GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - Ps resevoir relocation
Old 12th November 2013, 10:30 AM   #9 (permalink)
mambastu
mambastu is looking forward to fork lift powah !
mambastu's Avatar
Cars owned: TH1 R32GTR, Ex-RB25DETT RS13
Originally Posted by AlexJ View Post
Mine was moved to behind the headlight, the bracket is attached to the cross member/slam panel.
Beware when you re-route the hoses the swaged ferrules where the hard pipe meets the hose don't like being moved and will probably leak once they are disturbed.
I'm doing this on mine too. I've already cut off the swaged rubber hose that goes between the return line from the rack and the bottom of the resevoir. I assume as its low pressure you can just use a hose and jubilee clip instead ?
Will probably shorten the R32 PS pump and use a plastic R33 resevoir.
Stu
Stu
mambastu is offline   Reply With Quote
