Forge BOV fitting advice - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 12th May 2014, 04:18 PM   #1 (permalink)
a1whitey is enjoying the ride
Obviously look very easy to fit, only a couple bolts and nice and easy to get to.
What is concerning me in the spring rate adjustment, I have the yellow spring fitted atm, and green came with as a spare.
Yellow correct for stage 4?
The instruction sheet reads basically use the adjusters by trial and error to get right, is this correct?
"Each user will need to adjust their valves so that it will hold boost all the way to the specified redline of their application under wide open throttle without experiencing any valve fluttering at full boost throttle lift
If valve fluttering is felt at full boost throttle lift = too stiff
If leaking under WOT before redline = too soft"
Sooo, I should hear the noises from the valves (the famous ptshhhhhhh) when changing gear, but not changing gear during foot flat down driving? Is this because it is bad for the engine?
Basically I dont want to do any damage and trying to get advice how to make sure I dont set them wrong, thanks!
a1whitey is offline   Reply With Quote
Old 12th May 2014, 06:42 PM   #2 (permalink)
tinimark is making lots of noise
tinimark's Avatar
Cars owned: R35, Supercharged Elise 111r, BMW 220d, 335d, Golf R32..the list goes on
I've never heard mine changing up gears. I think the gear change is so quick even under part throttle. I hear them when changing down aggressively when the engine rev matches but they make the most noise when lifting off under full boost. Sometimes they flutter when lifting off under part boost. Mine are HKS but sure the principle is the same.
tinimark is offline   Reply With Quote
Old 12th May 2014, 06:50 PM   #3 (permalink)
All fitted.
So from the hazey instructions basically I dont want them to flutter when lifting from full boost? or changing gear on full boost? as this can damage the turbos?
They sound good so far
Old 12th May 2014, 07:16 PM   #4 (permalink)
tinimark's Avatar
It's a bit beyond my knowledge but I would have thought you're losing valuable boost if they're going off when you shift on full throttle.
Old 12th May 2014, 07:25 PM   #5 (permalink)
Ooo Matron !
snuffy's Avatar
Cars owned: GT-R & Fiat 500
You want to hear them when lifting off or changing gear (but as has been said, you may not hear them when changing gear as the change is very quick).
Under acceleration, if you hear them then the spring is too weak and it's dumping air and don't want that.
I was going fit them but from what's been said about not hearing them on a gear change I've decided against it as my only reason for fitting them was the psssttt noise on gear change.
Old 12th May 2014, 08:15 PM   #6 (permalink)
Firestarter is #nemesis_gtr
Firestarter's Avatar
Cars owned: R35 GT-R
Ive fitted TurboSmart BOVs on the advice of Iain & Sly as was told that the Forge BOVs don't operate correctly with Litchfield's maps. Mines a stage 3, and at the moment I only get the Pssssssst on lift-off which sound dooooope, however I will play with them tomorrow as the have a hard/soft setting which allows adjustment. Sly said that the piston shouldn't be open to far as this will create turbo lag where the air that's normally used to spool the turbo up is exhausted through the BOV, hence the turbo slows and then needs to re-spool
I'll have a play tomorrow and report back
Louie
Firestarter is offline   Reply With Quote
Old 12th May 2014, 08:24 PM   #7 (permalink)
You can just put the throttle down a bit and lift to get the noise, just been out and a well timed foot turned every head on the pavement :P
Old 13th May 2014, 07:20 AM   #8 (permalink)
Ooo Matron !
snuffy's Avatar
Arrggh, that's the thing with forums - conflicting information !!
Old 13th May 2014, 07:51 AM   #9 (permalink)
sound clip?? :P
Old 13th May 2014, 08:01 AM   #10 (permalink)
Ooo Matron !
snuffy's Avatar
sound clip?? :P
Go on then - that would be great, thanks.
Old 13th May 2014, 08:51 PM   #11 (permalink)
Steve is Mr GTR
GT-RDC Founder Member
Steve's Avatar
Cars owned: Nissan Skyline R33 GT-R "V"Spec
Louie
errrrr, hope not as I was / am an early adopter of the Forge BOV's, in fact I was the first one fitted with Forge BOV's as a trial for Forge and my car was remapped as recently as 2 weeks ago.
Iain knows my car inside out as he also supplied it !!!
Keep it on the Black Stuff
Steve + A-BEUT + A1 BEUT + Kermit
HARDCORE MEMBER
2008 Nissan GTR Black Edition (Racing "Fastest Colour" Red)
1997 Nisan Skyline R33 GTR V Spec (Midnight Purple, the only Colour for an R33 GTR)
1991 Honda NSX Type R (Vibrant Red)
2011 Porsche Cayman R (Peridot Green)
2108 VW Golf R (Saffron Gold)
2003 Mazda MX5 (Blue)
Steve is offline   Reply With Quote
Old 15th May 2014, 08:22 AM   #12 (permalink)
Can you please help me,
I'm worried about the settings on my forge bov,
want to make sure I have it right:
am I right in reading the instructions that, partial throttle lift = flutter is ok
but full throttle& boost lift = a strong hiss instead of flutter, this is right?
I have the yellow spring fitted and set as loose as it'll go really,
I dont have leaking of the valves so didnt need to set it any tighter?
Basically how do I know its set right???
