoeGr
is working on 2012 EDM support
Cars owned: 2008 Specialized Stumpjumper
Joe
COBB Nissan Firmware Engineer (GT-R Hacker) I have the best job in the world, I get to play with fast cars and computers all day long. :-) ![]() |
#85 (permalink) |
johnhanton57
I'll probably wait for the fix or just reset TP each time i go out as it takes minutes and stays ok until you turn motor off. Come on Joe burn some midnight candles for the COBB team
#86 (permalink) |
ChuckUK
is a proffesional loafer
Cars owned: MK3 VR6, Evo 6, Type-R, R32, GSI, VX220T, RRS-SC, RS4, GTR :)
Sounds like something that should of been picked up at beta testing !
#87 (permalink) |
thistle
is aware they can edit their status
Cars owned: GTR, D4 S8, MkV GTI, E46 325ti, E46 M3
This was picked up in my testing. ChuckUK, are you running this gearbox software on your car from us and are unhappy? If so, I'll give you your money back on the cost of this alpha software
#89 (permalink) |
alloy
is SVM Stage 6!
Just trid LC4 again but with the 1st gear low boost map. Alas still VDC cuts the power.....does feel like a lot of wheel spin before the vdc cuts in though...
GT-R Black Edition | SVM | GTC | VM |
#90 (permalink) |
thistle
Eric will be searching for VDC off if this is what you want. I just don't have the time to do this work these days. But it is planned and should be feasible.
#91 (permalink) |
alloy
is SVM Stage 6!
Thanks John, not sure I want 4.5k launch with VDC off and a stock gearbox though....sounds expensive!
Guess the other option is wait to see if there is better results retro fitting the VDC from an MY11.....
#93 (permalink) | |
tomgtr
is Is tired of the W word!
Cars owned: GTR R35 UMS premium + Ford Smax 2.5T
Silver Premium edition delivered August 1, 2009 GTR23.com |
#95 (permalink) |
Saunders
is Mostly scrubbing off the dead flies from the
windscreen
Purchased my 006 from GTC today. They are great people. I cannot wait to get mapping. TCM changes are where I am really interested in things.
#97 (permalink) | |
johnhanton57
#98 (permalink) | |
[email protected]
Registered User
this week has been hot for NIS006, Matt got our last one in stock. There's been alot of discussion with Cobb Tuning about online NIS005 upgrade, all being well it should be happening
#99 (permalink) |
Stevie76
is at stage 4.25+FMIC and counting
Cars owned: Current: Stage 4.25 DMG R35, 2014 Impreza WRX STi, 1992 205 Mi16, Pimped 320d MSport Touring, BMW S1000RR HP4C
Great news Ben....any idea on timescales / costs?
2010 R35 GT-R Premium - Stage 4.25 + FMIC, 102mm Exhaust, Dump Valves, Gloss Black Wheels, Eibach ARB's, PwPro Wrapped, Litchfield tuned 666bhp / 611 lbs/ft |
#100 (permalink) |
[email protected]
Registered User
Asier / godzilla2009 with 1111whp GTX35, stroker engine, Titan 102 etc.. posted today running accessPORT LC4 he's worked a way to launch without vdc
Bookmarks |
Thread Tools | |
