Anyone have the gtc 4 light kit fitted? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 10th August 2013, 07:19 PM   #1 (permalink)
bobbie is Stage 1
bobbie's Avatar
Cars owned: 2010 GTR
I bought one and fitted it as its just plug and play but no 4 lights light up when braking with the lights in off position, if i put side lights on the outer 2 light and the inner ones light up only when you brake, can anyone advise on this, i have emailed GTC so waiting for there reply.
Bobby
bobbie is offline   Reply With Quote
Old 10th August 2013, 07:55 PM   #2 (permalink)
Sinth is unaware they can edit their status
That is what is meant to happen. Your kit is working fine
Sinth is offline   Reply With Quote
Old 10th August 2013, 08:14 PM   #3 (permalink)
dtox is unaware they can edit their status
Does it look like this - If yes then its meant to
Tail Light Wiring Kit | Zele Performance Parts - NISSAN GT-R | Zele Performance Global Website
If you want all 4 to light up when you brake I have seen a thread about it somewhere on the internet but its not plug and play requires soldering and wire and all sorts
dtox is offline   Reply With Quote
Old 10th August 2013, 09:22 PM   #4 (permalink)
bobbie is Stage 1
bobbie's Avatar
I took the wire loom off then tested it, it made no difference put it back on still no difference, perhaps there is something wrong in the little black box it comes with, the normal running lights are side lights on means outer ones lit up when you brake the inner ones light up, with the harness fitted makes know difference reacts the same.i thought all 4 would light up with no side lights on.
Bobby
Old 10th August 2013, 09:46 PM   #5 (permalink)
David.Yu is adjusting to life without a GT-R...
Cars owned: R35 GT-R, BMW M135i 5 dr manual, 190hp Abarth 500 (wife's)
The only thing it is designed to do is light up all 4 when the sidelights or main lights are on. Only the inner two (and the high level one in the spoiler) will shine brighter under braking.
IF all 4 do not light up when the sidelights are on, then there is a fault either with the unit or the installation.
David.Yu is offline   Reply With Quote
Old 10th August 2013, 10:39 PM   #6 (permalink)
I believe this is how it should work;
Brake Lights only - No Sidelights
Sidelights only - No Brakes
Sidelights On - With Brakes On
Please correct me if I'm wrong
Old 11th August 2013, 07:34 AM   #7 (permalink)
bobbie is Stage 1
bobbie's Avatar
Nope mine do that with side lights on the brake lights are not on at all, i cannot get all 4 lights to light up with the side lights on, they only light up all 4 when you brake, there must be something wrong with the wire loom.
Bobby
Old 11th August 2013, 01:03 PM   #8 (permalink)
bobbie is Stage 1
bobbie's Avatar
There is a fault in the loom so will be sending it back for replacement.
Bobby
