-   -   How to remove the front R35 badge? (https://www.gtr.co.uk/forum/300297-how-remove-front-r35-badge.html)
Dr Meat 28th September 2014 03:12 PM
I'm trying to take the red resin R out of the crome effect plastic from the front R35 badge, I was hoping someone would know how to do this?has anyone on hear done this before? Ps the badge is removed from the car I just couldn't think of how to shortern this question for the thread title.
guyblue10 28th September 2014 05:20 PM
Hi There
Don't know - Just had a look at my R badge that's been in my desk drawer for the last 5 years....but I would try soaking it in this stuff
3M Scotch Weld Citrus Cleaner Spray 500ml 50098 Grease Oil Dirt Adhesive Remover | eBay
It's brilliant for removing adhesive - used it myself today on another project - I'd try giving it a good few sprays over the course of an hour, enough for it to penetrate well between the silver and the red, then trying to prise it out with a pin - it's got a bit of bend in it
Failing that - drill a couple of small holes from the rear - let loads of the same stuff penetrate into them...then try pushing from behind
What do you have in mind - some sort of SMD project?
Dr Meat 28th September 2014 05:46 PM
If I can split it without breaking it, I want to illuminate it or change the colour.
bobbie 28th September 2014 06:22 PM
I have tried this myself and ended up drilling it out with a bremhill drill bits, done the job ok, but then is the problem of inserting the leds in it, I done it but was not happy with how the leds lit up, all you saw was the individual leds and just not a single complete light source, so just slung it on the shelf and went and bought the tommy karra one. of which is great
[IMG]http://i1133.photobucket.com/albums/...7/IMG_1558.jpg[/IMG]
The Cat 28th September 2014 07:37 PM
Gently heat it with a Hair Dryer on inmurse it in hot water.
guyblue10 28th September 2014 08:07 PM
Here you go. Soak it in the 3M stuff - 2 squirts over an hour - use a razor blade to ease up one edge
http://i878.photobucket.com/albums/a...pse557ff77.jpg
http://i878.photobucket.com/albums/a...psa13e74ba.jpg
Squirt a bit more in the gap - leave it 30 seconds...ease it up a bit more - keep doing this for 4 or 5 goes - be really careful along the top as it's really thin and ....Bob's your auntie...
http://i878.photobucket.com/albums/a...psfdb93f8d.jpg
Dr Meat 28th September 2014 08:19 PM
:bowdown1:well done, I was going with the heat method as I put it in the oven at 120 for 5 mins and I could get some movement but I only had a terminal screwdriver but that was too fat. eBay it is then,Thankyou
bobbie 28th September 2014 09:26 PM
Ahhh once you got the front off that was the easy bit, now you have to make room in there for some leds:popcorn:
Bobby
guyblue10 28th September 2014 09:37 PM
Funny you should say that - I did think about it a couple of years ago - I can make PCBs, solder SMDs (small surface mount LEDs) and build sequencing circuits....my plan was to create an R with white leds on the outside and red on the inside, so the two colours could be made to light separately.....but how to make it resistant to 100+mph?...I thought about using the original R as a mould and then encasing the circuit board in clear resin....I think I even bought the stuff to do it.......
Never got round to it - think it would look good lit up, but not too sure in the daylight...
bobbie 28th September 2014 09:54 PM
You got a do it!
Bobby
Dr Meat 29th September 2014 11:44 AM
1 Attachment(s)
Warming it in the oven worked, I just needed a blade to remove the R. Thanks guyblue10:thumbsup:
The Zedhed 29th September 2014 01:03 PM
In for the updates :)
