ATTESA Rapid start pressure demonstration - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree3Likes
Old 12th September 2013, 08:09 PM   #1 (permalink)
R32 Combat is in limbo
Skyline Section Manager
R32 Combat's Avatar
Cars owned: R33 GTR
A while ago I fitted a pressure gauge to the R32 GTR ATTESA actuator cylinder on the rear of the transfer box. This was done as part of the Skylab Fusion development. If quickly became apparent what the ATTESA rapid start feature was all about and that hydraulic pressure and the torque split gauge didn't show the same thing.
I have mentioned before that between 0 and 20kph the ATTESA hydraulic pressure is proportional to TPS.
I have just fitted a gauge to a R33 GTR and video'd this feature.
It's also worth noting that the R32 has 0 psi line pressure at rest and the R33 GTR has 25 psi.
To do this test, i unplugged the TPS and plugged in a spare one so I could easily increase the TPS voltage without annoying the neighbors too much but revving the engine.
I started the engine, notice how the pressure drops from 85psi to 30 psi. The pressure rises when the engine is turned off. Perhaps to assist the handbrake?
I then turned the TPS to max and back to 0. The laptop shows the TPS voltage and the gauge shows the line pressure. All the time the torque split gauge showed nothing.
Old 12th September 2013, 08:16 PM   #2 (permalink)
fourtoes is milk monitor
fourtoes's Avatar
That's wicked that is Andy!
Bob
Like us on Facebook ZEALOU5 turning cars into heroes.
ZEALOU5
Please Whatsapp me on 07970699470.
(^^^best way to get in touch tbh^^^).
Contact: Bobby Proctor
Mobile: 07970699470
Website:
Email:
Old 12th September 2013, 08:59 PM   #3 (permalink)
Following EJH#25
matt j's Avatar
Well done Andy, does that mean the fittings are now available as I'd like to put a sensor in to send the pressure to the motec?
Old 12th September 2013, 10:19 PM   #4 (permalink)
Conrad is taking a break from cars...
Cars owned: AE86.... Sometime in the future
Nice work Andy, I wonder if the torque split output only goes to the gauge once the ATTESSA ECU detects wheel speed?
Conrad is offline   Reply With Quote
Old 12th September 2013, 10:47 PM   #5 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
They are all turned and heli coiled (12 off). I've not milled the hex on them or drilled/tapped the 1/8 npt holes yet.
I wanna run for a few days and check for leaks etc.
Old 12th September 2013, 10:48 PM   #6 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
You are right, but I wonder why.
Old 12th September 2013, 11:12 PM   #7 (permalink)
Following EJH#25
matt j's Avatar
What's the voltage to the centre torque gauge again Andy? 0-5v?
Old 12th September 2013, 11:15 PM   #8 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
I think so, I'll have a dig around tomorrow to confirm.
Old 12th September 2013, 11:35 PM   #9 (permalink)
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
Very cool stuff.
Old 13th September 2013, 07:59 PM   #10 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
.5-4.5v ideally. Gauge will run either PWM @ 5v or analogue 0-5v.
Basically, fit a .5-4.5v 0-300psi sensor in the adaptor, cut the wire on pin 50 of the ATTESA C/U. Wire the output of the sensor to the gauge and you will have a reading of sorts.
Old 13th September 2013, 10:09 PM   #11 (permalink)
yahoo1 is unaware they can edit their status
Just out of curiosity, is the atessa driven by a pump or how does it make pressure exactly? An actuator in a cylinder or some such system?
yahoo1 is offline   Reply With Quote
Old 13th September 2013, 10:54 PM   #12 (permalink)
Cool
It would appear that torque split is more than just a % of the pressure range for clamping pressure to the transfer box, is there some form of load cell in there?
Old 13th September 2013, 10:58 PM   #13 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
There are no load cells, what do you mean?
Old 15th September 2013, 06:03 PM   #14 (permalink)
Ignore me that doesn't make sense, I was thinking the gauge reads torque which needs a load cell or torque arm rather than torque split which is just % of clamping pressure. Ignore me, I was having a moment
Old 15th September 2013, 06:14 PM   #15 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
The gauge reads in kg/f not %.
Old 15th September 2013, 06:16 PM   #16 (permalink)
Corsa1 is unaware they can edit their status
Corsa1's Avatar
But your an Evo man lol
Corsa1 is offline   Reply With Quote
Old 15th September 2013, 07:07 PM   #17 (permalink)
A bit of everything Andy, if it has an engine I'm on it
Old 15th September 2013, 07:11 PM   #18 (permalink)
Yes.. Force applied which must be derived from the pressure applied to the transfer case hydraulically.
Old 15th September 2013, 07:28 PM   #19 (permalink)
R32 Combat's Avatar
Cars owned: R33 GTR
I am looking pressurising the system and putting a torque wrench on the front wheel output and seeing how accurate it is.
Old 15th September 2013, 07:31 PM   #20 (permalink)
Yeah that would be interesting, theoretically if you know the pressure and the area it is being applied to (transfer clutch area) then it could be calculated and compared.
I will be interested in seeing the results Andy.
