Intelligent key issues - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 1st December 2013, 03:42 PM   #1 (permalink)
legowyn is trying not to spend too much on upgrades
Cars owned: Audi A3 Sportback Black Edition; Mercedes A180 Sport; MY09 GT-R R35 Gunmetal
I've been having some issues with my intelligent key recently and wondered if anyone had any thoughts as to the cause. Sometimes the car doesn't recognise the key, so the car won't open or shows the yellow key warning, but it is very sporadic - sometimes the door won't open but once you are in it recognises the key, or the door opens but it won't start without the key in the slot. Yesterday I went to get fuel but couldn't as the filler flap wouldn't unlock!
Changed battery in key for a brand new one, which has helped a bit but it still does the same thing. Car battery itself is almost new as well and charged regularly. Sterring lock recall has been done already.
Any ideas/anyone had similar issues?
Thanks
legowyn is offline   Reply With Quote
Old 1st December 2013, 03:48 PM   #2 (permalink)
sw20GTS is feeling the need for more powerrr
sw20GTS's Avatar
Cars owned: Currently Audi Q7 and GTR Black Edition
I was going to say check batteries or steering lock but seems you've got that covered.
Dodgy key fob perhaps? Have you tried the spare key to compare?
Kuro Black GTR - Milltek Non Res Y Pipe - Litchfield Stage 1 - 2012 Gearbox Upgrade - Litchfields 4 light kit - Litchfields Reverse Camera - Litchfields Warranty - MPSS 275/305 OH YEAH
sw20GTS is offline   Reply With Quote
Old 1st December 2013, 03:57 PM   #3 (permalink)
Thanks, yes tried spare key, albeit without a new battery in it, and same issue.
Old 1st December 2013, 04:03 PM   #4 (permalink)
sw20GTS's Avatar
I had the same symptoms turned out to be steering lock failing which I've replaced. The only other time this would happen is when the battery is low - but I keep it charged whenever I can with CTEK (cold weather drains the battery a lot!).
Try new batteries in the spare fob to see if it makes any difference?
Old 1st December 2013, 06:18 PM   #5 (permalink)
Tin
Tin is modded out.
Tin's Avatar
Wild guess... anything new recently fitted of a wireless nature? could be something interrupting with the bluetooth freq? Does it happen always in the same place?
Old 2nd December 2013, 08:51 PM   #6 (permalink)
no, nothing new fitted and happens in different places - only new thing is a new battery pit in the car around 4 weeks ago but wouldn't have thought that would cause any issues, and it's been happening on and off for a while. Might need to get the key checked out.
Old 2nd December 2013, 09:50 PM   #7 (permalink)
Glennyboy is Balancing emissions by also having an electric car
Cars owned: R35, Clio 182, 911C4 cab, Boxster, Pulsar Gti-R, 306 gti-6, Rover 220 turbo, 205Gti x4, Renault 19 16v
My bet is its something to do with the cobra tracker that's fitted. I disconnected the car battery on mine to join up some ctek permanent leads so I could charge the car without having to lift the bonnet every time, and it reset the tracker (even though it wasn't activated/subscribed at the time) and had to then play around with the tracker fob to get things working again and get rid of the yellow key light. Although I don't think that wouldn't explain the getting in and out of car as mine still locked/unlocked.
Glennyboy is offline   Reply With Quote
Old 5th December 2013, 07:09 PM   #8 (permalink)
MickB is unaware they can edit their status
Cars owned: 350Z
I have same problem. Rarely works first time when I walk up to car. Sometimes have to press key to unlock car. I think its the car sensor rather than the key fob as spare key is same even with new batteries.
MickB is offline   Reply With Quote
Old 10th December 2013, 08:06 PM   #9 (permalink)
Does anyone know where the sensor is, and any thoughts as to cause of sensor issues? Could also be tracker, as suggested, so that is worth exploring further as well.
Old 10th December 2013, 08:43 PM   #10 (permalink)
R35 Section manager
TREG's Avatar
Cars owned: R 35 GTR
I'm sure I read recently that someone had a similar issue and it was a low battery in the tracker fobs even though the tracker wasn't being used?
