AMS Alpha Engine Oil Cooler - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > Vendors > Vendors Index > Evotune
Old 4th June 2014, 03:39 PM   #1 (permalink)
[email protected] is making things go faster
jamie@evotune's Avatar
Cars owned: R35 GTR, Porsche Cayenne Turbo, Evo 2 Sprint Car
The Solution For Replacing The Costly Factory Oil Cooler
The stock R35 GT-R oil cooler (p/n 21305-JF02B) retails at an astonishing $5133.00! When we saw that price we knew we had to create a solution. As usual, our engineering team had some unique ideas to make an oil cooler upgrade which was easy to install, more efficient and most importantly affordable for our customers.
Oil Cooler Upgrade Without Added Hassle
Instead of designing complex brackets, fittings, replacement lines and hardware or requiring modification of factory components we decided to make our oil cooler a true bolt in affair. By choosing a simpler approach we save you the worry about extra components that can corrode or leak. The Alpha Oil Cooler core uses all of the factory brackets, mounts, lines and shroud (no trimming required) exactly like the factory oil cooler core. This removes the added complexity of other alternatives saving you time and money.
Improved Design Aids Cooling
Instead of using the tube and fin style of the factory cooler and other upgrades on the market we chose a bar and plate design with a turbulator design. Turbulators increase the rate of flow and boost heat transfer netting better cooling of the oil. To further improve cooling our billet aluminum endtanks include a high temp foam making a proper seal to direct all of the air from the ducting through the core unlike the factory design. In addition we increased the thickness of our core from 50 to 61mm boosting cooling and oil capacity. This all adds up to an optimized cooler offering you greater efficiency
Billet Aluminum Endtanks
Larger, more efficient core design
Foam seal optimizes airflow through ducting
Cost effective solution when replacing the factory oil cooler
Uses OEM mounting, lines and shroud for a simple, true bolt in solution
Includes everything needed for installation
Includes
Alpha oil cooler
OEM gaskets
Installation Guide
Applications
2009 and up Nissan GT-R
Fits all USDM, European and JDM Models
Product Notes
This cooler was designed to work better than the stock counterpart when subjected to the identical conditions. If youíre looking for an all-around cooling solution for your GT-R, check out our Alpha Cooling System Upgrade.
We suggest the replacement of the factory oil cooler after any engine failure to prevent contamination of your new engine.
Price £1050 inc vat
jamie@evotune is offline   Reply With Quote
