4 Led Rear lights - Page 5 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 28th September 2012, 07:22 AM   #81 (permalink)
ossie cossie is the owner of a red GTR.
sorry forgot about this will sort it out next week. After tuesday evening.
ossie cossie is offline   Reply With Quote
Old 3rd October 2012, 02:06 PM   #82 (permalink)
Sinth is unaware they can edit their status
Invested in a GTC light kit now.
Sinth is offline   Reply With Quote
Old 3rd October 2012, 02:18 PM   #83 (permalink)
Registered User
BenLinney@GTC's Avatar
Old 8th October 2012, 09:04 PM   #84 (permalink)
Originally Posted by [email protected] View Post
Forgot to update.
I received the goods the next day and fitted in 10 mins. I was initially considering messing about cutting wires and using diodes but in the end decided it wasn't worth butchering the car. This was a simple plug and play kit.
The results
Thanks [email protected]
Old 30th October 2012, 04:35 PM   #85 (permalink)
spiceykam is unaware they can edit their status
spiceykam's Avatar
Greetings, having read through the 6pages of the forum relating to this topic, Valet Magic were kind enough to fit the appropriate wiring, so I could have these after burner lights visible all the time and when foot on brake, enable the innner ring to shine brighter. However still looking where there is an effective kit/wiring that enables the rear side strips to become additional lighting, seen some of these done in the US on Youtube, any ideas and kits would be useful, thanks
spiceykam is offline   Reply With Quote
Old 30th October 2012, 04:38 PM   #86 (permalink)
the USDM cars are different and when you brake all 4 illuminate. No kit is required for them.
Old 30th October 2012, 10:59 PM   #87 (permalink)
spiceykam's Avatar
Yes mine also now with kit illuminates all four, my query is with the side reflectors on rear of GTR, they've been illuminated also by other owners. I'll try and post a pic.
Old 31st October 2012, 11:49 AM   #88 (permalink)
spiceykam's Avatar
Update, these look nice but a bit pricey but hey if looks could kill:
vosmotorsports: TOMMY KAIRA LED Smoked Rear Side Markers for GT-R
Old 31st October 2012, 11:59 AM   #89 (permalink)
spiceykam's Avatar
Side Lens illluminated
Old 4th November 2012, 02:22 PM   #90 (permalink)
Protegimus is enjoying GT-R LMS4 motorsport
Protegimus's Avatar
Cars owned: R35 Black Edition
As an addendum to my original post containing the schematics and with a big thanks to ossie cossie for figuring out the correct (180ohm) resistor value, the following diagram gives the correct wiring to allow all four tail lights as sidelights; brakes lights remain high intensity on the two inner (original) lights and the third high level spoiler light, plus optionally operate as four brake lights (with outers at normal intensity) when the sidelights are switched off:
Bit of advice during installation - the plugs undo easily once the retainer is unclipped, press down on the central retainer with a small (4mm) flat blade screwdriver then pull the harness out:
Standard connector pinout - I used 1N4001 diodes. The feed from the brake lights to the tails lights (diodes A & B for four brake lights with sidelights off, which is optional) is already spliced:
Now the brake light feed is cut ready to splice in the 180ohm metal film resistor and diodes C & D:
Heat shrink insulates and supports the soldered in components - it is only a few pence and much better than insulation tape. Cut to length and borrow your Mrs. hairdryer to shrink:
Protegimus
'59 Black R35 Black Edition :: Akrapovic Carbon/Ti cat back :: GTC Ti Y-pipe :: EcuTek LMS4.25 :: Alcons/Pagid RS-29/Goodridge lines :: Litchfield Handling Kit/Eibach ARB's :: RSW Carbon
Old 4th November 2012, 05:00 PM   #91 (permalink)
WooHoo is now on EcuTek
@Protegimus... That's interesting - when you put a third diode in to get 12v to the tail light on braking, I'm assuming that lights the tail light at its normal intensity? I didn't do that when I was making up the wiring, as I thought it would look odd. If in fact the tail light is lighting up at the same intensity as the brake light when the pedal is pressed then the car's wiring is not quite how I'd imagined it.
I think there must be either a resistance (maybe also about 180 ohms) built in to the loom of the light cluster for the tail light, or the tail light LEDs have lower output at 12v. Either way, what makes the tail light less bright than the brake light at full voltage is distal to the connector from the car loom to the light cluster. Hence why getting all four(five) lights lit under braking requires modification to the lights themselves, which is a ballache. If I'm wrong on that let me know, as I'll dive back in and plumb in another diode!
Andrew
WooHoo is offline   Reply With Quote
Old 4th November 2012, 07:10 PM   #92 (permalink)
Protegimus's Avatar
You're right Andrew the cluster must have additional control on the normal tail lights. As is, with sidelights off braking illuminates all four tail lights; however only the inner original plus high level lights are high intensity. I preferred the effect so left it that way.
Not sure I fancy opening up that cluster.
spiceykam: what you want to achieve should be easy as you have access to the inside of the side reflectors with only the rear panel out. They are transparent so you'd only have to test illuminating them with a red LED bulb if you didn't want to go as far as obtaining US reflectors.
Protegimus
Old 4th November 2012, 11:33 PM   #93 (permalink)
Can you access the rear corner marker lamps by just taking out the boot carpet?
Old 5th November 2012, 09:26 AM   #94 (permalink)
spiceykam's Avatar
4 LED Rear Side Reflector_Lights
Thanks Protegimus, please see an example side refelctor LED lights, when it comes fitting I'll get Valet Magic a call, they know their stuff when it comes to detailing/cosmetic
Old 5th December 2012, 05:16 PM   #95 (permalink)
X2K
X2K is unaware they can edit their status
X2K's Avatar
I also build my tail lights the same way. it works great on my LHD GTR. it only cost me 2 euro .
X2K is offline   Reply With Quote
Old 5th December 2012, 07:12 PM   #96 (permalink)
where you find this? seems pricey
Old 11th December 2012, 07:14 PM   #97 (permalink)
Satan is skint, but with a stupidly big grin !!
Satan's Avatar
Spill the beans
So are you going to tell us all how you did it?
Satan is offline   Reply With Quote
Old 11th December 2012, 11:51 PM   #98 (permalink)
enshiu's Avatar
Are those allowed for mot?
Now: R35 GTR JDM - R32 GTS4
Past: R33 GTR sgl turbo
Old 12th December 2012, 05:38 AM   #99 (permalink)
X2K
X2K's Avatar
hi.-
you can use the diagram from my homepage and build it.
X2K.dk - GTR white - LED 4 lights tail
Old 12th December 2012, 04:44 PM   #100 (permalink)
X2K
X2K's Avatar
hi.-
here a pic of them
