Misfire/hesitancy around 3500rpm? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 20th October 2004, 11:51 AM   #1 (permalink)
-C-
-C- is unaware they can edit their status
Cars owned: The Mystery Machine
Hmmm
My car when I last drove it seems to be developing a slight missfire in the lower gears around the above rpms. It's just about where the car slowly starts to make positive boost.
Once it's 'cleared' itself & will carry on fine as it always has done, no other detrimental things going on from what I can tell...
Any suggestions? I thought maybe plugs but surely it would happen through the whole rev range then?
Bit confused now!
Chris
2 Wheels are better than 4!
-C- is offline   Reply With Quote
Old 20th October 2004, 12:05 PM   #2 (permalink)
s2gtr is RS6 Owner, After 5 GT-R's
s2gtr's Avatar
Cars owned: R33GT-S,R33GT-R,R34GT-R Now R35GT-R
Hi,
Had a similar problem with my R33-GTR turned out to be the lambda sensors.
Dave.
s2gtr is offline   Reply With Quote
Old 20th October 2004, 12:43 PM   #3 (permalink)
empi is unaware they can edit their status
Are you running F Con Pro ?
empi is offline   Reply With Quote
Old 20th October 2004, 12:44 PM   #4 (permalink)
-C-
Nope!
Still runs with the AFM's too (albeit the big Z32 types)
Chris
Old 20th October 2004, 12:53 PM   #5 (permalink)
Originally Posted by -C-
Nope!
I had a stutter in the low rev range which would come and go, then clear under load!, it drove me nuts it turned out to be a loose injector.
Old 20th October 2004, 01:27 PM   #6 (permalink)
Pavlo is unaware they can edit their status
Cars owned: [email protected] flat 4
do you run a VTA dump valve? If so, try blocking it, it sounds like the DV is leaking on vacuum then you get a hicup as it seals and suddenly throws the AFR out.
Paul
Pavlo is offline   Reply With Quote
Old 21st October 2004, 05:56 PM   #7 (permalink)
RocK is a racer..
RocK's Avatar
Cars owned: BCNR33 V-Spec
i got the same hicup. I'm running F Con V pro.
My 1st thought were the plugs, but i replace them its still there.
any ideas? thanks..
RocK is offline   Reply With Quote
Old 22nd October 2004, 12:40 PM   #8 (permalink)
Hmmm
Bit confused now!
On my R33 GTR it was a dead O2 sensor, probably failed when I had the engine out, they don't like being knocked about when they have a few miles on them. The CONSULT box will show this or anyone competent with an oscilloscope can test them.
Best Regards,
Chris Wilson.
Old 22nd October 2004, 12:49 PM   #9 (permalink)
nigel f is unaware they can edit their status
nigel f's Avatar
Cars owned: R33 GTR V SPEC, R34 GTR
It could be the Ignition Amp, I found that under load it wasnt as bad as light load and higher up the revs it wasnt as bad.
I did change the plugs and the coil packs etc, but proved it to the the Amp.
Nigel
nigel f is offline   Reply With Quote
