-   R35 - "How to" and DIY guides (https://www.gtr.co.uk/forum/r35-how-diy-guides.html)
-   -   4 Led Rear lights (https://www.gtr.co.uk/forum/157921-4-led-rear-lights.html)
ossie cossie 28th September 2012 07:22 AM
sorry forgot about this will sort it out next week. After tuesday evening.
Sinth 3rd October 2012 02:06 PM
Invested in a GTC light kit now.
[email protected] 3rd October 2012 02:18 PM
:thumbsup:
Sinth 8th October 2012 09:04 PM
Originally Posted by [email protected] (Post 1685950)
:thumbsup:
Forgot to update.
I received the goods the next day and fitted in 10 mins. I was initially considering messing about cutting wires and using diodes but in the end decided it wasn't worth butchering the car. This was a simple plug and play kit.
The results
http://i860.photobucket.com/albums/a...006_193054.jpg
Thanks [email protected]
spiceykam 30th October 2012 04:35 PM
Greetings, having read through the 6pages of the forum relating to this topic, Valet Magic were kind enough to fit the appropriate wiring, so I could have these after burner lights visible all the time and when foot on brake, enable the innner ring to shine brighter. However still looking where there is an effective kit/wiring that enables the rear side strips to become additional lighting, seen some of these done in the US on Youtube, any ideas and kits would be useful, thanks :)
Sinth 30th October 2012 04:38 PM
the USDM cars are different and when you brake all 4 illuminate. No kit is required for them.
spiceykam 30th October 2012 10:59 PM
Yes mine also now with kit illuminates all four, my query is with the side reflectors on rear of GTR, they've been illuminated also by other owners. I'll try and post a pic.
spiceykam 31st October 2012 11:49 AM
Update, these look nice but a bit pricey but hey if looks could kill:
vosmotorsports: TOMMY KAIRA LED Smoked Rear Side Markers for GT-R
spiceykam 31st October 2012 11:59 AM
Side Lens illluminated
1 Attachment(s)
Protegimus 4th November 2012 02:22 PM
5 Attachment(s)
As an addendum to my original post containing the schematics and with a big thanks to ossie cossie for figuring out the correct (180ohm) resistor value, the following diagram gives the correct wiring to allow all four tail lights as sidelights; brakes lights remain high intensity on the two inner (original) lights and the third high level spoiler light, plus optionally operate as four brake lights (with outers at normal intensity) when the sidelights are switched off:
Attachment 6293
Bit of advice during installation - the plugs undo easily once the retainer is unclipped, press down on the central retainer with a small (4mm) flat blade screwdriver then pull the harness out:
Attachment 6289
Standard connector pinout - I used 1N4001 diodes. The feed from the brake lights to the tails lights (diodes A & B for four brake lights with sidelights off, which is optional) is already spliced:
Attachment 6290
Now the brake light feed is cut ready to splice in the 180ohm metal film resistor and diodes C & D:
Attachment 6292
Heat shrink insulates and supports the soldered in components - it is only a few pence and much better than insulation tape. Cut to length and borrow your Mrs. hairdryer to shrink:
Attachment 6291
Protegimus
WooHoo 4th November 2012 05:00 PM
@Protegimus... That's interesting - when you put a third diode in to get 12v to the tail light on braking, I'm assuming that lights the tail light at its normal intensity? I didn't do that when I was making up the wiring, as I thought it would look odd. If in fact the tail light is lighting up at the same intensity as the brake light when the pedal is pressed then the car's wiring is not quite how I'd imagined it.
I think there must be either a resistance (maybe also about 180 ohms) built in to the loom of the light cluster for the tail light, or the tail light LEDs have lower output at 12v. Either way, what makes the tail light less bright than the brake light at full voltage is distal to the connector from the car loom to the light cluster. Hence why getting all four(five) lights lit under braking requires modification to the lights themselves, which is a ballache. If I'm wrong on that let me know, as I'll dive back in and plumb in another diode!
Andrew
Protegimus 4th November 2012 07:10 PM
You're right Andrew the cluster must have additional control on the normal tail lights. As is, with sidelights off braking illuminates all four tail lights; however only the inner original plus high level lights are high intensity. I preferred the effect so left it that way.
Not sure I fancy opening up that cluster.
spiceykam: what you want to achieve should be easy as you have access to the inside of the side reflectors with only the rear panel out. They are transparent so you'd only have to test illuminating them with a red LED bulb if you didn't want to go as far as obtaining US reflectors.
Protegimus
ossie cossie 4th November 2012 11:33 PM
Can you access the rear corner marker lamps by just taking out the boot carpet?
spiceykam 5th November 2012 09:26 AM
4 LED Rear Side Reflector_Lights
1 Attachment(s)
Thanks Protegimus, please see an example side refelctor LED lights, when it comes fitting I'll get Valet Magic a call, they know their stuff when it comes to detailing/cosmetic :)
X2K 5th December 2012 05:16 PM
I also build my tail lights the same way. it works great on my LHD GTR. it only cost me 2 euro .
Sinth 5th December 2012 07:12 PM
where you find this? seems pricey
Satan 11th December 2012 07:14 PM
Spill the beans
So are you going to tell us all how you did it?:clap:
enshiu 11th December 2012 11:51 PM
Are those allowed for mot?
X2K 12th December 2012 05:38 AM
hi.-
you can use the diagram from my homepage and build it.
X2K.dk - GTR white - LED 4 lights tail
X2K 12th December 2012 04:44 PM
Originally Posted by X2K (Post 1713570)
hi.-
here a pic of them
http://x2k.dk/images/GTR%20%20white/...20tail%203.jpg
