Water collects around the boot/trunk - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > Nissan GT-R > Technical Chat
Old 5th August 2013, 10:31 AM   #1 (permalink)
cpass is GTR R35 Stock owner
Does anybody know if its normal for a small pond to form when it rains in the place where the gas struts that lift and hold the boot are located, see pictures
cpass is offline   Reply With Quote
Old 5th August 2013, 11:40 AM   #2 (permalink)
EAndy is unaware they can edit their status
Grim builds up between where the bumper join is below and blocks the channel therefore the water builds up, it still shouldn't leak into the boot however.
I use a cable tie and push between the gap and wiggle it to dislodge the grim, you'll then see the water flow free and exit out of the car by the exhausts.
EAndy is offline   Reply With Quote
Old 5th August 2013, 11:53 AM   #3 (permalink)
Brilliant, all the water has gone, thanks for the advice
Old 20th April 2014, 06:06 PM   #4 (permalink)
samdehaan is unaware they can edit their status
can you elaborate on this? push between what gap exactly?
samdehaan is offline   Reply With Quote
Old 20th April 2014, 06:15 PM   #5 (permalink)
ah sorry don't worry I've worked it out now! cheers!
Old 21st January 2018, 12:33 PM   #6 (permalink)
Chronos's Avatar
Cars owned: R35 Black Edition
Grime builds up between where the bumper join is below and blocks the channel therefore the water builds up, it still shouldn't leak into the boot however.
I use a cable tie and push between the gap and wiggle it to dislodge the grime, you'll then see the water flow free and exit out of the car by the exhausts.
Good tip thanks, all this time and I'd never noticed/heard of this!.. probably as I don't use the boot much.. Anyhow cleaned mine up and cable ties used to clear the drain slits.
Before - blocked+swimming!
After - flowing, cables ties in place as an example, then removed and kept in door basket.
