GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - What are your oil temperatures?
Old 30th September 2012, 07:03 AM   #28 (permalink)
BigKriss
BigKriss is Cruiz`n a little..
Originally Posted by Little Nismo View Post
Depends which one you mean I know one cracked the block due to a broken engine mount I don't know about others? And I am sure that drag oil temps are completely different to circuit
Uhmm, there`s a vid on the Tube where the RB30 chucks a rod ?? They comment that they did not warm the oil sufficiently before the run as a competitor had fallen out and they had to fast forward their run.
I may be wrong, secondhand info here..
Do you guys still use the std. oil/water heat exchanger in conjunction with the oil cooler ??
Wouter, you not worried that 72 deg c is too cold for oil ?? I would be a little concerned that that may be a little low..
BigKriss is offline   Reply With Quote
