-   -   Replacement of front indicators (https://www.gtr.co.uk/forum/190065-replacement-front-indicators.html)
TROGTR 21st August 2013 09:29 AM
Hi Can anyone tell me how I get to the bulbs of my R35 (front). I've taken the 2 bolts which hold the housing but they do not pop off.
HELP:mad:
EAndy 21st August 2013 09:33 AM
Easiest way is to turn wheel, jack car up, removing arch liner and hey presto full access to the indicator bulb.
Pain I know but if you find another way let me know :D
charles charlie 21st August 2013 10:11 AM
HELP:mad:
You cant removed the headlamps without removing the bumper so dont try!
Access for the main bulbs (except the sidelights) are best achieved as Andy says above.
TROGTR 21st August 2013 11:20 AM
Many thanks lads.
What a pain!!!!
How would I access the side indicators?
_shaun_ 21st August 2013 11:31 AM
Originally Posted by TROGTR (Post 1920161)
Many thanks lads.
What a pain!!!!
The side indicators (on the fenders) should just "pop" out but be careful as they bracket that hold it in can break easily.
TROGTR 21st August 2013 06:56 PM
Another question, I've just got some rear indicator leds, but they are flashing twice as fast now, I gather i need to change the flasher relay with an LED one, where the hell is it??? and will this work???
Tom
Swobber 21st August 2013 07:05 PM
What about leds with built in resistors, also called leds for Can-bus etc...
TROGTR 21st August 2013 07:13 PM
I've bought the leds with the can-bus but still flashing faster.:confused:
charles charlie 21st August 2013 07:59 PM
You need to place resistors in line with the indicator feed as the power draw is less thus the car thinks the bulb is blown.
I used a pair of these
You need to place them in parallel using scotch clips on wire no 1 on each lamp connector.
Wire number 1 is the top left wire as you look at the connector form the rear.
Passenger colour is white
Driver side colour is yellow
I did this 3 years ago so I hope this info is correct!!
TROGTR 22nd August 2013 07:37 AM
Many thanks Charlie.
So I have to place it in series! This means I have to cut the wire and then connect the resistors in line to be in series. I'm just bait nervous to cut it......what happens if it doesn't work?!
charles charlie 22nd August 2013 08:31 AM
Sorry bad choice of words!
I think I spliced mine in parallel.
Iggy GT-R 18th June 2014 09:15 AM
I want to replace the OE orange indicator bulbs, for a cleaner look.
How difficult is it to get the arch-liner off & is access easy enough once removed?
I would've liked to go the LED route, but with the hassle of splicing resisters.... I'll get a set of Phillips Silver Vision - Philips Silver Vision PY21W (581) Styling Indicator Bulbs | PowerBulbs
Iggy
Iggy GT-R 25th July 2014 03:36 PM
Anyone?
I'm going to be having a go after the weekend!
