Flashing air bag light, - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Garage FAQ Members List Calendar Mark Forums Read Insurance
Like Tree1Likes
  • 1 Post By goldgtr35
LinkBack Thread Tools Rate Thread
Old 25th May 2013, 07:57 AM
goldgtr35 is Running 1026 BHP and 850 Lbs torque
goldgtr35's Avatar
As the post states, I've taken the drivers seat out and put a Tillet seat in,
Now have the dreaded flashing dash light, is there someone local can put a resister in and turn the light out please,,,
Be good if they were in the Kent area, but if not I will travel,
goldgtr35 is offline
Old 25th May 2013, 08:22 AM
Tin
Tin is modded out.
Tin's Avatar
Could it not be coded out via a consult 3? Try Sly he maybe able to help.
Tin is offline
Old 25th May 2013, 08:40 AM
goldgtr35's Avatar
I've been told not,,, needs some sort of gizmo wired in,,
Really not important just annoying.
Old 25th May 2013, 09:09 AM
You can buy from eBay in the states and then result bulb with consult or ecutek cable.
Adamantium is offline
Old 25th May 2013, 10:55 AM
Takamo is Living the Dream... Alhumdulillah (thanks to God)
GTR Register Trader
Takamo's Avatar
Cars owned: R32 GTR, R33 GTR, R34 GTR, R35 GTR and many many more!!!
If I'm not mistaken you need to link the two airbag wires using a 1k resistor which fools the system thinkingtthat the original seat is there
Rabs Car Alarms 0121 771 1511 or 07973733441
Facebook:
Official Dealers of:
Autowatch Ghost Immobiliser
Smartrack Trackers, Toad, Scorpion & Blackvue
Takamo is online now
Old 25th May 2013, 12:04 PM
charles charlie's Avatar
You should have the connector below just hanging around..
Take a 2.2ohm (ebay, maplins) resistor and push it into the connector (doesnt matter which way around it goes) and tape it up.
Resetting the airbag warning light:
You can reset the airbag warning without a CIII/Cobb/ecutek by doing this:
Turn the car ON (2 presses of the start button- DO NOT START THE CAR.... FOOT OFF THE BRAKE) and watch the airbag light (it will be on).
Immediately after it turns off, push the start button (i.e. turn the power off). Count to 5 and push the start button twice to turn the car on.
Repeat the cycle 3 times. If it works (and it will... multiple attempts may be necessary), after the third cycle, your airbag light will flash SLOWLY. This is diagnostic mode. You can then turn the car off.
Your airbag light should remain off now.
EDIT:
The passenger side requires the occupancy bladder in the seat base to swapped over to any new seat to prevent an airbag light, but the above will work for the side airbags on both seats.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
charles charlie is online now
Old 25th May 2013, 12:16 PM
Andy, is there a way to disable the passenger air bag so I can put a child seat in the front?
This is on ebay and will do the very same for you:
ebay device..
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 25th May 2013, 12:18 PM
We've chatted about this before havent we Adam?
Other than cutting wires and adding a switch in line to the Passenger Occupancy Sensor (bladder in the seat base cushion) I dont think so.
Me, I'm not too happy about messing with such important parts tbh.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 25th May 2013, 12:23 PM
goldgtr35's Avatar
Thanks for all the replays,, cheers Charle I've ordered the part of flee bay and ill follow your instruction,, thanks again for all replys,
Goldie
Ps will the air bags still work in a accident ,
Old 25th May 2013, 12:34 PM
Have we? Don't recall! Brain on its way out clearly.
I don't get why the us cars have a low weight passenger sensor and hardware to disable the airbag. Why couldn't we get that?
I wonder if I could just remove the airbag and replace it with a resistor?
Old 6th December 2014, 01:46 AM
Samopangy is unaware they can edit their status
This is helpful!
Samopangy is offline
Old 6th December 2014, 10:47 AM
EAndy is unaware they can edit their status
When fitted Recaro's to my Clio V6 had same issue, went Maplins bought a resistor for 12p and popped that in. Problem solved.
When sold car refitted existing seats binned the 12p resistor.
EAndy is offline
Old 6th December 2014, 10:56 AM
goldgtr35's Avatar
Should have put the resister on EBAY as a specillist part for a tenner.
Goldie
matthewk likes this.
Old 26th July 2016, 12:02 PM
Tony4 is unaware they can edit their status
This worked a treat thanks, cool test of reaction times too!
Tony4 is offline
Old 22nd March 2017, 09:40 PM
Black_Supra is on Highboost
Anybody know if the connectors are avilable on the market ?
Just the connector of the seat without resistor etc.
I am seaching since a long time but can`t find them.
Black_Supra is offline
Old 23rd March 2017, 11:01 AM
Tin
Tin is modded out.
Tin's Avatar
Top Secret do a airbag canceller plug & play kit.
Tin is offline
Old 23rd March 2017, 11:23 AM
They're always available mainly from Chinese suppliers of copied OEM connectors. The issue is you have to buy 500-1000 at a time!!
If you buy a 2.2ohm resistor and solder wires to each side then use scotchclips across the two wires of the OEM connection it'll work.
I could easily knock one up for you if you like?
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Rate This Thread
