R35 GTR Transmission Upgrades - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > Vendors > Vendors Index > AC Speedtech
Old 17th October 2013, 07:38 PM   #1 (permalink)
ACspeedtech is getting bigger and faster!
GTR Register Trader
The GR6 transmission, although very strong and capable does have a few issues. We have available upgrade parts from ACspeedtech that can prevent and repair the minor problems that account for around 99% of the issues that trigger various transmission faults:
Front Circlip retainer
Well noted is the issue with the front circlip either coming adrift from the circlip groove or with the repeated shock loading actually wiping the whole groove off the end of the shaft leaving no possibility of holding a circlip on at all. There are quite a few designs of retaining the circlip, the design we use covers the circlip stopping it from opening up, but also clamps into the end of the shaft re-enforcing it and preventing total damage to the circlip groove itself. It is also 'balanced' and will not cause any issues with vibration/resonance that may occur with some 'clamp' designs and also does not rely on the existing circlip groove which we have seen failure of. To date we have not seen failure of any of the other circlips in road or circuit use, so we cannot recommend upgrade of them. Requires transmission removal to fit. RRP £100+vat per car set
Gear stopper kits
Over selection of the gear by the shift forks repeatedly impacts the sleeve on the stops on the gear. Fitting this kit repairs issues with and prevents further damage to the stops by limiting the shift fork travel. Made from a specific nylon designed and tested to be impervious to the aggresive transmission fluid. As a nice by-product, the nylon also feels to dampen and smooth the shift too over the factory metal-to-metal setup. Fitted into the solenoid pack without transmission removal. RRP £150+vat per car set
Piston clips
As the shift forks are actuated by the shift pistons, the square edges of the shift piston wear off, this allows the piston to rotate which in turn allows the magnets in them to rotate which then go out of range of the mag sensor and the TCU cannot 'see' where the shift piston is triggering a fault. These piston clips work by increasing the size of the locating area stopping the piston from rotating and solving the issue. They are also made from steel which will not wear the same as the soft alloy shift piston stopping future issues. The design is similar to the factory Nissan upgrade which unfortunately is NOT available to the end user from their parts departments. There is another design available which is formed from simple steel channel which we bypassed due to it's poor retention ability. Fitted into the solenoid pack without transmission removal. RRP £80+vat per car set
GR6 Upgrade Kit
We can supply these kits individually, or can supply as a kit with all 3 of these parts to prevent and repair against the vast majority of issues you may find with this transmission in a 'per car kit'. OFFER PRICE £288.75+vat
This is available with just the Piston Clip Kit and the Gear Stopper Kit for an OFFER PRICE of £201.25+vat
We can also supply the Pentosin FFL-4 or FFL-R in 10 litre containers for individual per-car servicing/upgrades.
We find that these transmissions create quite a lot of debris during the first few thousand miles of use which can clog up the magnets in the sump pan. The first time the pan is removed will look the worst, after the first clean, you won't see the same levels of deposits on the magnets if examined at a later date.
Please call us on: 01925 830889 (if we're busy in the workshop please send an email!)
Email us at:
Visit us at: ACspeedtech, 3C Trident Ind.Park, Birchwood, WA3 6AX.
EcuTek MASTER Tuner - COBB PROtuner - 6T9 - KW suspension - SuperPro Bushes - OZ Racing - Millers Oils - AP Racing - Arai Helmets - Corbeau Seats - Luke Harnesses
ACspeedtech custom GR6 gearbox upgrades - GR6 transmission repairs and solutions
ACspeedtech is offline   Reply With Quote
Old 20th January 2014, 06:32 PM   #2 (permalink)
ifty is Enjoying ownership of the
BOSS
ifty's Avatar
Cars owned: SVM Built Torque Monster
Good prices, well worth doing gives me something to think about when my car comes out of hybernation
ifty is offline   Reply With Quote
Old 21st January 2014, 11:42 AM   #3 (permalink)
GTR Register Trader
Thank you We make the upgraded parts ourselves so keeps the cost down for everyone. Gear stoppers and Piston clips are a common upgrade to be done at service time while the transmission fluid is being dropped already.
Coming soon will be upgraded shift forks, available individually (i.e. replace the troublesome 1st/reverse snapped one) or a full upgraded set. Will bring a much firmer and reliable shift feel as well. That should complete the catalogue for fixing/repairing/prevention of issues with these transmissions.
Email us at:
Old 12th March 2014, 11:51 AM   #4 (permalink)
safcjo is there are fast cars then theres GT-Rs
is there a filter to change when doing the oil
safcjo is offline   Reply With Quote
Old 14th August 2014, 08:39 PM   #5 (permalink)
Hugh Keir – PTSYS is getting old
Single Product Trader
Hugh Keir – PTSYS's Avatar
Cars owned: R32 GTR Race Car
Would like to know a bit more about gearbox filters, can see that a couple of companies offer filter upgrades and have seen some threads talking about cleaning the gearbox filters.
Is there a good source for the available options?
Thanks
Hugh
DSC Sport equipped R35 launching at TOTB
name="wmode" value="transparent"> To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
type="application/x-shockwave-flash" wmode="transparent" width="425" height="350">
Hugh Keir – PTSYS is offline   Reply With Quote
Old 24th September 2015, 07:28 AM   #6 (permalink)
Gearbox filter
Dodson offer the filter and pan filter. £300 litchfields are Uk dealers
Old 24th September 2015, 01:22 PM   #7 (permalink)
GTR RGT is unaware they can edit their status
GTR RGT's Avatar
Cars owned: R34, R35, Defender, Supra
Imo I'd prefer the nissan OEM filter to replace once in a while.
GTR RGT is offline   Reply With Quote
