AEM experts? R32 wont start - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 21st February 2012, 09:22 PM   #1 (permalink)
Madaxgt is unaware they can edit their status
Hi
Been having issues getting my aem to work. No help on aem forum and response from aem us is next to useless as it takes forever.
I bought a used but working aem 1623u from here. I started off with the stock nissan cas which they are meant to work with but are troublesome. I then got the specific aem disc and another cas to put it in. Following all the aem instructions i still cannot get the damn thing to start.
For people that know the system i get stat sync while cranking which stays on and the engine speed reads for a few seconds then drops to 0 while still cranking. stat sync stays on. I checked for spark but nothing but i will check again this weekend.
It starts and runs perfect on the stock ecu, all wiring been checked and both cas's worked on stock ecu.
If anybodys got any suggestions?? Its doing my f***in nut in.
Madaxgt is offline   Reply With Quote
Old 21st February 2012, 09:25 PM   #2 (permalink)
R32 Combat is in limbo
Skyline Section Manager
R32 Combat's Avatar
Cars owned: R33 GTR
I ran the standard CAS without issues.
Old 21st February 2012, 09:48 PM   #3 (permalink)
Yeah i know it should work mine doesnt! Ive checked everything starting to suspect the ecu. Be really annoyed as it was sold as fully working.
Old 21st February 2012, 10:13 PM   #4 (permalink)
tyndago is gtrusablog.com
tyndago's Avatar
Cars owned: Nismo R32, #500, and #536
Doing this from memory, but
1623 is for R34.
1621 is for R32/R33
The CAS are different. The 1 and 120 signals are swapped. You need to rewire the CAS to make it work.
Unless its rewired, it is not going to start.
Sean Morris
Old 21st February 2012, 10:31 PM   #5 (permalink)
tyndago's Avatar
R34 Wiring
R32/R33 Wiring
Sean Morris
Old 21st February 2012, 10:35 PM   #6 (permalink)
tyndago's Avatar
Look at pins 41,42 and 51,52 on each chart above.
Sean Morris
Old 21st February 2012, 11:08 PM   #7 (permalink)
Yup already done, have a swappable plug so i can quick swap to stock cas and ecu.
Any more ideas lol??
Old 22nd February 2012, 02:07 AM   #8 (permalink)
tyndago's Avatar
I've put AEM's on a ton of cars, but its been a couple years since I messed with them much. Normally when they won't start, they have something not checked in the setup.
Sean Morris
Old 22nd February 2012, 02:22 AM   #9 (permalink)
tyndago's Avatar
Do you have Pin 8 hooked up to power? Its blank on an R33/R32 and has IGN on an R34.
Sean Morris
Old 22nd February 2012, 08:49 AM   #10 (permalink)
Ah I dont think I had noticed that, I do remember there was a link wire inside the ecu but I will check if I have any wire or voltage at pin8 on my harness.
Old 8th December 2014, 11:57 AM   #11 (permalink)
GTRmuscle is unaware they can edit their status
Did you end up figuring this out? I'm having trouble getting mine to start...
GTRmuscle is offline   Reply With Quote
Old 9th December 2014, 06:57 AM   #12 (permalink)
Do you have a nissan cas wheel or the aem one? Do you have timing sync in the software while cranking? Series 1 or 2 aem?
Old 10th December 2014, 12:32 PM   #13 (permalink)
I have both cas, AEM and stock, I have tried both, had more luck with the stock. However I was told by AEM that the stock cas will not work with series 2. I'm not sure about timing sync.
I got some directions from AEM how to best sync the timing. It seems I just need to work at it more. I was curious if you fixed your problems and what you might have done.
Old 23rd December 2017, 03:09 PM   #14 (permalink)
Dk1
Dk1 is unaware they can edit their status
Same issue here anyone figure this out.
Dk1 is offline   Reply With Quote
Old 6th January 2018, 05:07 PM   #15 (permalink)
Dk1
Bump
