Upgrade order? - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 4th October 2014, 05:45 PM   #1 (permalink)
whpFarmer is a SharePoint nerd
whpFarmer's Avatar
Upgrade order?
Hello!
I recently bought a 2010 gt-r with rouglhy 18 000 miles on the clock.
I'm looking at 2012 inlets (or perhaps aftermarket?), catted ams dp's (they're in my garage), catless y-pipe, a tune and lastly intake. Does that sound like a good order of doing things, or should I change something?
I don't mind having a car breathing more freely than 2012 onwards, even though I probably won't tune for every last drop of power. If you know of any good information that describes the order in which upgrades should be made for the r35 or if you provide it yourself, that tip would be greatly appreciated.
Cheers from Sweden!
whpFarmer is offline   Reply With Quote
Old 4th October 2014, 05:49 PM   #2 (permalink)
Caveman is trying to resist buying another GTR...
Cars owned: 2013 R35 GTR (Gone), 2010 RS6 Plus Avant (Family wagon)
Injectors will finish that list off nicely.
Caveman is offline   Reply With Quote
Old 4th October 2014, 06:36 PM   #3 (permalink)
whpFarmer's Avatar
If I tune conservatively do I need injectors? Did Nissan change injectors between years? The way I see it, is that I can at least run power levels that Nissan deem relatively safe on the newer models. Haven't ever had a tuned car where I practically followed the car manufacturers recommendation on tuning :-)
I thought perhaps if I "needed" more power I'd go injectors, pumps and e85.
Old 4th October 2014, 08:57 PM   #4 (permalink)
vxrcymru is a carbon fetishist
GT-RDC Founder Member
vxrcymru's Avatar
Cars owned: R35 GTR Stage 5 & Evo X FQ400
You'll get to 600 ish with that set up, fit injectors to up to 640 ish.
Black MY2010 Black Edition, Litchfield Stage 5 - Switzer P800 turbos, Litchfield suspension, Alcon 400mm front and 380mm back discs with Pagid pads, circlips, front and rear cameras, auto folding mirrors & lots of CF. Advan RSD wheels!
vxrcymru is offline   Reply With Quote
Old 5th October 2014, 08:03 PM   #5 (permalink)
gtr mart is fast and loud
gtr mart's Avatar
I think the injectors bring a margin of safety above 600 hp. If you might run E85 then consider this now as you will need much bigger injectors - that said without forging your rods atleast or fitting bigger turbos you will only be able to get so much power out of your set up.
What you suggest sounds good although if your not going mad for power then panel filter upgrades would do inplace of full inlets and if your doing the downpipes it should help remove some restriction at the top of the rev band anyway.
With the tune, what would you run? Cobb or Ecutek I assume?
Old 6th October 2014, 11:43 AM   #6 (permalink)
gtrsam is 1337
gtrsam's Avatar
Cars owned: Super fast cars :-)
I assume you already have the catted dp's but many of them have been destroyed after a while since they can't take the heat. It is usually better to use noncatted DP's and have a catted y-pipe with HF catts then you can pass inspection(besiktningen :-)).
GTC have aftermarket inlet pipes for a good price which is bigger then oem 2012+.
Om du inte redan är det regga dig på r35.se.
Never take life seriously. Nobody gets out alive anyway.
In hoc signo vinces
gtrsam is offline   Reply With Quote
Old 6th October 2014, 11:49 AM   #7 (permalink)
grahamc is loving the GTR!!!
grahamc's Avatar
Cars owned: Nissan GT-R35; Mazda MX5 supercharged; Ford Escort Mk1; Datsun 240z
+1... standard injectors are close to the limit at this stage, so since you are doing a tune/remap, may as well replace them at the same time.
"Anyone who tells me a good car is one that is light with high power to weight ratio is an amateur." - Kazutoshi Mizuno
Originally Posted by BridgeStoneSteve
grahamc is offline   Reply With Quote
Old 6th October 2014, 01:03 PM   #8 (permalink)
you say, doing things in this order....... so you are going to do all these biits over a course of time and fit them as you get them?
Old 6th October 2014, 08:16 PM   #9 (permalink)
whpFarmer's Avatar
I was thinking of doing dp's, inlet, intakes with cone filters (although if possible get upgraded panel filter since it looks a lot better for the inspection/mot/besiktning), y-pipe and of course the tune in one go.
I've run Cobb for the last 10 years on ohter platforms and I think it suits my needs for the gt-r as well. I'll run a conservative map for the setup, 550-560 crank hp will suffice for now.
Catted downpipes I've never had before on other cars, as they were given to me I'll just stick to them I think. That is, if there's nobody objecting on here. Since they're after the turbos I assume nothing big happens if they break, or?
I'll have to check out gtc for the inlets, sounds good.
So injectors I'll only need for roughly 600 crank hp and onwards?
I thought I'd wait with the injectors and if I wanted to switch over to ethanol I'd do the injectors and pumps. Does this seem reasonable?
Finally thanks for all the responses!
Old 6th October 2014, 08:19 PM   #10 (permalink)
grahamc's Avatar
600 flywheel hp is when injectors are required
Old 6th October 2014, 08:30 PM   #11 (permalink)
gtr mart's Avatar
that seems reasonable to me. I think if you aren't fussed about getting over 600hp then you needn't bother with the DP's either but they give potential to make the top end of your rev band a bit more free revving.
As for the catted performance downpipes, I don't know. When anyone in the UK does the downpipe upgrade they tend to go for catless downpipes and do it mainly for the noise. AMS is a respected brand and I would have zero issue fitting their kit, but what they will be like I don't know. I would give it a go if labour wasn't prohibitive
Old 6th October 2014, 08:50 PM   #12 (permalink)
whpFarmer's Avatar
Ok, seems like consensus to wait with injectors provided I go convervative when tuning.
My neighbour is really into cars, so I can borrow his lift when I want to, as long as I complete the task in a week or two.
I like getting my hands dirty wrenching my cars, so labour is "free". I'll try these downpipes and see how they hold up.
Next step would be injectors, pumps and ethanol. But I'm not sure I'll ever get the urge for E in this car.
Cheers!
