ECUtek ROM v4 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 5th September 2014, 01:03 PM   #1 (permalink)
tinimark is making lots of noise
tinimark's Avatar
Cars owned: R35, Supercharged Elise 111r, BMW 220d, 335d, Golf R32..the list goes on
ECUtek ROM v4
Afternoon all,
It's been a while so I thought I'd make a quick post about ECUtek ROM.
Since having v4 installed by ACSpeedtech it really has made a big difference to the way the car drives and the new toys (rolling launch etc) are great fun.
I have an idea to improve usability and thought I'd run it past you all to see what you think. Also, I'm aware the ECUtek guys come on the forum from time to time so it might give some inspiration.
This would be quite easy to implement, not too technical.
Currently, I have 4 maps installed and to change maps you have to hold the CANCEL button on the steering wheel for 2 seconds, change map with the cruise control adjust button and then wait about 2 - 3 more seconds for the map to engage.
It would be much quicker to make it so that just a quick press of the cancel button put it in to "map change mode" select the desired map and then press CANCEL again to engage the map. I can't ever recall accidentally pressing the CANCEL button and even if you did it wouldn't change maps by itself.
With rolling boost you have to first select the correct map which has the feature enabled, put the car in to cruise control and set speed, floor the accelerator and then press CANCEL to unleash the beast.
Wouldn't it be better if by pressing and holding the cancel button at the desired speed then floor it and release CANCEL to go without going in to cruise control? I think this would give much more control of the feature and allow users to take advantage at very short notice. It would also mean that "normal" cruise control would not be affected (so you can accelerate as normal in cruise).
What do you all think?
tinimark is offline   Reply With Quote
Old 5th September 2014, 01:20 PM   #2 (permalink)
Johnny G is here. Hi!
Johnny G's Avatar
Cars owned: Nissan GT-R, BMW 730d, BMW 535d
Can't say it bothers me in the slightest, to be honest.
Johnny -
2017 GT-R - Daytona Blue, Recaro Edition - Litchfield Stage 4.5, Alcon BBK: 754bhp, 642lb/ft
Johnny G is offline   Reply With Quote
Old 5th September 2014, 01:43 PM   #3 (permalink)
tinimark's Avatar
I wouldn't go as far to say that it really bothers me but here's a scenario....
Driving down the A30 on the way home in normal cruise control and an M5 wants to have a play. I decide he needs a few flames so change to pops and bangs map. Then after a little while he pulls up beside and I fancy some rolling boost action which means changing the map again, engaging cruise and setting speed etc.
With the tweaks I mentioned above all of this could be done in one map at a fraction of the time.
Those extra few seconds in the heat of the moment and less fiddling around would make all the difference I think.
Old 5th September 2014, 01:51 PM   #4 (permalink)
Johnny G's Avatar
Being brutal, that's more you than the setup.
I leave mine in full power mode all the time. When there's nothing around, then I play with pops and bangs, mainly in tunnels. Then I go to full power again.
Johnny -
Old 5th September 2014, 02:00 PM   #5 (permalink)
tinimark's Avatar
Not really complaining about the setup, just think it could be improved with regards to map changing and rolling boost.
Do you have rolling boost feature enabled on your full power map?
Old 5th September 2014, 02:23 PM   #6 (permalink)
Johnny G's Avatar
Yep. I have four maps. 95, 97, 99, 100.
99 and 100 are the same, except 100 has no addons.
Johnny -
Old 5th September 2014, 02:28 PM   #7 (permalink)
tinimark's Avatar
I see, but if you have RB enabled on all maps then you can't really use cruise control in the normal way ie. if you accelerate with the pedal then nothing happens except building boost.
On mine I have a full power map and a full power map with RB.
With my suggestion, you wouldn't need an extra map just for RB feature.
Old 5th September 2014, 02:46 PM   #8 (permalink)
Johnny G's Avatar
I have my RB to only kick in when suspension is in Race, on all maps except 100.
Johnny -
Old 5th September 2014, 03:15 PM   #9 (permalink)
tinimark's Avatar
So, not only do you need to be in the right map but you also have to be in race mode and if you ARE in race mode then you can't use normal cruise control unless you're running 100 fuel?
That would definitely bother me!
Old 5th September 2014, 04:57 PM   #10 (permalink)
Mommy's setup is far easier and better.... drive on full power but comfort mode all the time an if you feel you need to scuttle.off quickly you simply put suspension in r instead of changing maps simples
Old 5th September 2014, 05:09 PM   #11 (permalink)
tinimark's Avatar
I hear what you're saying but with the tweaks i'm suggesting, you wouldn't need to engage R mode to use RB and you wouldn't be restricted to using cruise control ONLY in comfort mode and you wouldn't have to change maps either.
ie. All maps have RB enabled and to use it just press and hold CANCEL, floor it and release.
...even more simples!
Old 5th September 2014, 05:38 PM   #12 (permalink)
Johnny G's Avatar
I can count on a leppers hand how many times I've actually used RB. It's for bigger turbos. For stock, it's cool, but a waste of time IMO.
Johnny -
Old 5th September 2014, 08:40 PM   #13 (permalink)
thistle is aware they can edit their status
thistle's Avatar
Cars owned: GTR, D4 S8, MkV GTI, E46 325ti, E46 M3
The way I coded it for Cobb I still like. Hit cancel and as soon as you like hit up or down and the map changes instantly. Never accidentally made a selection, but people like user interfaces done differently.
thistle is offline   Reply With Quote
Old 5th September 2014, 09:08 PM   #14 (permalink)
tinimark's Avatar
Didn't even know Cobb maps could be swapped on the fly. Is that a newish thing?
Old 5th September 2014, 09:28 PM   #15 (permalink)
thistle's Avatar
4 years old. It isn't trendy to like Cobb on this forum since I stopped working for them 3 years ago, because new developments have lagged behind Ecutek, but it is still a powerful platform. It sounds like they are testing rolling boost and engine protection maps. Traction control would be nice for the more powerful cars I think, but launch aside, R mode suits my car.
Old 6th September 2014, 07:55 AM   #16 (permalink)
tinimark's Avatar
I was on Cobb to start with about a year ago and now you mention it, I do reminder being able to switch maps but can't recall the process now. No doubt Cobb will come back with updates for their platform and will be interesting to see if they have made any new innovations.
I'm not sure how much control the tuners get in terms of being able to decide how the user interfaces work but they must have some amount of control to be able to decide if certain features are available if a switch is in R mode or not.
I saw not long ago a module that allowed the R switches to remember their last known position. Since 90% of the time I drive in RRR I think this is a nice idea but now I'm wondering if this could be done via the ECU rather than having to buy quite an expensive but simple circuit board.
Old 6th September 2014, 09:17 AM   #17 (permalink)
thistle's Avatar
So far no one has flashed the suspension and VDC modules. So you would have to get the TCM or ECM to switch them. If the switches transmit over CAN bus that should be possible to code. If the suspension and VDC switches are wired to their modules then it needs the circuit board. Wiring diagrams would test feasibility.
