850bhp/750ft lbs - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 24th February 2014, 05:57 PM   #1 (permalink)
vxrcymru is a carbon fetishist
GT-RDC Founder Member
vxrcymru's Avatar
Cars owned: R35 GTR Stage 5 & Evo X FQ400
850bhp/750ft lbs
What are the standard gearbox and clutch upgrades recommended to safely handle this level?
For road, occasional launch and track use only, No drag-strips
Black MY2010 Black Edition, Litchfield Stage 5 - Switzer P800 turbos, Litchfield suspension, Alcon 400mm front and 380mm back discs with Pagid pads, circlips, front and rear cameras, auto folding mirrors & lots of CF. Advan RSD wheels!
vxrcymru is offline   Reply With Quote
Old 24th February 2014, 06:24 PM   #2 (permalink)
R35 Boxer is loving the MY17 LM900!
R35 Boxer's Avatar
Cars owned: LM850 GTR, Audi RS6, Range Rover Vogue, Bentley Mulsanne
I'd say a Sportsman clutch, upgraded baskets, circlips and maybe an upgraded first gear.
R35 Boxer is offline   Reply With Quote
Old 24th February 2014, 06:38 PM   #3 (permalink)
vxrcymru's Avatar
Sounds sensible.
Is that what you are running?
Old 24th February 2014, 06:42 PM   #4 (permalink)
sportsman might be overkill - could try a supersport.
Old 24th February 2014, 06:45 PM   #5 (permalink)
R35 Boxer's Avatar
Edit I meant superstock. I've been running that clutch for almost a year at 880hp and no problems with it,. Me and JamieP both have had to upgrade the clutch baskets so it'll be best to upgrade them. My stock first has had a handful of launches and all is good so far.
Old 24th February 2014, 07:03 PM   #6 (permalink)
vxrcymru's Avatar
So basically you have this clutch pack
DMS DODSON MOTORSPORT SUPER STOCK 7 PLATE CLUTCH KIT 650FT/LBS R35 CSS | Dodson Motorsport
and this basket?
DODSON MOTORSPORT NISSAN R35 GTR CLUTCH BASKET OUTPUT B (1,3,5,R) | Dodson Motorsport
Any other ancillary parts required for the clutch?
Old 24th February 2014, 08:59 PM   #7 (permalink)
R35 Boxer's Avatar
Yes that's the one. I'm pretty sure nothing else is needed for the clutch but just confirm it with Iain first. What turbos are you going for?
Old 24th February 2014, 10:06 PM   #8 (permalink)
vxrcymru's Avatar
Not sure yet
The superstock kit is advised to 650ftlbs how much torque are u running?
Old 24th February 2014, 10:16 PM   #9 (permalink)
R35 Boxer's Avatar
Around 800ft/lbs or less usually, Iain said the superstock clutch is massively underrated and as of yet I've had no problems so they must be able to handle the power.
Old 25th February 2014, 06:01 AM   #10 (permalink)
Forgive me, I meant super stock, nit super sport. Stock clutch holds 650 to 750 (not sure how long for) so super stock will have higher capacity than that. I would fit billet baskets and uprated Dodson first gear and shaft and be done with it.
Cheaper than the higher options and retains stock feel.
Old 25th February 2014, 06:21 AM   #11 (permalink)
JamieP is aware!
JamieP's Avatar
My clutch is a 14 plate OEM clutch, 1.6 steels, set up by SVM. It's been brilliant and was seriously cheap setup when compared to everything else I've seen, drives like stock.
I've got an Albins first gear kit and SVM clips.
I've just recently upgraded to welded, stock clutch baskets.
But if you are not drag racing I'd have thought you could get away with just doing the clutch?
JamieP is offline   Reply With Quote
Old 25th February 2014, 08:02 AM   #12 (permalink)
vxrcymru's Avatar
Jamie,
many thanks.
Why did you go for the Albins first gear instead of the Dodson or PPG? Isn't the Dodson good and cheaper?
Old 25th February 2014, 08:36 AM   #13 (permalink)
The new Dodson first gear kit wasn't out until recently. They showed the prototype at sema. It's chunkier than the other first gear kits out there.
Albins have major supply problems as they honour Motorsport contracts first. Great stuff but difficult to source.
Old 25th February 2014, 10:16 AM   #14 (permalink)
JamieP is aware!
JamieP's Avatar
I just went with SVM's advice on the gear kit.
