4 Led Rear lights - Page 4 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 13th June 2012, 12:41 PM   #61 (permalink)
ossie cossie is the owner of a red GTR.
Right i started to do my 4 light conversion myself, tested the wiring to get the correct wires, then made up an extension wiring harness using deutz plugs, just incase i have to remove it later.
Found all the wiring colours and what they do. started fitting the diodes, to get all 4 lights to work, all was goin well. Then, i was doing one part at a time and testing as i was going, found that when i connected the diode in the side lamp wire and to the inner stop lamp, i could start the car without putting my foot on the brake if the lights were on. Startled me for a bit. Then i found that i had to put a diode back to back in the brake light wire before the other diode. That cured it.
Also found that when it is conected up in 4 light mode, the stop light, inner ones are on brighter than the outer ones, this must be where the voltage regulators are needed, will update my progress as i get more info.
Tony.
ossie cossie is offline   Reply With Quote
Old 13th June 2012, 07:48 PM   #62 (permalink)
ludez is unaware they can edit their status
ludez's Avatar
Thanks for all the hard work lads, will be following with interest!
ludez is offline   Reply With Quote
Old 13th June 2012, 08:03 PM   #63 (permalink)
KaizerMotor is new name for GTR in Kent.www.kaizermotor.co.uk
GTR Register Trader
KaizerMotor's Avatar
In July we are offering free installation of these diodes on every Stage2,Stage4 upgrade or 36 month services, if any of you are interested
THE LEADING SPECIALIST FOR NISSAN GTR IN KENT
YOUR NEED IS OUR PRIORITY
With 3 Nissan Trained Master Technician under one roof !
Mob:+44(0)7852291335
Web:
Email:
Find us on Facebook:
KaizerMotor is offline   Reply With Quote
Old 16th June 2012, 05:59 PM   #64 (permalink)
ikeysolomon is saying #supportthetechno
ikeysolomon's Avatar
Cars owned: Focus MK2 MP375, RRS SDV6, Mini Cooper SD
Fitted the GTC kit today. 10 mins at stated, looks much better imho.
Ikey
ikeysolomon is offline   Reply With Quote
Old 2nd July 2012, 08:13 PM   #65 (permalink)
Sinth is unaware they can edit their status
Tony.
any updates?
Sinth is offline   Reply With Quote
Old 2nd July 2012, 09:15 PM   #66 (permalink)
_shaun_ is unaware they can edit their status
_shaun_'s Avatar
Cars owned: At the moment R35, JDM S14, EVO X
Any kits so its like the MY12 cars? All 4s on during normal and then all 4s on braking?
_shaun_ is offline   Reply With Quote
Old 14th July 2012, 07:40 PM   #67 (permalink)
+1 any news on this? I heard the outer LED's need to be replaced to enable it to brake like the inner ring
Old 14th July 2012, 07:43 PM   #68 (permalink)
_shaun_'s Avatar
Ahh make sense as they would need to light up brighter on braking..
Old 10th September 2012, 01:29 PM   #69 (permalink)
OK update time i have altered the wiring on my Auxilary harness for the 4 rear light conversion, got some voltage reducers, rheostat type things, soldered them in line with the extra feed to the inner brake lights, and hey presto it worked. Before i adjusted them down the inner 2 stop lamps were on bright, as i adjusted the screw the inner LED,s went dimmer, i got them to about the same brightness as the outers, COOL. then with them on i put my foot on the brake pedal and hey ho all 3 of the brake lights came on full brightness.
Its late in the evening here in OZ, but tommorow i will post up pics of what i have done.
Tony.
Old 10th September 2012, 01:49 PM   #70 (permalink)
Bugger it here is a quick taster.
just the 4 park lights on, no brake lights.
My home made kit, modified harness, plug and play can easilly be removed.
Old 10th September 2012, 03:07 PM   #71 (permalink)
^^ awesome work. Do 4 lights work brighter when your brake too? Or is it just the inner two rings ? Can you please post up a DIY if possible with photos
Old 10th September 2012, 11:39 PM   #72 (permalink)
When i put the brakes on, the inner rings and the brake light on the spoiler light up brighter. I will sort out more pics and a DIY drawing etc later.
Old 11th September 2012, 11:03 AM   #73 (permalink)
brake lights only.
brake and side lights.
4 side lights only.
Old 11th September 2012, 12:37 PM   #74 (permalink)
Nice. Got a diy?
I wish there was a way of getting the outer ring to work as well when braking.
Old 11th September 2012, 12:39 PM   #75 (permalink)
*MAGIC* is unaware they can edit their status
Power User
*MAGIC*'s Avatar
Nice. Got a diy?
We are fitting one tomorrow along with some halo's for the headlights so I will take pics and post them up if no one else does in the meantime
Robbie
UK's finest GT-R Detailing / Enhancement Specialist.
-Creator of the finest GT-R's around -
- Studio location - Camberley GU15 -
Tel: 01344 891 891
Direct: 07817 922 095
Oo oO Halo lights available
Cobb Accessports available
Vinyl Wrapping / Tints / Wheel refurbs.
Full bodyshop facilities available
Zaino approved detailer
Exhausts & Y-Pipes supplied & fitted.
Official Knight Racer stockist.
*MAGIC* is offline   Reply With Quote
Old 12th September 2012, 02:06 AM   #76 (permalink)
When i get back next week i will try something out. RE making the outer lights work as brake lights as well. It may just be the supply voltage, what i was thinking is putting the brake light wire into the outer light and see if it comes on bright, if so it will just be some more diodes. But i cant see it bieng that easy. I know some LED,s work on variable voltage. The ones i have seen work on, say 12 to 30 volts for example.
Old 12th September 2012, 02:06 AM   #77 (permalink)
Hmmm! Halo,s would like to see them.
Old 16th September 2012, 12:58 PM   #78 (permalink)
any updates on drawings and equipment used?
Old 16th September 2012, 11:41 PM   #79 (permalink)
Sorry guys, i am at work, dont fly home till tuesday arvo. When i get back i will sort out some diagrams and a list of parts with pics.
Old 24th September 2012, 05:38 PM   #80 (permalink)
Any pics of the wiring and stuff used? Fancy making one for myself
