Jm-Imports
is sitting on 1293 @ the hubs
Registered User
Syvecs S8 Ecu on R35 GTR fully working - Tuning on a new level
This is the new ecu going in my R35 GTR..
awesome stuff.. If anybody is interested feel free to email us for cost and mapping. [email protected] 14 minutes Demo well worth the watch Syvecs R35 GTR Demo - YouTube So Whats it all about ? The Syvecs S8 ECU for the Nissan R35 GT-R Will be released in March 2012. I have information and videos that i hope will interest all those in the market for tuning the R35 GT-R. Here is the latest update from Ryan at Syvecs. "After 7 months of development we finally have it all working perfectly. Just need to make some changes to the tuning software for the launch control options for the GTR and also setup the traction control at the test track. Will get another video of some of the dyno and test track action up soon. Release date March 2012" With the Syvecs S8 for the R35 GT-R you can fully adjust the Torque Actual and Torque Demand Maps live which Syvecs have mapped to copy as stock presently. Syvecs did some testing increasing and reducing actual torque and the difference was brilliant. (See link for logs below) Can make clutch pressure apply more and less properly without having to increase touch points which can make low down driving not nice. Can also adjust the slip and shift point by changing the torque tables. This made power go up and clutch temps to drop! The logs are available for download here: Logs S8 Torque.zip On other ECU’s like Cobb AP and ECUTek you can only increase the clutch Demand which is not the right way of doing it for more clamping and why many have experienced issues. Features which stand out for the GTR: - live tuning of any map - Full VVT control - Full Control over Fans - super fast connection using rj45 Ethernet connection so ability for live tuning anywhere in the world or even on Track if connected to wireless unit. - Connect any race series dash or even one of our partners small can adjustment /display units - control up to 12 injectors so on big power vr38 engines ability to run staged injection - Wet and Dry nitrous control with ability to drive solenoids directly and control n20 heaters via pressure monitoring - control high or low impendence injectors - view any input live with built in scope up to 1000hz And much more which they are still working on. Here are the Spec's for the Syvecs ECU used for the GTR: Processing: Powerful RISC CPU for advanced strategy execution Custom synchronous FPGA processor for engine position tracking and output diagnostics up to 25,000rpm Outputs: 28 user configurable general purpose Pulse Width Modulated power outputs, including: 8 Ignition Coil outputs IGBT or TTL (Software configurable) 16 Fuel Injector outputs 2 Full Bridges also configurable as 4 Half Bridges or 4 PWMs (DbW & HDP-5) Inputs: 24 user configurable general purpose analogue sensor inputs, including up to 16 bipolar, inductive or hall effect speed / engine position inputs 6 dedicated inputs, including: 2 Acoustic knock sensor inputs 2 Wideband (NTK) lambda sensor interfaces† 2 K-type thermocouple sensor interfaces Interfaces: 100 MHz full duplex Ethernet for calibration, configuration and data download 3 CAN 2.0B† interfaces for communication with other controllers or logging systems RS232 serial interface for communication with other controllers or logging systems Memory: 4MB or 8MB† battery backed internal logging memory Downloaded in under 10 seconds via Ethernet Time/Date stamped data via real time clock Power Supply: 6 to 32V input voltage range with reverse polarity protection 2 regulated 5V sensor supply output with individual short circuit protection Software configurable (5 to 12V) sensor supply output (eg for 10V load cells) Unregulated sensor supply output which tracks the ECU supply voltage with nominal 17V clamp 5 Separately protected sensor and communication ground inputs Physical: 88 pin automotive connector CNC machined, ‘O’ ring sealed, anodised aluminium case Maximum dimensions including the connectors are 178 x 122 x 36 mm Total mass is 485 grams
Jm-Imports
Registered User
this will make fast cars go faster lol.. it can change so much to the stock ecu, we have been using them on supras and the changes is amazing over stock ecu..
the safety trips has to be the winner for me.
Adamantium
is apparently poisonous to Wolverine - who knew?
As far as I am concerned the syvecs is the best standalone ecu on the market.
Made by the one of the best ecu manufacturers, and specced by those hardcore tuners who know the features they need in order to contol the car properly. Combine these two and put them in the hands of real enthusiasts and you have the perfect tool for the aftermarket. If going beyond ecutek or cobb's current facilities this is the only ecu to consider!
MiGTR
is frying his noodle
Cars owned: MKII Golf VR6, Supra Big Single, E46 M3, E46 M3CSL, E60 M5, 2010 R35 GTR, 997 Turbo Tip. Currently Own: A Barge!
Impressive stuff. It sure looks like it offers far more flexibility for those that don't want to go down the romflash route.
Jm-Imports
Registered User
it is awesome stuff, i have invested in my R35 GTR and with this ecu we can monitor everything..
i have almost all the sensors fitted on my engine to adapt to this ecu in March. dont get me wrong the cobb and ecutek are great but this is a different league and a must for the bigger builds.
#13 (permalink) |
[email protected]/AMS.UK
is R33 GTR
Looks good.
#14 (permalink) |
Steve
is Mr GTR
Cars owned: Nissan Skyline R33 GT-R "V"Spec
& the price ??
I looked at the Syvecs unit for my R33, but just couldn't justify the proce as I already have an HKS F con with the wiring harness which was £2k back in the day. Nice piece of kit IF you (I) was starting from afresh
Keep it on the Black Stuff Steve + A-BEUT + A1 BEUT + Kermit HARDCORE MEMBER 2008 Nissan GTR Black Edition (Racing "Fastest Colour" Red) 1997 Nisan Skyline R33 GTR V Spec (Midnight Purple, the only Colour for an R33 GTR) 1991 Honda NSX Type R (Vibrant Red) 2011 Porsche Cayman R (Peridot Green) 2108 VW Golf R (Saffron Gold) 2003 Mazda MX5 (Blue) |
#15 (permalink) |
Jm-Imports
Registered User
looking forward to having this on my car now..
here is another teaser video Syvecs S8 Gtr Demo of Torque and Launch control - YouTube
#17 (permalink) |
bcl
is addicted to turbos
It's not just the gearbox, that's a lot of stress on the axles.
On one of 2wd turbo cars I've twisted a tailshaft with about 5lb boost at the drags. Always the case of finding the next weakest link. Brian
#18 (permalink) |
Jm-Imports
Registered User
Just an update guys
The Syvecs Kit was fully released 2 weeks ago but we have not done any press release yet as we wanted to get the whole kit tested on a few big power GTR’s around the world that wanted exclusive use first. This was very useful for us, as lots of feedback from some of the biggest Gtr calibrators around the globe lead to a few firmware updates which we got on straight away and released within the week. As all the calibrating had been done initially on a low spec GTR it was important for me to get involved personally and get some good base maps for the big power cars on ID2000 and modified heads which have less manifold vacuum which plays a big roll in the torque calculations. This obviously took a lot of time as with a full standalone kit we are pretty much going back to what most of the head calibrators at Nissan did on the stock ECM. I managed to fit into my busy schedule a short trip to Dubai to get 2 kits tested and setup on highly modified Gtr’s and had the luxury of testing the new launch strategy. The Launch can be completed 2 ways now. The first method controls the ramp in effect of torque control based on Throttle opening versus ground speed which can be perfectly plotted to maximise traction and Long G. The second method controls the ramp in effect based on ignition cut, ignition retard or fuel cut. This is much more aggressive method as allows the torque to be reduced on the ramp in but keep the turbine drive pressure and energy alive to have full boost constantly with no lag. Here is a brief video of a tame launch with method1 with only 0.3bar and 45% throttle which was right on the limit of traction with road tyres as you can see from the log below. Syvecs S8 GTR Kit - Soft 3000rpm Launch Control with no Ign Cut or retard - YouTube Red = Manifold Pressure Green = Rpm in Graph1 and Launch Switch in Graph2 Orange = Throttle angle (See how ramps in based on speed) Purple = Vehicle Speed (Front Wheels) Blue = Longitude G Yellow = Wheel Spin (worked out from difference between Front and Rear wheel speeds) All of the data in the logs can be logged up to a 1000 times a second for proper monitoring. ![]()
#19 (permalink) |
Jm-Imports
Registered User
Updated information.
SYVECS Ltd, producers of Advanced Engine Management Solutions in the UK, are proud to announce the release of the S8 R35GTR Kit - The world’s first stand-alone Engine Management Solution for the Nissan R35GTR Over the last 12 months SYVECS has been working hard to develop a completely new product for the tuning of the Nissan R35GTR. Around the world, as the limits of the VR38DETT are pushed further and further, the last hurdle to jump has always been the OEM ECU. Now free of the restrictions that re-flashing of the stock ECU imposes, tuners can now use the SYVECS EMS to go further, push harder and take advantage of the superior control, Motorsport developed strategies and full data logging that it offers. The advanced engine management, together with a full software suite, offers unbeatable flexibility and protection to all tuning levels, safeguarding your investment, while maximising performance. The SYVECS S8 R35GTR kit is a stand-alone unit enabling the complete removal of the OEM ECU. The new unit enables live adjustment of every aspect of the engine’s calibration, while also offering the ability to control the TCM Module for adjustment of gear shift points, clutch clamping pressures, torque reduction, and much, much more! Browse through the feature list, and contact SYVECS to learn how the S8 R35GTR kit can push your vehicle to new levels of performance. Standard features - Live Tuning of every aspect of the engine’s calibration, including signals sent to the TCM and 4WD - Ability to select desired engine map, boost level, traction and launch control levels through steering wheel buttons - Fully adjustable Launch control with Anti-lag strategies and Ramp in Maps - Full Variable Valve Timing control - Closed loop Dual Lambda Control - Fully adjustable closed loop boost control with launch level adjustments and trims for turbo speed, air charge, engine coolant temp, exhaust gas temperatures etc - Monitor and trimming of exhaust gas temperatures - Built in data logging of up to 8 hours, with data rates at up to 1000hz - Pit lane limiter strategies, great for building boost on a roll - Antitheft and valet modes - Super fast connection via RJ45 Ethernet port for live tuning anywhere in the world or even remotely if on track if connected to a wireless unit - Adjustable traction control strategies based on lateral g, steering angle and/or individual wheel speed monitoring - 4 programmable and selectable target slip maps. An immediate torque reduction can be applied by the ECU via ignition retard or a fuel cut - Configurable Engine Safety Trips on all important parameters like oil temperature, oil pressure - Fuel pump control of both main, and sub pumps, as well as Relative fuel pressure monitoring and limiting in the event of fuel pressure dropping on boost - 4 different Pedal to Throttle Angle maps with multipliers for different parameters e.g. speed. Again adjustable via steering wheel buttons - Configurable individual cylinder closed loop knock control, to suit any cylinder modification with adjustments to frequency, windows for listening and gains for each cylinder. Ability to trigger full cylinder shutdown in severe knock conditions. - Ability to change torque levels or demand levels sent to 4wd unit and TCM ECU for changing of up shift and down shift points, clutch pressures and diff tightness. - Change torque reduction levels on shifts. Essential for very high power GTRs where the maximum reduction available via the stock ECU is not enough to prevent damage to components - Ability to change Torque ramp in after launch - Change throttle blip requests to match your torque band. Especially useful on oversized turbo installations. - Run up to 7bar map sensors - Control high or low impendence injectors - Control up to 12 injectors for high power installations where staged injection may be required - Change injector dead times based on voltage levels for proper control - Change injector end angle to ensure injection point is properly calibrated - Ability to fit any type of external sensor to monitor and trigger safety trips from anything from crank case pressure to damper position - Ability to use any size DBW throttle body e.g. Chevrolet LS7 - Wet and Dry nitrous control with ability to drive solenoids directly and control n20 heaters via pressure monitoring - Ability to control any external vehicle features based on sensor inputs e.g. Adjustable rear wing linked to G force or exhaust control valves - Connect any race series dash or even one of our partners’ Touchscreen CANBUS adjustment /display units - View any input live with built in scope up to 1000hz - And much, much more! The Full plug and Play kit includes 2 Lab Grade NTK Wideband Lambda Sensors and a 2.5m Loom. We specify superior Lambda sensors to improve accuracy in calibration control, as standard equipment sensors can be affected by exhaust temperature. If your interested in the Kit please email us as we are now Approved dealers. [email protected]
Bookmarks |
Thread Tools | |
