My 2p's worth.
Given what you want is little more than a few ancilliaries and some boost then it may be more pertinent to look at this geographically, as most the good tuners should be able to accomplish what you want without any kind of problem.
You may want to consider things like what ecu access you use for future mods (and trust me, even if you dont think it now there almost certainly will be future mods lol) - lots of people have gone ecutek only to then decide that syvecs gives them other features further down the line thus wasting a couple of thousand for example. This may have some bearing on who you get to do the work or map it.
You may want the added security a big tuner like SVM or Litchfields give as far as warranty goes, or maybe get the work done via Middleshursts or an HPC with a tuner affiliate that then has Nissan warranty backup.
Also think about gearbox and other software and whether you have had any of the known faults and recalls all done before starting mods so there can be no finger pointing when turning up with a genuine problem and a now recently modded car.
J.
