How to install a proper battery in a R33 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 8th April 2012, 08:35 PM   #1 (permalink)
RonniNielsen is Really wanting to drive his car again soon
We all know a battery made for a micra, just dont cut it in the skylines!
So i desided to fit a proper one in mine!
The battery i bought is the most sold battery from the company i bought it from, and was actually half price of the mirca ones so you save money aswell
I also bought 2 batteryterminals to get rid of the japanese style ones.
Comparing the batterys, the old one is the one the car left the factory with! Not bad i guess
This aint going to fit. 2 options here, go to the scrapyard, and find one that will suit, ore do as i did, and make your own. you are going to need some powertools for this.
Start by removing everything in the boot, thats in its way. mine is extra crowded from the Surgetank, along with the rearseat!
Its mutch easyer to remove the 2 back bolts on the batterytray with it out.
First remove the sitting part, 2 visible bolts, and pull up! (they can be quite stuck in the plastic clips some times. For the backrest remove thease 2 bolts eatch side, and again, pull upwards and then out.
Remove the metalcover.
Then remove thease bolts.
The front sits with a little more, all marked with red cirkels
Pull the tray out of the car, now you can see why ive pulled it out in the first place. the battery blocks half the hole for the innerstud
Oval out the hole till the battery clears.
Now for the "tricky" part to make the topbracket. ive made mine out of 2mm think steel. there it 19,5 mm between the studholes, and an additional 2 cm on eatch side. you could ask a smith just to make one with thease measurements.
Now its important to make thease bends ore other types of reinforsements, otherwise, you will simply bend it when tightening the bolts
Now the battery should bolt nicely to the tray, and you can fit the tray, and battery.
As far as the connections, DO NOT! cut the wire just before the connection, they will simply become to short to reatch the terminals.
cut them up, and extract them without shotening them
Now for the drain.
i used the plastic bit from the old battery, but i had to reverse mont it.
Heat up the rubber just a bit, and you can easy get the hose over the "big" end
I glued mine in with a bit of enginesealer.
Mount everything back together in reverse order!
I cut up a movingblanket, and made a dubblelayer on top underneath the speakercover, along with stuffing it in everywere there were open holes to the cabin. the blankes are great for sound deatening, ive used the same around the shifter, to damp noice comming trough there.
The final product. now enjoy your superchanged startermotor! this really made a differense in speed!
Ronni
RonniNielsen is offline   Reply With Quote
Old 8th April 2012, 09:04 PM   #2 (permalink)
MikeyB571 is unaware they can edit their status
MikeyB571's Avatar
Nice writeup, I may follow this at some point.
One question though, can I ask how you put the bends into the bracket you made. Looks very tidy.
MikeyB571 is offline   Reply With Quote
Old 8th April 2012, 09:25 PM   #3 (permalink)
Ive got a "bendingmachine" that can take the 2 mm plate, it makes quite a nice finish.
you could make it quite wider, and hit it with a hammer around a corner, then trim it so it only has a small edge.
Old 8th April 2012, 09:51 PM   #4 (permalink)
MikeyB571's Avatar
I suppose I will have to do it the hard way
Old 8th April 2012, 11:08 PM   #5 (permalink)
Site Admin.
Mookistar's Avatar
I don't get it? I've got a big battery in mine and didn't have to make any mods at all?
Autoguide.com
Old 9th April 2012, 09:05 AM   #6 (permalink)
samgtr is Alhumdilillah
samgtr's Avatar
Cars owned: Honda Prelude 2.2 Vtec, Nissan pulsar Gtir, BMW E39 M5, R33 GTR,
I used a small optima yellow top battery, straight fit and never goes flat.
But good on you for all the effort and how to guide.
samgtr is offline   Reply With Quote
Old 9th April 2012, 04:47 PM   #7 (permalink)
are you able to fit it up agains the edge in the back?
the problem was, that the hole the stud comes trough was halfcovered by the new battery, i could have pulled it a bit forward to clear, but i like to do things properly
You also will have to make up the new bracket that keeps the battery in place.
Ronni
Old 9th April 2012, 05:08 PM   #8 (permalink)
Site Admin.
Mookistar's Avatar
Well I've still got the small plastic tray that sits inside the metal battery tray and my 540/70 battery fits a treat. Great write up though, can't knock the job you've done.
mook
p.s. ignore the mess, see my other thread, lol
Autoguide.com
Old 9th April 2012, 05:12 PM   #9 (permalink)
There is simply no way i can ignore that mess!
Autch!
Have you had a leaking battery? ore a missing drain?
Old 9th April 2012, 05:15 PM   #10 (permalink)
Site Admin.
Mookistar's Avatar
see my other thread...
https://www.gtr.co.uk/forum/112859-ba...ics-added.html
Autoguide.com
Old 9th April 2012, 05:20 PM   #11 (permalink)
matty32 is In tokyo
matty32's Avatar
lol Mook, thats wires everywhere!
you know Ron doesnt roll like that!
Ron - i take my hat off to you Sir, you are mad for clean cars! and a talent considering your in your early 20s.
Old 9th April 2012, 05:24 PM   #12 (permalink)
clarky_gtt is get the car ready for the feature
clarky_gtt's Avatar
Cars owned: R33 GTR V-spec
same here
clarky_gtt is offline   Reply With Quote
Old 9th April 2012, 05:39 PM   #13 (permalink)
I do my very best to keep the quality as high as possible
Quality over quantity..
thanks for the kind words.
Old 9th April 2012, 05:42 PM   #14 (permalink)
Site Admin.
Mookistar's Avatar
mine will be all loveley and tidy when I'm finished
Autoguide.com
Old 15th April 2012, 01:53 PM   #15 (permalink)
Site Admin.
Mookistar's Avatar
You are gonna love this
My rotten old black tray vs. my new grey one
Same part no!!
Mook
Autoguide.com
Old 18th April 2012, 07:24 PM   #16 (permalink)
Site Admin.
Mookistar's Avatar
I'm curious as to why there are two battery tray sizes. Wonder how many people have the larger one and why some cars have one over the other?
Autoguide.com
Old 18th April 2012, 07:30 PM   #17 (permalink)
Nigel-Power is playing a Game
Nigel-Power's Avatar
Cars owned: a wheelbarrow
Glad you posted up this NielsenRonie,
The Micra battery was one of the main reasons why my car got nicked.
They drain out in no time.
Definitely need a bigger battery. How about the terminals, I guess the wires need to be elongated as well to reach the much bigger terminals of the battery.
Nigel-Power is offline   Reply With Quote
Old 23rd April 2012, 04:01 PM   #18 (permalink)
Mook, coulden it have swapped the early models, and late models?
Sure aki must know this
Nigel, no need to do anything about the lenght of the wires, as long as you "open" the old terminals, and dont cut it over at the joint.
This "mod" really made a difference on my car! no more cuffing startermotor!
An other "issue" i think ppl are experiancing, is a lot of aftermarket shit on "standby"
in my experience, cheaper alerts, wrong mounted amplifiers, are a key issue when it comes to draining batterys.
i have 0 "drag" when the car is parked, on the other hand, i havent mounted my alert ore tracker yet.
Ronni
Old 23rd April 2012, 04:24 PM   #19 (permalink)
dan-hipgrave is Gtr-less
dan-hipgrave's Avatar
Cars owned: R33 GTR v-spec
UK vs JDM? Or Series 1 vs Series 3. It'll be something along those lines.
dan-hipgrave is offline   Reply With Quote
Old 23rd April 2012, 04:27 PM   #20 (permalink)
Site Admin.
Mookistar's Avatar
mines a 1995. why would they make the battery smalleR?
Autoguide.com
