R32 gts4 needs help - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 27th November 2013, 06:48 PM   #1 (permalink)
hnr32gts4 is unaware they can edit their status
R32 gts4 needs help
hi guys, im new on here so please be nice to me,
i purchased my skyline r32 gts4 over a year ago, and now it has developed a problem, when you drive the car it drives perfect and engages the 4wd as it should when it needs to, but after about 10 miles the car will start to judder/jerk when the the 4wd is engaged. i checked the attesa ecu and it flashes 18 times, i found a earth strap perished which came from the attesa pump to the chassis, i have replaced the earth strap but the car still judders/jerks in 4wd, after changing the earth strap the attesa ecu does not have any faults codes flashing, when i take the 4wd fuse out it will drive perfect without the 4wd, this is my 5th r32 and second gts4 and i have never had this problem before, can someone please help
hnr32gts4 is offline   Reply With Quote
Old 24th December 2013, 10:20 PM   #2 (permalink)
monkichi is building 1000+ hp
monkichi's Avatar
Cars owned: R35 GTR, V6 Turbo Cedric, Rocketbunny S13
I have simillar problem with my R32 GTR. All grounds ar good, no fault codes, but car jerks when im driving it slowly or maintaining steady speed. Torque needle jumps around from 8 to 10 from 8 to 10 and so on. Once, but only once it jumped from 0 to 10 and back.
What could it be? I have used search in here and google, a lot of people have problem like this, but they have fault codes. I have no codes. Please help?
Transfer case on its way out or G sensor dead?
monkichi is offline   Reply With Quote
Old 9th February 2014, 08:24 AM   #3 (permalink)
bump, someone must no whats wrong
Old 9th February 2014, 11:26 AM   #4 (permalink)
monkichi's Avatar
I think i found problem what could causing this to me. After some deep research in forums i think its my Attesa accumulator. This is nitrogen filled bottle which sits together with attesa pump and helps to maintain pressure.
Turn on you 4wd system (fuse back on or switch, whatever you have), and let the car idle for a while. Open your trunk, put your head inside and stay like this for at least 5minutes. Try to hear clicking relay noise at the rear. If its clicking really often (like few times in a minute or 2 minutes). Then your nitrogen filled bottle is getting empty and attesa pump is engaging too often, because it have to maintain pressure.
Also a question does your 4wd funktion properly when you floor it?
Old 9th February 2014, 11:28 AM   #5 (permalink)
monkichi's Avatar
Could someone move this under maintenance? It think its in wrong section.
Old 1st March 2014, 07:12 AM   #6 (permalink)
i changed the brake pads, and 2 new tyres on the rear and the jerking/jeddering has stoped
Tags
attesa 4wd skyline r32
