-   -   Clicking front wheels (https://www.gtr.co.uk/forum/218081-clicking-front-wheels.html)
stixGTR 2nd December 2013 09:36 PM
I've had an intermittent clicking sound coming from the front wheels ( cv joint sort of noise ) but its got worse since the last track day on Saturday.
any pointers or quick fixes would be really appreciated.
Thanks in advance
Ja5on 2nd December 2013 09:38 PM
Remove both front wheels and put them back on. When putting them back on torque up to
145nm
15delux 2nd December 2013 09:44 PM
Just had this sounds like a creak.... Cleaned and refitted and now perfect
stixGTR 2nd December 2013 09:56 PM
so just a simple take off clean and refit.
I read somewhere about using copper grease on the backs of the wheels - any point in this or is it just a crazy idea that someone had.
also been torqueing up to 150Nm - is this too much ?
Mookistar 2nd December 2013 10:02 PM
There's a sticky about this somewhere
stixGTR 2nd December 2013 10:09 PM
I thought there might be but I cant find it
Ja5on 2nd December 2013 10:14 PM
150 should be fine. I torqued the wheels to 150 for a sprint.
Mookistar 2nd December 2013 10:17 PM
https://www.gtr.co.uk/forum/164792-cl...light=Clicking
Trevgtr 3rd December 2013 01:18 AM
3 Attachment(s)
The problem is actually the hub to disc (bell) surfaces, not the wheel to disc surfaces (that only works short term as you're squeezing the hub to disc when retorquing wheel nuts).
I did mine a couple months ago and have been silent since, they were clicking like crazy esp on LH lock before. Remove disc bell, clean surface rust on bell and hub, grease, refit = silent. :)
stixGTR 3rd December 2013 03:58 PM
Cheers Trev.
That sounds like a straightforward job as I need to put my road pads back in, so I'll give her a good scrub and clean out whilst the wheels are off
dominic1 3rd December 2013 04:17 PM
it sounds like your wheels are going to fall off !!
not good
Nedzilla 3rd December 2013 05:10 PM
Mine were clicking like crazy and i did mine this january when i changed my tyres. Cleaned disc and wheel faces,applied a bit of copper grease to both faces and torqued to 145n/m and have not heard a single click since so not sure if removing the disc is really necessary.
Trevgtr 4th December 2013 01:01 AM
3 Attachment(s)
Yes it is Ned, the rust when you remove the disc is plentiful, yours will probably come back quite soon. I had the wheel to disc surfaces cleaned and greased at the last service and yes it did stop the clicking, but only for about 1k miles. I then did the proper fix and it's been silent since. :) I guess it could be a combination of both (makes sense) but IME the disc to hub was the fix.
