Car wont start! Steering lock failure i think despite having recall - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 27th June 2013, 08:13 PM   #1 (permalink)
Nedzilla is unaware they can edit their status
Nedzilla's Avatar
As per title,just got in my car and it wont start. All was fine yesterday,all electrics are working and the battery is fine.
When the ignition is switched on the inteligent key light stays on with all the other lights and stays on by itself for about 5 seconds after the ignition is turned off.
Had a quick look at the owners manual and it points to a peoblem with the key or the steering lock. Tried the other key and same result.
What do you think chaps? Sounds like the steering lock problem to me. I had the recall done at Middlehursts about six weeks ago so a bit pissed off to say the least as my car is now stuck at the bottom of my narrow driveway f*#king up my evenings plans and probably my weekend.
Cheers.
Nedzilla is offline   Reply With Quote
Old 27th June 2013, 09:00 PM   #2 (permalink)
isub is unaware they can edit their status
isub's Avatar
Cars owned: 10' R35, stage 4, Russ Fellows system, Eibach arb's, ap & XP10's, MPSS
Ned, had the exact same problem. When it first happened it prompted me to get the steering lock recall done, which was right at the very start of the recall process.
A week later it failed to start again, took back to the dealers, no problem found.
Few days later same thing, it became more frequent, but i must add always started in the end. Sometimes after 30 mins, sometimes after 5.
Though it did become almost every other day of driving. In the end i changed the fob battery, and it has never done it again since. That was prob two months ago now.
Apparently if the fob does go flat it should still work by sticking it in the slot under the steering wheel. But this never helped when i had the starting problem.
Maybe the above may help you. My car is a my10 and had never had new fob batteries.
isub is offline   Reply With Quote
Old 27th June 2013, 09:36 PM   #3 (permalink)
KAT
KAT is back to a single turbo
KAT's Avatar
Cars owned: R35 GT-R, Evo 5 RS, FQ360, Sti, DC2, F1 R27, ML55, Shogun, A180
I had a problem when I was first taking my car out this year.
I cant remember exactly what lights were on/off but the key symbol was on and I suspected the steering lock, your problem sounds similar.
All that was wrong with mine was the battery in the tracker fob, I have never used mine so although it always clicks away I thought it wouldn't matter but it does.
It has an LED on it that has to light up when the button is pressed.
Not sure if this applies to you or no.
J
KAT is offline   Reply With Quote
Old 27th June 2013, 11:10 PM   #4 (permalink)
Nedzilla's Avatar
Thanks for the replies guys. Went out earlier and got new batteries for the key fobs and still no joy.
KAT,my tracker is also inactive and i just leave the fobs at home so i had a look at them and no LED so i changed the battery in one of them (same as the ones in the key fobs luckily) and hey presto it started straight away!!
No idea why this is either as my tracker is is also inactive but clearly its something that ALL GTR owners should be aware of!
Hopefully someone can shed some light on the issue.
Luckily my car was at home.
Anyway,once again the forum has come up trumps as i was picturing the car being on the back of a trailer in the morning and facing a hefty bill for what turned out to be a £2 albeit odd fix.
Thanx very much to you both.
Old 27th June 2013, 11:14 PM   #5 (permalink)
KAT
KAT's Avatar
Great you have it sorted, have a good blast this weekend to celebrate
J
Old 27th June 2013, 11:26 PM   #6 (permalink)
Nedzilla's Avatar
J
Thanks again,i'l treat it to a couple of tanks full of v power nitro this weekend if the weathers good!
Old 5th March 2017, 06:42 PM   #7 (permalink)
Chronos's Avatar
Cars owned: R35 Black Edition
OK just to add as I just had the none start when changing battery , as none of the above worked for me, and this is one of the threads I found when searching for help, so to forum record my funky experience, and include the fix -
It went like this -
I changed the car battery Just for a bigger spec one, and now the car won't start! Car has power, locks and unlocks fine, radio fine, just when you press the start button nothing happens, no crank at all! Put the original battery back, same issue, the key symbol stays on the dash as per picture (attached) for 5 seconds when you turn the ignition off, so swapped the key and tracker fob batteries around no joy, tried the key fob in the key slot next to the steering wheel no joy, locked the car and left it 10 mins no joy, tried the spare set of keys no joy, car has had the steering lock recall done about a year ago, called cobra tracker as I have a live subscription with them, they say all is ok their end.. new batteries in the key fob/tracker fob, no joy.
FIX - The bitch has started !!!! left the battery positive off for 5-8 mins, put it back, and it's fired up! Thanks Goldie for the tip, thought I had the dredded steering lock issue then!!
