What are your oil temperatures? - Page 2 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
View Poll Results: What Oil temperature do you see under normal hard road driving?
Who cares...! 0 0%
std. cooling: below 70*C mark 2 1.32%
std. cooling 70-90*C 40 26.32%
std. cooling 90-110*C 24 15.79%
std. cooling 110*C+ 2 1.32%
oil cooler below 70*C mark 5 3.29%
oil cooler 70-90*C 64 42.11%
oil cooler 90-110*C 9 5.92%
oil cooler 110*C + 4 2.63%
Are you mad?? You are way off!! 2 1.32%
Voters: 152. You may not vote on this poll
Like Tree4Likes
Old 16th September 2012, 11:31 AM   #21 (permalink)
Siegerd is unaware they can edit their status
Running a UK spec R34 GTR so standard nismo oil cooler, most of the time 70deg C when i drive the car. Hot days city use it could go to 90deg C but that is highest i've ever seen my oil temperature. I've use Shell full synthetik 5W30 oil.
Siegerd is offline   Reply With Quote
Old 16th September 2012, 11:49 AM   #22 (permalink)
Little Nismo is A Pickled Cabbage
Cars owned: Nissan Skyline R33 GTR, 402kw @ 1.75bar
The problem here is that context means everything.
My car would hit 70-80 deg most of the time and never see over 90deg on the road even open road spirited driving.
However on the track is a different story. The temps just skyrocket. 120 after 3 laps, 130 after 4-5 by 7 it could be 135.
Turns out now that i'm doing a rebuild the water galleries were chocka block with rust scale and the bearings were starting to wear! so the two combined compound to cause the excessive heat feedback loop. runing a 12 row cooler btw.
Anything that Doesn't kill you can only Maime u for life
Little Nismo is offline   Reply With Quote
Old 24th September 2012, 05:52 AM   #23 (permalink)
BigKriss is Cruiz`n a little..
Where are the RIPS boys here ? and the other top blokes who run proper cars at events ? They can give us solid real life info here.
We built and raced the Alfa Romeo GTa`s here and we got concerned when temps started reaching 130 Deg C.
I feel 70 and 80 deg C is too cold for oil as well..
BigKriss is offline   Reply With Quote
Old 24th September 2012, 07:09 AM   #24 (permalink)
I don't think RIPS races on a circuit much mostly the 1//4
Old 25th September 2012, 02:46 PM   #25 (permalink)
Ill bet my bottom dollar they also get the temps up to spec before they do a run. They will have an ultimate temp they use, of that I`m sure.
I think the engine they lost was due to too cold oil ??
Old 26th September 2012, 10:31 AM   #26 (permalink)
Depends which one you mean I know one cracked the block due to a broken engine mount I don't know about others? And I am sure that drag oil temps are completely different to circuit
Old 29th September 2012, 09:47 PM   #27 (permalink)
Wouter is working at Co-ordSport
Cars owned: '97 series 3 BCNR33, '94 SW20 Turbo
I'm running a HKS oil cooler kit, normal driving around 72, sporty driving nearly 80. That's German Autobahn 250km/h or 20 min track driving.
Best mod so far
Wouter is offline   Reply With Quote
Old 30th September 2012, 06:03 AM   #28 (permalink)
Uhmm, there`s a vid on the Tube where the RB30 chucks a rod ?? They comment that they did not warm the oil sufficiently before the run as a competitor had fallen out and they had to fast forward their run.
I may be wrong, secondhand info here..
Do you guys still use the std. oil/water heat exchanger in conjunction with the oil cooler ??
Wouter, you not worried that 72 deg c is too cold for oil ?? I would be a little concerned that that may be a little low..
Old 30th September 2012, 07:26 PM   #29 (permalink)
DNCracing is unaware they can edit their status
Street driving with occasional sprints i run at about 86 to 93 C.
DNCracing is offline   Reply With Quote
Old 13th October 2012, 12:24 AM   #30 (permalink)
Silviagtr85 is Gtr31985
Hi guys,my temps are a bit worrying,it is kinda cold in Scotland just now but not freezing but if I'm driving around town I get about 70/80oC but as soon as I go out onto the main roads it drops straight down to the minimum 50oC I hope it a faulty guage as I don't think oil would loose temp so quickly :/
Silviagtr85 is offline   Reply With Quote
Old 6th November 2012, 01:30 AM   #31 (permalink)
BaKaJin is a GT-R lover
BaKaJin's Avatar
Cars owned: 89'GTR, 90'GTR, 00'GTR V-Spec II, 95 Supra, 93 RX7 Efini, 91 Soarer, 91 Aristo, 05 STi
Have the same issue as yours, I will have the water galleries checked sometimes soon Cheers mate!
BaKaJin is offline   Reply With Quote
Old 6th November 2012, 07:39 PM   #32 (permalink)
Jimbostir is Wondering if Andy H has lost his Pistons?.
Jimbostir's Avatar
Cars owned: Datsun
Odd. What cooler have you got? Yeh got to be the gauge/sensor surely
Old 10th November 2012, 08:26 PM   #33 (permalink)
I have a 19 row cooler,I have covered the cooler with tape and tin foil and now I'm getting temps of 80-90
Old 10th November 2012, 08:32 PM   #34 (permalink)
There is a maximum size you can run before the oil pump starts to struggle though i think ie a 19row cooler is a bit bit for a standard oil pump. Of course i would think that 2 9row coolers woudl be at least as restrictive.
Is 19 row to big with a N1 oil pump?
Old 30th November 2012, 01:09 PM   #35 (permalink)
oilman is unaware they can edit their status
Registered User
Cars owned: Mazda RX8
Looking at the temps you guys have posted, there are a few cars where the oil isn't getting hot enough you want it to get over 70-80C as some of the additives require heat to work properly. You don't want to overcool the oil, 100C is ideal.
Also, the temps are generally within the safe tolerances for a quality 5w-40 (up to 130C average, with higher peaks). Perhaps with a forged build a 10w-50 would be better if the temp gets over 115C or it burns much oil.
Tim
Gav.Diamond, MS33 and enshiu like this.
Old 10th December 2012, 11:38 PM   #36 (permalink)
Deddu is engaged with his Bnr32!
Deddu's Avatar
my r32 gtr with standard cooling is in the range from 70 to 90.. on the streets.. i think during a race in a trackday go to 90-100.. i hope not much more.. ahah
ps: oem turbos, 360whp ecc ecc
Deddu is offline   Reply With Quote
Old 31st December 2012, 08:54 AM   #37 (permalink)
iceager is missing tweenierob, RIP mate
iceager's Avatar
Cars owned: R33GT-R
120C on the track in 35C outside temp. after 5 laps with high revs all the time.
Was in Germany in 2009 did 298 km/h and oiltemp was 80C.
Hard city driving is about 85-90C.
Running 2.0bar, with N1 engine block´+ 40mm alu radiator, normal thermostat.
enshiu likes this.
TweenieRob build RB28 - T04Z
iceager is offline   Reply With Quote
Old 31st December 2012, 02:10 PM   #38 (permalink)
Registered User
120degc on track, that is quite hot!
Guy
Old 31st January 2013, 11:11 AM   #39 (permalink)
MervinoGTR is unaware they can edit their status
org cooling on R32 GTR good lap on nordschleife tends to get very hot, 130+ degrees.
MervinoGTR is offline   Reply With Quote
Old 24th April 2016, 05:24 PM   #40 (permalink)
bigkeeko is in business
bigkeeko's Avatar
Cars owned: R34 GTR M Spec
Seeing as this thread pops up anytime anyone votes I thought I'd add my 2p worth.
My oil is never hot if I drive the car easy. Ok, I don't thrash it much ( and I never have done with any car) but I think the highest I've noticed is 76. It's usually 71 or 72 when driving normally. In saying that, it's been cold since I got it so I've never seen it in traffic on a hot day.
bigkeeko is offline   Reply With Quote
