-   Tuning: General (https://www.gtr.co.uk/forum/tuning-general.html)
-   -   What are your oil temperatures? (https://www.gtr.co.uk/forum/159863-what-your-oil-temperatures.html)
backout 10th January 2012 08:33 PM
Hey everyone
I've been wondering what oil temperatures everyone is getting?
The reason I ask is to try to figure out if my oil temp gauge is off , and to choose the right oil grade/weight.
I have a 12 bar oil cooler so expect it to be low but if the temps are below 90*C will I need to use a 10w-50 or 15w-50? Would a 10w-40 or the like not be better...?
I've added a poll for anyones future reference.
Moff 11th January 2012 07:23 PM
Depends on the outside temp too.
Voted based on road driving, but
I can see 90 on track on zero degrees, or 120 on a hot summers day
Alex C 11th January 2012 07:23 PM
I briefly debated this with RB motorsport as I was also thinking that for the vast majority of the time, my temps were below 80deg. In the end however I bowed to their knowledge and continued to use 15W-50 racing synthentic and I think most other estbalished tuners will use a similar grade for turbo seal leakage reasons.
I never use more than half revs, half throttle until the temp is over 70deg.
On the track I saw a peak of about 110deg after 4 laps of 5K-8k revs, I have a 19 row mocal cooler.
adamsaiyad 13th January 2012 06:05 PM
my vote comes from Africa where ambient temps are around 24-38C
GTR Cook 12th July 2012 01:08 PM
Hardly see above 85 on the road given it a a little stick.
Jakobsen 13th July 2012 04:49 PM
running R32GTR and HKS Type R Oil cooler kit and relocation. normal cruise just above 70C but on the pedal i will go op just a little :) Btw also run Truust Greddy sump so have som more oil then Stock
pupsi 15th July 2012 10:31 PM
Around town normal driving with an oil cooler, I see around, between 80 and 90, when booting it, it'll go up to 110.
ShanGTR3318 20th July 2012 05:10 AM
Approx 80deg on my 33gtr on touge
Red Duke 21st July 2012 11:25 AM
Mine hovers around 80 (got a Mocal oil cooler) even booting it a bit it doesn't go above 85-90, only seen 90+ after a long cruise on the Autobahn at about 80-90mph, and then stopping for fuel / piss / coffee and the engine not running to circulate the oil.
ian turbo 21st July 2012 03:29 PM
Oil cooler , plus trust ex sump normal driving 70, when driving hard up to 80-90.
Adam Kindness 21st July 2012 05:59 PM
roading driving - 75ish
20lap race - 98-100ish
19row 230mm wide cooler, thermo plate, 8l sump
nazams 21st July 2012 06:10 PM
Oil temp Arnt they all different depending on what sort of engine or mods you have??
backout 22nd July 2012 10:23 AM
..and that is why you need an oil cooler.
Little Nismo 5th August 2012 10:42 AM
on the track i see up too 135 degrees. talked to a lot of people about this varied opinions on whether this is too high. i use very good oil a 13row cooler and big radiator but water temp will still hit 110 and oil 135 on ten lap session on 1 bar boost with standard turbos.
BaKaJin 27th August 2012 06:03 AM
I have similar issues as you are. My R34 GTR hit 127C after only a couple laps on the track. I lived in Indonesia where temp is around 30-34C. Car is on stock turbos on 1 bar boost as well. car also has no oil cooler or upgraded radiator. My mechanic told me to install dual oil cooler, is it necessary?
Brains 27th August 2012 06:30 AM
Easier to fit one larger one.
Little Nismo 27th August 2012 06:31 AM
Intersting i had not thought of dual coolers but it makes sense i guess. I will ask mine and see what he reakons.
Little Nismo 27th August 2012 06:35 AM
There is a maximum size you can run before the oil pump starts to struggle though i think ie a 19row cooler is a bit bit for a standard oil pump. Of course i would think that 2 9row coolers woudl be at least as restrictive.
BaKaJin 28th August 2012 07:42 AM
Yes, I was told to use dual Greddy coolers, especially because it comes with the oil relocation kit.
Anybody ever compared the Greddy with Mocal? I heard about them before, but never buy their products.
BigKriss 14th September 2012 08:07 PM
Running two coolers, would that be in series or parallel ?
Series coolers would i.m.o. be rather restrictive with an accompanied pressure loss ?
Interesting to see what others are getting temp wise..I am in Africa where summer stinks and oil temps go crazy..I am using a 19 row Setrab and Setrab thermostatic adapter....track time temps around 110deg C.
