Grey 32,strip and clean....kind of. - Page 41 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree312Likes
LinkBack Thread Tools Rating: Thread Rating: 10 votes, 5.00 average. Display Modes
Old 20th April 2018, 09:30 AM   #801 (permalink)
Simonh's Avatar
Cars owned: MY11 R35 Recaro
how did I miss the diff update? Great work as ever
Old 20th April 2018, 11:25 AM   #802 (permalink)
brett21 is My car keeps stealing my money
brett21's Avatar
Cars owned: Skyline GTR R32
Every time you blow me away with the effort & quality of the work.
Can I have first dibs on a viewing of this amazing car when it’s done?!
brett21 is offline   Reply With Quote
Old 20th April 2018, 02:16 PM   #803 (permalink)
R32skyline2017 is unaware they can edit their status
Originally Posted by kevr32 View Post
Thanks John, just wish I had a bit more time to spend on it.
Hi kurosan,
Thanks for the kind words and spoon recommendation, had a look as I had never heard of the collars, but to be honest, there's a lot of other bits I would rather spend the money on at the moment, thanks for bringing them to my attention.
Thanks ridge racer, I'll certainly try.
Hi R32skyline2017,
I use one of those cheap blast cabinets you can get from the like of ebay and Machine mart, crushed glass media and just a 6" bench grinder with a wire wheel, some times smaller wire wheels in my drill for the tight areas, so nothing flashy, just what ever works.
Regards Kev.
And the wire wheel is what polishes like that?
That’s a lot of work. But well worth it comes out looking so nice like new
R32skyline2017 is offline   Reply With Quote
Old 5th May 2018, 09:03 AM   #804 (permalink)
kevr32 is loving mornings, and the cool fresh air, just breath...
kevr32's Avatar
Thanks Simon,
Don't know if you get, or are even set up for notifications, but for some reason I've stopped being notified when someone replies to my thread, which is a little annoying as I don't check in on a daily basis, then feel a little rude for not responding quicker to everyone that takes the time to comment.
Nice to here from you Brett,
It's been a while bud and thanks for the kind words, hey, if it ever gets done I will be more than happy to drive down and let you have a look round it, as long as there's tea and biscuits available that is, how's the little one doing, thinking about it, probably not so little now.
Yes, just the wire wheel and your right it is a lot of work, but worth it, when I first started having bits zinc plated, I soon realised most of the problems and expense involved in getting a good finish was the prep work, which a lot of companies don't want to do because it's very time consuming, hence I started doing it myself.
Regards Kev.
R32skyline2017 likes this.
My Thread, may be worth a look when your board,
kevr32 is offline   Reply With Quote
Old 5th May 2018, 12:13 PM   #805 (permalink)
jnoor is told I am addicted to this site
jnoor's Avatar
I started getting a few bits plated but never thought about the prep work to get a good finish.
Going to take this into account now. Always learning something new from you if not being inspired by you Kev.
Would be grateful for you help on a quick few questions. When you painted the diff housing what are you using?
Also Im planning on taking off the entire dump valve assembly to refurb, and the valve heads with the vacuum nipple have rust on the surface. What would be the best way to clean this off without damaging the inner components? Mask off properly and vapor blast or shot blast them?
jnoor is offline   Reply With Quote
Old 5th May 2018, 02:04 PM   #806 (permalink)
Simonh's Avatar
So much awesomeness in one thread has broken the update notification.
kevr32 likes this.
Old 5th May 2018, 06:20 PM   #807 (permalink)
kevr32's Avatar
Hi bud,
The light grey paint I used as a base coat is epoxy mastic and sourced from a company called rust buster, not cheap but you get what you pay for, it's the same stuff I used on the shell, then followed this with five coats of good old u-pol satin black from a rattle can, I think the main thing about getting a good finish other than the paint, is heat, when I did mine I had it sat on a couple of blocks on the top of an old cupboard so air could circulate round it, then pointed my space heater at it to keep it warm between coats, (it was freezing out side at the time) and to be honest it turned out better than I expected.
Your spot on, that's what I did, masked and vapour blasted rather than dry blasted because the main part of the valve body is aluminium and needed to be done that way for the finish that was required, unfortunately for me the vapour blaster managed to blow part of the masking tape off one of the inlet pipes on top of the valve, which led to a little of the blast slurry getting in side, a real pain in the arse, but fixable, I dried them out for a couple of days on a radiator then blew the media out with an air line, of course it wasn't that easy but you get the idea.
Anything I can help with just ask, as I've said before I'm no professional, just a normal guy like everyone else and I may get things wrong, or do things other people don't agree with, but hey, I'm not here to teach, just to share what I like doing and hopefully inspire others to have a go them selves, because if I can do it, anyone can.
jnoor and R32skyline2017 like this.
Old 6th May 2018, 12:49 PM   #808 (permalink)
brett21's Avatar
Hi Kev,
Yes been a while, I’m always on here though, I have so many interests it’s hard to keep up to date! I’m a Old Skool Renault fan too,
Always time for a cuppa if your in my area with or without your Skyline, my garage has the kettle continuously hot.
Yes my boy is 4 going on 5 now, But now have another in the oven growing!
Back to Skylines, I stripped down my sills to metal the other weekend & primered & undersealed. I was so happy to see no rust! I’ve kept ACF 50 inside the sills & rear wheel arches since I imported it back in 2005, The only annoying bit is the left front jacking point slightly pushed up by bad jacking. (Not me)
I look forward to seeing more updates from you.
Cheers Brett
Old 2nd June 2018, 12:00 AM   #809 (permalink)
Marl is unaware they can edit their status
Hi Kev
Love your dedication to the 32 xx
The wheels that were on your car when you first starting the strip down, team dynamics Jade R 18-8.5 et 30
Can you confirm the size for me and the tyre size please as I really like them and want to get some for my 94 R32
Cheers and all the best
Marl
Marl is offline   Reply With Quote
Old 2nd June 2018, 05:36 PM   #810 (permalink)
kevr32's Avatar
Originally Posted by Marl View Post
Hi Kev
Marl
Yes of course I can bud, it's been a while since I've looked at them so I'll check on Monday and get back to you.
Kev.
Afternoon all,
A while back I had the clutch cylinder body vapour blasted by someone different to my normal guy and once it was built up I wasn't happy, so said I'd strip it down an have it done properly to match the rest, for the doubters out there,
The finish I wasn't happy with, quite dull and marked easily,
So stripped it down and now, much better,
Had the diff cover done at the same time,
When I did the diff housing I also had a crack at tidying this up,
Not really happy with the finish as you can still see the corrosion tracks made by the leaking brake fluid, so I'm going to flat it back and try filling the marks with some fine stopper.
Also had a delivery, a few little bits for when it goes back together,
I'd buy so much more if not for the fee's and tax's, but then again, wouldn't everyone.
Till next time,
Kev.
Old 9th June 2018, 08:42 PM   #811 (permalink)
Hi Kev,
Did you have a look at your wheels yet , I would love to know the spec you have .
Just finding a wheel you like for a R32 among the huge choice of very expensive wheels is a minefield ***128514;***128514;***128526;***128526;
On the engine front , are you going for a mild tune to compliment your ORC clutch or back to std.
Marl
Old 9th June 2018, 08:48 PM   #812 (permalink)
Apologies Kev
Just read my notifications and appreciate your answer .
Awesome project you have and cheers again.
Marl
Old 10th June 2018, 09:47 AM   #813 (permalink)
Mr GCC is unaware they can edit their status
I just spent too long looking through this build from start to here, WOW. There is restoration and then there is what you are doing.
In my head your doing all the things I tell myself I can do (yet to prove myself on that one lol)
Seriously going through this thread nearly made me break my fast haha
Amazing work and I kind of don't want it to finish because its stunning how good of a job you are doing. Keep it up mate!
Mr GCC is offline   Reply With Quote
Old 10th June 2018, 12:58 PM   #814 (permalink)
speedingpanther is Playing with R34 RB install
speedingpanther's Avatar
Cars owned: MNP R33 GTR, White Spec2 Stagea
Great to see the continued updates. I’ve been so busy I’ve not checked for a good few months. Keep it up Kev
speedingpanther is offline   Reply With Quote
Old 12th June 2018, 09:54 PM   #815 (permalink)
kevr32's Avatar
Thanks for the kind words bud, it'll be interesting to see what you do with yours, don't get many four doors on here.
Cheers bud will do, going to PM you.
Old 12th June 2018, 10:18 PM   #816 (permalink)
kevr32's Avatar
Tried to PM you Dave but your in box is full.
Old 12th June 2018, 11:30 PM   #817 (permalink)
Feel like a celebrity just looked at my car.. hahaha
The R34 will be a pretty mild build compared to what I am doing with me E30. Thats going to be the hard one and I hope I have the patience like you have.
Do you have a dead line you would ideally want your car done by?
JapFreak786 likes this.
Old 13th June 2018, 11:48 AM   #818 (permalink)
Not anymore
Old 29th July 2018, 11:43 PM   #819 (permalink)
gtr33 vspec is Modified
gtr33 vspec's Avatar
Cars owned: gtr 33 v-spec
I feel like I’ve just binged watched 10 seasons on Netflix of a favourite show
And there’s no more left I need more ,
U can build me a bigger garage and work on my car any day lol ***128514;
gtr33 vspec is offline   Reply With Quote
Old 30th July 2018, 09:05 PM   #820 (permalink)
kevr32's Avatar
Hi Mate,
Just PMSL, don't worry there's more to come, it's just that works taken over this year as usual, what can you do the bills need to be paid, money and time are being put aside though, so I can have a binge on it next year, may even get to squeeze a couple of days in before Christmas, need to finish the bungalow I'm building at the moment first, then fit my new kitchen before my wife cuts my nuts off.
Regards Kev.
brett21 likes this.
