-   Skyline and Stagea "How to" and DIY guides (https://www.gtr.co.uk/forum/skyline-stagea-how-diy-guides.html)
-   -   Ps resevoir relocation (https://www.gtr.co.uk/forum/212554-ps-resevoir-relocation.html)
bignath4607 11th November 2013 08:59 PM
Hi guys i didnt have time to look today so i test fit my
New manifold n turbo and il have to relocate the power steering resevoir do many have to do this, if so where is the favoured spot.
Any suggestions welcome oh r33 btw .
Regards
Nath
bignath4607 12th November 2013 07:57 AM
Come on someone must of had to do this ?
Brains 12th November 2013 09:12 AM
I think mine is moved. Aren't they normally placed on the strut?
Mine is sat behind the front light.
bignath4607 12th November 2013 10:18 AM
Yeah thats where i detached it from i was thinkin behind the passenger side light actually dont suppose you have a pic brains
Brains 12th November 2013 10:29 AM
I can get a picture for you in a while . Doesn't r32 have it there?
bignath4607 12th November 2013 10:36 AM
Im not sure tbh ive looked in so many engine bays but never paid attention to the ps location
AlexJ 12th November 2013 10:53 AM
Mine was moved to behind the headlight, the bracket is attached to the cross member/slam panel.
Beware when you re-route the hoses the swaged ferrules where the hard pipe meets the hose don't like being moved and will probably leak once they are disturbed.
bignath4607 12th November 2013 11:03 AM
Thanks alex il probably replace the pipes too
mambastu 12th November 2013 11:30 AM
I'm doing this on mine too. I've already cut off the swaged rubber hose that goes between the return line from the rack and the bottom of the resevoir. I assume as its low pressure you can just use a hose and jubilee clip instead ?
Will probably shorten the R32 PS pump and use a plastic R33 resevoir.
Stu
Austrian GTR 12th November 2013 11:51 AM
I made up my own PS reservoir and used the bracket for the stock carbon canister :thumbsup:
http://i1002.photobucket.com/albums/...1/IMG_1399.jpg
HTH
Leo
bignath4607 12th November 2013 12:10 PM
Thats a good shout looks well
mambastu 12th November 2013 12:22 PM
Yes, great idea. Took it off years ago, wonder if I've got the bracket still !
Stu
Skeeed3r 12th November 2013 12:23 PM
i have an AutoSelect one, same place as leo :smokin:
AlexJ 12th November 2013 12:58 PM
Stu
Abbey did the work on mine, they tigged an aeroquip fitting on the back of the standard fitting at the rack and ran a new hose the whole way back replacing that return hard pipe. As you say being the low pressure side, you'd think a jubilee clip would do it just as well though - it's a jubilee clip at the reservoir after all.
synistrGT-R 13th November 2015 08:06 PM
2 Attachment(s)
I just finished relocating mine on my R33. I removed the charcoal canister from the bracket, cut the mounting tabs off the power steering reservoir, TIG welded the 2 together, ran new braided lines, filled the system and finished project.
