Removing the rear diff BNR32 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree1Likes
  • 1 Post By monkichi
Old 15th September 2014, 03:35 PM   #1 (permalink)
CabbageMS is trying to keep r32godzilla.com up to date...
What is the process for removing the rear diff? Do you have to drop the fuel tank? Or is it easiest to remove the whole rear sub frame?
CabbageMS is offline   Reply With Quote
Old 15th September 2014, 04:28 PM   #2 (permalink)
AlexJ is as AlexJ does
AlexJ's Avatar
Cars owned: BNR32 HCR32
Undo the prop and driveshafts, pull the abs sensors, earth strap and lower the diff abit on a jack, undo the attesa pump and bits bolted to the top, tricky bolts bit not that bad, then drop the diff.
No need to drop the subframe or tank.
Old 30th October 2014, 12:20 PM   #3 (permalink)
Chris_Gojira is Hardcore
Chris_Gojira's Avatar
Cars owned: Gojira
Exactly.
Be carefull, the diff is pretty heavy. You should really use a gearbox jack because you can't lift it from above your head when you're doing it on your own
Chris_Gojira is offline   Reply With Quote
Old 30th October 2014, 02:07 PM   #4 (permalink)
I take it this requires removing the fuel tank to get at the bolts on the back?
Old 30th October 2014, 04:32 PM   #5 (permalink)
AlexJ's Avatar
Nope
Old 30th October 2014, 10:20 PM   #6 (permalink)
monkichi is building 1000+ hp
monkichi's Avatar
Cars owned: R35 GTR, V6 Turbo Cedric, Rocketbunny S13
No, no. You can do it just like mentioned before. I can lift diff alone, but it's heavy a lot. So careful wenn you disconnect last bolts.
Agent83 likes this.
monkichi is offline   Reply With Quote
Old 22nd December 2015, 12:37 AM   #7 (permalink)
BronxGTR is unaware they can edit their status
Going to tackle this in a few days and wondering whats the beat way to clean the surface before installing new gasket. Should I use some sealant also?
BronxGTR is offline   Reply With Quote
Old 23rd December 2015, 04:42 PM   #8 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
You can get a diff gasket from Nissan, better to use this imo.
