GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - Ps resevoir relocation
Old 12th November 2013, 12:58 PM   #14 (permalink)
AlexJ
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
Originally Posted by mambastu View Post
I'm doing this on mine too. I've already cut off the swaged rubber hose that goes between the return line from the rack and the bottom of the resevoir. I assume as its low pressure you can just use a hose and jubilee clip instead ?
Will probably shorten the R32 PS pump and use a plastic R33 resevoir.
Stu
Abbey did the work on mine, they tigged an aeroquip fitting on the back of the standard fitting at the rack and ran a new hose the whole way back replacing that return hard pipe. As you say being the low pressure side, you'd think a jubilee clip would do it just as well though - it's a jubilee clip at the reservoir after all.
