VDC settings - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 20th February 2012, 09:22 AM   #1 (permalink)
Fred is unaware they can edit their status
Fred's Avatar
Cars owned: 430 spider, Tuscan S, M3 convertible, EVO6 TME, MX5, MV F1000, Benelli LE
VDC settings
Apologies if this has been asked before, but I am trying to get to grips with the GTR. As I understand it there are 3 levels at which the VDC switch can be set to, Normal, Race, and Off.
My understanding of Race mode is:
It allows power to shift from the rear to the front - I am assuming this is similar to the set up in the R33 and R34? And that ESC is still on (which the 33 and 34 did not have).
Does this mean that in Normal mode the car is permanently in 4wd mode? If so, what percentage of power is fed to the rear?
If my thinking is right, in summary:
Normal mode: ESC on, 4wd
Race mode: ESC on, rwd, but allows power to be transferred to the front
Off mode: ESC off, rwd, but allows power to be transferred to the front, as long as you hit the gas before driving into the nearest ditch
Thanks in advance.
Fred is offline   Reply With Quote
Old 20th February 2012, 09:39 AM   #2 (permalink)
sin
sin is "living the dream"
sin's Avatar
Thanks in advance.
Normal Mode - Full Traction Control - Kicks in before limit of adhesion.
Race Mode - Traction control but allows you to go beyond the limit of adhesion for short spells before it pulls you back in line.
Off - No traction Control what so ever.
The 4wd system is active in all set ups shifting power from back to front when needed.
sin is offline   Reply With Quote
Old 20th February 2012, 09:50 AM   #3 (permalink)
Fred's Avatar
Thanks, so the difference from Normal to Race is a softening of TC only?
Old 20th February 2012, 09:57 AM   #4 (permalink)
sin
sin's Avatar
Yes, Race mode allows you some play but not too much before it kicks in.
The 4wd transfer works the same in all settings, this has nothing to do with traction control system.
Old 20th February 2012, 10:48 AM   #5 (permalink)
Fred's Avatar
Thanks Sin.
Old 20th February 2012, 04:08 PM   #6 (permalink)
Tonto_GTR is aware that a GTRRRRRRR, is a Pirates favourite car.
Tonto_GTR's Avatar
Theres no permanent 4wd. It rwd all the time, unless additional tracton is required
Tonto_GTR is offline   Reply With Quote
Old 20th February 2012, 04:27 PM   #7 (permalink)
B'have is innate Jet.
Good thread, how many drive with VDC off? I read that this can damage the transmission, is this true?
B'have is offline   Reply With Quote
Old 20th February 2012, 06:38 PM   #8 (permalink)
CT17 is probably in an R34 GT-R.
CT17's Avatar
Cars owned: A GT-R... and some others.
I'm not brave enough to drive with the VDC off!
On a track... maybe, but I'd want plenty of practice first.
CT17 is offline   Reply With Quote
Old 20th February 2012, 09:57 PM   #9 (permalink)
Anyone know if driving VDC off can damage transmission? I understand it might encourage wheel hop if launching, but for normal spirited driving?
Old 20th February 2012, 10:10 PM   #10 (permalink)
GRowsell is Gavin in the real world...
GRowsell's Avatar
Cars owned: Stage Fright R35, 440hp R34 GTT (which you should buy), Various big tractors, lots of junk vehicles,
In the summer I had traction control off 99% of the time (and would be considered to drive 'enthusiastically' ).
In the winter I have been using R mode till the tyres are warm, then when feeling brave switch traction control off.
If it's cold and wet, then I tend not to switch it off on public roads unless I'm running lower boost... because at 1.5 BAR it really is a bit too lairy (and I never thought I'd say that).
I may well have a 4WD clutch issue though, meaning it's pretty much entirely RWD... Litchfields and Nissan are looking into this currently, as I want it sorted prior to my warranty running out!!!
UK's most powerful R34 GTT 4 door Tiptronic for sale on Skyline Owners Club
GRowsell is offline   Reply With Quote
Old 20th February 2012, 10:17 PM   #11 (permalink)
MiGTR is frying his noodle
MiGTR's Avatar
Cars owned: MKII Golf VR6, Supra Big Single, E46 M3, E46 M3CSL, E60 M5, 2010 R35 GTR, 997 Turbo Tip. Currently Own: A Barge!
You read the Ring Clencher in the manual, didn't you
"Driving the GT-R with the VDC off may lead to handling issues related to steering maneuvers, acceleration, or deceleration. Moreover, driving with the VDC off can result in an inoperative vehicle by causing ser- ious damage to the powertrain, including damage to the Transaxle Assembly including Transfer, Clutch, Gears, Transaxle case and all of its components and other drivetrain"
MiGTR is offline   Reply With Quote
Old 20th February 2012, 10:34 PM   #12 (permalink)
Exactly that Mig
I wonder if anyone has killed a tranny because of VDC (or lack of it)
Old 21st February 2012, 01:31 PM   #13 (permalink)
Fred's Avatar
Isn't switching it off putting you in the same place as in a 33 or 34, where the technology was tried and tested. Not sure how much different it can be on the 35?
Old 21st February 2012, 02:16 PM   #14 (permalink)
enshiu's Avatar
As far as I know it's RWD but, can be 4WD when needed. The LSD sort it out. it can be 50:50 sometimes.
Now: R35 GTR JDM - R32 GTS4
Past: R33 GTR sgl turbo
Old 21st February 2012, 02:20 PM   #15 (permalink)
MIKEGTR is rolling on double deuces
Cars owned: Midnight Purple R33 GTR
Whats an LSD got to do with the 4wd
MIKEGTR is offline   Reply With Quote
Old 21st February 2012, 08:41 PM   #16 (permalink)
GRowsell's Avatar
Shouldn't enshiu's post come with a confusion / misinterpretation disclaimer?
Old 21st February 2012, 10:13 PM   #17 (permalink)
Hai, watashi ha konran shiterukedo Kare ha jibun no itteru koto wakatteiru to omouyo.
Old 22nd February 2012, 07:10 PM   #18 (permalink)
Still a little confused with this, so VDC off is definately a bad idea even for track use? Anyone serious about track days here?
Old 22nd February 2012, 07:34 PM   #19 (permalink)
MiGTR's Avatar
I wouldn't panic too much Charlie, it's not a Supra autobox There's quite a few guys on here and the American forums that do track days with VDC off, and I haven't read of any of them reporting a failed box because of it ( awaits someone to come along and disprove that).
There's been a few threads covering it, here's one> Click me for some traction
Now, what Mr Nissan would say if one did lunch and he checked the Flikr to see VDC off, would be another matter.
Old 22nd February 2012, 08:09 PM   #20 (permalink)
Good find, thanks Mig.
