HELP NEEDED: Ignition stuck on lock position - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 21st December 2013, 06:02 PM   #1 (permalink)
dumdum is unaware they can edit their status
I dont think its a battery issue key seems to lock and unlock the car fine, but once in the starter button wont move from lock position not even to acc (with or without foot on the brake), has this happened to anyone before or anyone know a fix. I'm off home to try the spare key see if that works but failing that I'm out of ideas?!
Any help appreciated
dumdum is offline   Reply With Quote
Old 21st December 2013, 06:05 PM   #2 (permalink)
Nedzilla is unaware they can edit their status
Nedzilla's Avatar
Is the yellow key light showing up on the dash?
Nedzilla is offline   Reply With Quote
Old 21st December 2013, 06:06 PM   #3 (permalink)
grahamc is loving the GTR!!!
grahamc's Avatar
Cars owned: Nissan GT-R35; Mazda MX5 supercharged; Ford Escort Mk1; Datsun 240z
Gearshift in Park?
grahamc is offline   Reply With Quote
Old 21st December 2013, 06:06 PM   #4 (permalink)
No its not, i tried putting key in the intelligent key port to see if anything and nothing came up there either
Old 21st December 2013, 06:07 PM   #5 (permalink)
RichF-R35 is unaware they can edit their status
RichF-R35's Avatar
Cars owned: Saphire cosworth, Evo6 TME, GT-R R35
Try shaking the steering wheel firmly
RichF-R35 is offline   Reply With Quote
Old 21st December 2013, 06:08 PM   #6 (permalink)
Yep gearshift in park, i assumed it wouldnt go into lock position unless in park but double checked that also. Sly just recently changed the battery in my key fob at the last service 3 weeks ago, so i doubt its that battery but im going to go home and change it anyway to be sure
Old 21st December 2013, 06:09 PM   #7 (permalink)
grahamc's Avatar
What year is your car?
Old 21st December 2013, 06:11 PM   #8 (permalink)
Nov 2009 (59 plate)
Old 21st December 2013, 06:12 PM   #9 (permalink)
Nedzilla's Avatar
I had similar problem a while ago and it turned out to be the batteries in the tracker fob. It was a strange one but im not the first person its happened to.
Old 21st December 2013, 06:14 PM   #10 (permalink)
thats interesting i have tracker on the car, but i don't have a fob at all. never been sent one, it was already installed on the car when i got it and i just renewed the membership when i took over ownership
Old 21st December 2013, 06:16 PM   #11 (permalink)
Nedzilla's Avatar
I take it its not the nissan factory fit cobra tracker then?
Do you know if it has had the steering lock recall done?
Old 21st December 2013, 06:17 PM   #12 (permalink)
ROG350Z is Nismo
GT-RDC Founder Member
ROG350Z's Avatar
Cars owned: GT-R R35 Spec V, GT-R Nismo, Zenos E10R
I had this the other week in a car park in Liverpool. You try to start and nothing at all happens right even though you can get into the car? You haven't got a tracker and then not bothered renewing have you? Does dashboard light up but the car won't start?
I was in a car park with no mobile signal so the car (for no reason) disabled itself and the fix is to dismantle the passenger footwell by the door hinge and remove the tracker fuse(s) depending on model. Leave for ten minutes then reinsert then it starts.
Mr Litchfield and his team were amazing as always as I had to keep running out of car park and send photos for advice then back in (I was in Liverpool so had to explain to everyone why I was in a suit, head first upside down in my footwell stealing my own car).
ROG350Z is offline   Reply With Quote
Old 21st December 2013, 06:31 PM   #13 (permalink)
Thanks ROG, i'm going to give that a try, seems to make the most likely option.
When i bought the car i didnt realise it had a tracker on it until Tracker themselves called me up and asked me if i wanted to take over subscription which i have but not received anything following.
I'm going to look for this fuse in the passenger footwell
Old 21st December 2013, 06:47 PM   #14 (permalink)
ROG350Z is Nismo
ROG350Z's Avatar
No problem. Start with removing the foot kick plate door plastic from rear of door forward then the plastic element which curves round inside footwell and carpet. Fixed in which some tabs which unscrew if I remember correctly.
Once you get this out then the fuses are in a bundle (might be electrical taped together) and you might need long nosed pliers to get the fuse out. The tracker one should be relatively obvious as the 'odd one out' if Cobra then I think there is only one but apparently some have two. Mine was yellow if that helps.
Wait ten minutes then reinsert and try engine.
Good luck! Don't do it in the dark.....
Old 21st December 2013, 06:55 PM   #15 (permalink)
Johnny G is here. Hi!
Johnny G's Avatar
Cars owned: Nissan GT-R, BMW 730d, BMW 535d
Hehem!!
Johnny -
2017 GT-R - Daytona Blue, Recaro Edition - Litchfield Stage 4.5, Alcon BBK: 754bhp, 642lb/ft
Johnny G is offline   Reply With Quote
Old 21st December 2013, 07:28 PM   #16 (permalink)
charles charlie's Avatar
Damn Rog. Me and Johnny could have come to where you were stranded.
And laughed our tits off at you.
RF street zorst+DPs
RacingBrake BBK
DSC susp controller
Old 21st December 2013, 07:36 PM   #17 (permalink)
ROG all i could find in the passenger footwell was this, nothing yellow there and wasnt sure what to take out, nothing obviously stood out as being different.
Any suggestions?
Old 21st December 2013, 11:24 PM   #18 (permalink)
Nickgtr35 is Looking forward to the sun
Nickgtr35's Avatar
Cars owned: GTR 35,Volvo XC70, Vauxhall Corsa S ecoflex
Heard something that this may be related to a steering lock failure, but could be wrong! 2009 models have had steering lock problems, do you know if yours has been updated?
Nickgtr35 is offline   Reply With Quote
Old 22nd December 2013, 12:29 AM   #19 (permalink)
No mine hasnt been fixed, I hope that isnt the case as the thought of taking my car to Nissan makes my skin crawl i have only had to speak to Nissan once in my 3 years of ownership and they wanted to charge me 145 to rest my TMS sensors after i had a flat tyre and repaired it myself - i knew then i would only get it serviced by Sly/Iain.
I'm going to go back tomorrow during the day and take a closer look and if nothing I will wait for Sly to get back to have a look.
Old 22nd December 2013, 08:00 AM   #20 (permalink)
R35 Section manager
TREG's Avatar
Cars owned: R 35 GTR
If it is a steering lock issue Nissan would of fixed that for free!
I suspect it is that.
