Evans cooling system - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 20th December 2012, 11:13 PM   #1 (permalink)
dinny is CLUB MEMBER
dinny's Avatar
Like to here has anybody used the non-water automotive coolant in the nissan GT-R
dinny is offline   Reply With Quote
Old 20th December 2012, 11:22 PM   #2 (permalink)
David.Yu is adjusting to life without a GT-R...
Cars owned: R35 GT-R, BMW M135i 5 dr manual, 190hp Abarth 500 (wife's)
Yes, I've been running it for a few months now. No obvious effects, positive or negative, but it was not designed to lower coolant temps, but to prevent localised boiling in hot spots in the engine as the boiling point is way higher at 180C.
Some interesting info here: Power Cool 180° - Waterless Coolant for Performance Cars
David.Yu is offline   Reply With Quote
Old 20th December 2012, 11:25 PM   #3 (permalink)
dinny's Avatar
Thanks-i was more interested in the fact it seems to be none corrosive on the aluminum. i will give it a try
Old 22nd December 2012, 09:50 AM   #4 (permalink)
alex_123_fra is now on stage 4
Cars owned: B7 RS4, B8 S4, Noble M400, Evo VIII MR FQ340, R32, E46 M3, Type-R
Seems to have quite a few benefits. Are there any manufacturers using this type of coolant in stock cars?
alex_123_fra is offline   Reply With Quote
Old 26th August 2017, 09:18 PM   #5 (permalink)
MS33 is unaware they can edit their status
MS33's Avatar
I've been using it, pleased with the results. My main concern was pressure in the cooling system, now I have none. Came back off a hard run, oil temp 102degrees C. Coolant gauge the same as before using water. And promptly removed the rad cap, no expansion at all and no pressure on any hoses.
MS33 is offline   Reply With Quote
Old 27th August 2017, 07:43 PM   #6 (permalink)
dudersvr is A Legend
dudersvr's Avatar
Anyone realise its flamable??? There were problems on the Porsche forum with guys using it, they came to the conclusion its better in older cars, cant remember problem but stopped me using it and I had it sitting in workshop.
Old 28th August 2017, 08:14 AM   #7 (permalink)
MS33's Avatar
I didn't, looked into it, and under extreme conditions the temperatures need to be higher than even those seen in malfunctioning engines and in vehicles in which the engine has been overloaded for an extended period of time.
Did you know ethylene glycol (antifreeze) has a flash point of 111 degrees C (232 F) in closed cup tests? I didn't!!
Old 28th August 2017, 10:28 AM   #8 (permalink)
dudersvr's Avatar
Brake fluid is bad as well, really any car on track should only have water it, no race car or bike has antifreeze.
