Suspension bolt sheared... - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > General > General Nissan Skyline Chat
Old 31st August 2014, 03:28 PM   #1 (permalink)
CSB
CSB is hoping this thread doesn't get locked...
CSB's Avatar
Exclamation Suspension bolt sheared...
Anyone know how to rectify this problem? Suspension bolt sheared on one side and on the other the threads have been sheared so the nut just spins in one place.
Car is on axle stands so not driveable. I'm guessing its pressed in to the hub from the other side?
Anyone got a nissan FAST diagram?
CSB is offline   Reply With Quote
Old 31st August 2014, 03:45 PM   #2 (permalink)
Simonh's Avatar
Cars owned: MY11 R35 Recaro
Is that the bottom of the damper? Can't quite see for the pic, if so it will just knock out
Old 31st August 2014, 04:27 PM   #3 (permalink)
CSB
CSB's Avatar
Yeah bottom of the damper. You sure it will knock out? Looks like it will require some serious force.
Old 31st August 2014, 04:34 PM   #4 (permalink)
Saifskyline is unaware they can edit their status
Saifskyline's Avatar
Cars owned: R33 GTR V-Spec
Try knocking it out with a punch, if that doesn't work use mole grips and unwind it untill all the threads are clear then try and knock it out.
If none of the above works then drill it
Saifskyline is offline   Reply With Quote
Old 31st August 2014, 04:45 PM   #5 (permalink)
CSB
CSB's Avatar
Do you know how it's assembled?
Old 31st August 2014, 05:17 PM   #6 (permalink)
wildboy is looking for more horses
wildboy's Avatar
Cars owned: R32GTR
Bottom damper bolt just knocks out, should be easy with no weight on it
wildboy is offline   Reply With Quote
Old 31st August 2014, 06:33 PM   #7 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Don't think its available separately
Old 1st September 2014, 08:19 AM   #8 (permalink)
lightspeed is mapping Infinity
lightspeed's Avatar
Cars owned: Project BNR32
It's a captive stud that is part of the front upright.
It must have been seriously over-torqued at some stage for it to snap at the thread like that.
Easiest repair would be to get a new front upright from a breaker.
I would think about doing the other side too seeing as the gorilla with a wrench probably swung on that one as well.
lightspeed is online now   Reply With Quote
Old 1st September 2014, 02:34 PM   #9 (permalink)
Carlos is making every day count
Carlos's Avatar
What lightspeed said. Had same issue recently with nut spinning. Took off ARB bracket and chopped end off bolt with angle grinder. Nut then backed off easily. Thought about getting all medieval on the bolt to replace it but not much room to play with. New upright was much easier solution.
Carlos is offline   Reply With Quote
