Sky engineering sump extension - Page 2 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > General Nissan Skyline Chat
Like Tree5Likes
Old 15th October 2014, 01:16 PM   #21 (permalink)
markM3 is GTRless!
Maybe try an Accusump, as you can mount them in the boot for example.
markM3 is offline   Reply With Quote
Old 15th October 2014, 01:20 PM   #22 (permalink)
Skeeed3r is unaware they can edit their status
Skylinesusky switched from Sky Engineering sump to HiOctane sump after problems with the tightness
Skeeed3r is offline   Reply With Quote
Old 15th October 2014, 02:47 PM   #23 (permalink)
TeCko is unaware they can edit their status
I have it also on my car.
The sump itself and its effects are good.
In combination with my oil cooler i have almost 10 litres of oil now.
It is also not as low as the trust extension.
It had to be rewelded once because it was leaking, since then no problems.
TeCko is offline   Reply With Quote
Old 15th October 2014, 06:52 PM   #24 (permalink)
Jayman is Owner of R34 GTR 720 hp
i dont run a sump!! means uber cooling and no oil changes needed
Nosump for the win
Jayman is offline   Reply With Quote
Old 15th October 2014, 07:25 PM   #25 (permalink)
Saifskyline is unaware they can edit their status
Saifskyline's Avatar
Cars owned: R33 GTR V-Spec
Mine came super fast no issues dealing with them, and clearance will be fine with it. It's used worldwide and nobody has had issues with them.
Saifskyline is offline   Reply With Quote
Old 15th December 2015, 07:18 AM   #26 (permalink)
Audiophile is rebuilding to RB30
Audiophile's Avatar
I will add my 2 cents here.
Paid the guy in 11th of November for the sump. Nothing so far. He was happily answering my emails until I made the payment....Unfortunately I found this thread too late.
Could someone tell what are the dimensions of this sump?
Markus
Audiophile is offline   Reply With Quote
Old 15th December 2015, 07:51 AM   #27 (permalink)
teetee is unaware they can edit their status
teetee's Avatar
Markus
I got my sump extension in two weeks, but it was missing 3 pieces, then he doesn't answer to my emails anymore! After two months of emailing him, Saifskyline called him and this jonne told that I can't have my missing parts. Nice.. one part was longer oil pickup which I have to weld it myself because this great guy.
teetee is offline   Reply With Quote
Old 17th December 2015, 05:03 PM   #28 (permalink)
Audiophile's Avatar
Im now making my own, have scanned the stock sump into solidworks. Next I will make 3d model and will cut it out from 5mm aluminum alloy. Luckily I had sump baffle in my car, so will manufacture this also to meet new sump requirements.
Sent from my D5803 using Tapatalk
Old 17th December 2015, 08:08 PM   #29 (permalink)
arnout is converting to LHD
Cars owned: bee-R334 R34 LHD V8
You know with Jonne you have to actually drive to his shop and get the parts? That's how it works with him. He is just too busy / most likely forgetting so he just doesnt know he needs to send you a sump... that's it with him!
AEM Factory Trained Tuner
arnout is offline   Reply With Quote
Old 17th December 2015, 09:17 PM   #30 (permalink)
TAZZMAXX is ...............
ADMIN
TAZZMAXX's Avatar
No mate, he's a ****ing crook, plain and simple. If he's advertising sump extensions, and people pay for them, he needs to despatch them within a reasonable time frame. There's very few people on here have a good word for him so to try and make out he's a bit busy is a crock of shit.
David, matty32, Audiophile and 1 others like this.
Old 25th June 2018, 05:22 PM   #31 (permalink)
doyle4281 is unaware they can edit their status
Cars owned: Nissan
I know this is an old thread, but does anyone have any specific welding tis for welding sump extensions to the RB26 casting. I made a nice sump extension for my RWD sump, and now need it welded to the cast pan. The extension is made of .190" 5052, and it welded up fine, however welding that to the nissan casting is the issue. What filler rod, welder settings, and techniques are used?
doyle4281 is offline   Reply With Quote
Old 25th June 2018, 07:08 PM   #32 (permalink)
Gojira-R32 is Drifting mode
Gojira-R32's Avatar
i welded a lot of the cast alu parts for skylines without any problem.
I use 5053 or 6066 filler, just be shure you use more AC balance as you need to cook out the dirt in the weld of the cast alu.
And when you're tungsten point is melting, you need to change to different tungsten.
I use 1.6mm for ALL cast alu welds, and pre-heat you're cast alu part to minimize bending when cooling off
Gojira-R32 is offline   Reply With Quote
Old 25th June 2018, 07:29 PM   #33 (permalink)
Cars owned: Nissan
Thank you, I sent you a private message if thats alright
Old 30th June 2018, 11:51 AM   #34 (permalink)
KamikazePlayboy is unaware they can edit their status
my friend did the same job last year, took him 2 days on his own
KamikazePlayboy is offline   Reply With Quote
Old 30th June 2018, 04:51 PM   #35 (permalink)
K66 SKY is NO longer a subscribed reader of Evo magazine -The thrill of errrm....Advertising Watches???
K66 SKY's Avatar
Cars owned: 1992 Carlton GSi 3000 24v - 1996 R33 Skyline GT-R Standard Spec II.
Any Pics??
Passionate about old RWD Vauxhall-Opel's from the 1980's and 1990's but my Do-Luck BCNR33 Skyline GT-R is totally in another league and blows them all away!!!!
K66 SKY is offline   Reply With Quote
