How to remove the front R35 badge? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 28th September 2014, 03:12 PM   #1 (permalink)
Dr Meat is a THUNDER BUDDY
Dr Meat's Avatar
I'm trying to take the red resin R out of the crome effect plastic from the front R35 badge, I was hoping someone would know how to do this?has anyone on hear done this before? Ps the badge is removed from the car I just couldn't think of how to shortern this question for the thread title.
Dr Meat is offline   Reply With Quote
Old 28th September 2014, 05:20 PM   #2 (permalink)
guyblue10 is aware they can edit their status
guyblue10's Avatar
Hi There
Don't know - Just had a look at my R badge that's been in my desk drawer for the last 5 years....but I would try soaking it in this stuff
3M Scotch Weld Citrus Cleaner Spray 500ml 50098 Grease Oil Dirt Adhesive Remover | eBay
It's brilliant for removing adhesive - used it myself today on another project - I'd try giving it a good few sprays over the course of an hour, enough for it to penetrate well between the silver and the red, then trying to prise it out with a pin - it's got a bit of bend in it
Failing that - drill a couple of small holes from the rear - let loads of the same stuff penetrate into them...then try pushing from behind
What do you have in mind - some sort of SMD project?
guyblue10 is offline   Reply With Quote
Old 28th September 2014, 05:46 PM   #3 (permalink)
Dr Meat's Avatar
If I can split it without breaking it, I want to illuminate it or change the colour.
Old 28th September 2014, 06:22 PM   #4 (permalink)
bobbie is Stage 1
bobbie's Avatar
Cars owned: 2010 GTR
I have tried this myself and ended up drilling it out with a bremhill drill bits, done the job ok, but then is the problem of inserting the leds in it, I done it but was not happy with how the leds lit up, all you saw was the individual leds and just not a single complete light source, so just slung it on the shelf and went and bought the tommy karra one. of which is great
[IMG][/IMG]
Litchfield Stage 1, Version 7 EcuTek RaceRom, with Milltek de-res Y pipe
Litchfield TC & LC with 2015 Nismo gearbox software update K & N Filters, Non Res Miltek y pipe, Rear 4 light edition, Rear Led licence plate lights, Tommy Kaira light up Gtr Emblem.
Bristol & surrounding area meet
bobbie is offline   Reply With Quote
Old 28th September 2014, 07:37 PM   #5 (permalink)
The Cat is unaware they can edit their status
Gently heat it with a Hair Dryer on inmurse it in hot water.
The Cat is offline   Reply With Quote
Old 28th September 2014, 08:07 PM   #6 (permalink)
guyblue10's Avatar
Here you go. Soak it in the 3M stuff - 2 squirts over an hour - use a razor blade to ease up one edge
Squirt a bit more in the gap - leave it 30 seconds...ease it up a bit more - keep doing this for 4 or 5 goes - be really careful along the top as it's really thin and ....Bob's your auntie...
Old 28th September 2014, 08:19 PM   #7 (permalink)
Dr Meat's Avatar
well done, I was going with the heat method as I put it in the oven at 120 for 5 mins and I could get some movement but I only had a terminal screwdriver but that was too fat. eBay it is then,Thankyou
Old 28th September 2014, 09:26 PM   #8 (permalink)
bobbie is Stage 1
bobbie's Avatar
Ahhh once you got the front off that was the easy bit, now you have to make room in there for some leds
Bobby
Old 28th September 2014, 09:37 PM   #9 (permalink)
guyblue10's Avatar
Funny you should say that - I did think about it a couple of years ago - I can make PCBs, solder SMDs (small surface mount LEDs) and build sequencing circuits....my plan was to create an R with white leds on the outside and red on the inside, so the two colours could be made to light separately.....but how to make it resistant to 100+mph?...I thought about using the original R as a mould and then encasing the circuit board in clear resin....I think I even bought the stuff to do it.......
Never got round to it - think it would look good lit up, but not too sure in the daylight...
Old 28th September 2014, 09:54 PM   #10 (permalink)
bobbie is Stage 1
bobbie's Avatar
You got a do it!
Bobby
Old 29th September 2014, 11:44 AM   #11 (permalink)
Dr Meat's Avatar
Warming it in the oven worked, I just needed a blade to remove the R. Thanks guyblue10
Old 29th September 2014, 01:03 PM   #12 (permalink)
The Zedhed is going to clean his car!!!
The Zedhed's Avatar
Cars owned: Turbo ZZR14R 360rwhp (Road Bike); Turbo ZZR11 575+rwhp (race Bike)
In for the updates
The Zedhed is offline   Reply With Quote
