Attesa pump problem and 4wd issue - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 3rd November 2012, 08:02 AM   #1 (permalink)
Guricha is Way to 600
Hello everyone,
Need help guys, two days ago i realized that my 4wd on R32 doesnot works, check everything:
fluid is new and on right level (i have usd only genuine attesa fluid)
No 4wd or abs light on dash
torque gauge is working and shows like in working condition
no error codes and no light blinking on ets controller ecu
have done next steps check and remove all cables from pump and from oil tank, in each action ecu showing errors so i think its in good condition
I realized that cant heard pump noise and i was right, during the oil bleed option pump doesnot starts at all
defending on electronic system everything is good but in real car is on rwd mode, cant find out problem and please help, only thing is left to remove attesa pump and change it i dont have any other option
any other ideas guys?
Guricha is offline   Reply With Quote
Old 3rd November 2012, 08:05 AM   #2 (permalink)
gtr-loz is cold
gtr-loz's Avatar
I think there is a fuse on the r32 might be worth checking but will prob be ok as you have power to the ecu how do you know it's in rwd?
gtr-loz is offline   Reply With Quote
Old 23rd November 2012, 12:57 PM   #3 (permalink)
heller44 is happy with 11.682 with an unopened motor..
heller44's Avatar
Cars owned: r32 gts4 with rb26dett
There is a fuse for the attessa module, in the drivers cab fuse box, and there is another one for the attessa pump motor in the engine bay fuse box. Check if you actually are getting power to the motor first on key-on.
heller44 is offline   Reply With Quote
Old 23rd November 2012, 02:38 PM   #4 (permalink)
blitzman is by the sea.
blitzman's Avatar
Cars owned: BMC & Nissan
Did the pump kick in when you connected the wire in the drivers footwell to bleed it?
blitzman is offline   Reply With Quote
Old 28th November 2012, 10:49 PM   #5 (permalink)
ore12 is unaware they can edit their status
Can you check the 4wd drive system by lifting all 4 tires off the ground and seeing if the front tires start turning when you go open throttle
ore12 is offline   Reply With Quote
Old 29th November 2012, 01:56 AM   #6 (permalink)
heller44's Avatar
Not really, with no load the front will turn just with the drag in the system.
If you can get it to a roller dyno, an easy test is to put the rears on the roller and see if the front will pull the car off.
Old 25th July 2013, 01:19 PM   #7 (permalink)
vito_lomazzo is Trying to go fast
i have same issue ?
vito_lomazzo is offline   Reply With Quote
Old 21st August 2013, 08:13 PM   #8 (permalink)
RootiMaster is unaware they can edit their status
Banned
hey he hasnt responded in a while but it will be good to know what the result was as i also have the same problem
RootiMaster is offline   Reply With Quote
Old 21st August 2013, 08:25 PM   #9 (permalink)
Rootimaster---- ECU
I found more and more of this issue and ppl switch the AWD ECU and it works
Old 16th February 2015, 10:58 AM   #10 (permalink)
kangal is unaware they can edit their status
I have the same problem
kangal is offline   Reply With Quote
