R34 GTT Detailed Specifications - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Old 5th July 2002, 10:48 AM   #1 (permalink)
Trevor is unaware they can edit their status
Trevor's Avatar
Cars owned: Ferrari 360 & R34 GTt
Post R34 GTT Detailed Specifications
Here's the most details specs i've managed to find out yet... Anyone who can add to this, e.g. gearing ratio's, etc. please feel free to add to this list... I'm trying to get a full list of specs to add to a new website i'm going to create specifically for the R34 GTT drivers in the UK....
enjoy !
Trev
Model: R34 Nissan Skyline GTT
Model Year: 1998.5 to present...
Engine Name: RB25DET (Race Bred, 2.5 litres, turbo)
Engine Cooling: Water cooled,
Engine Configuration: Inline V6 Cylinder,
Engine Camshafts: Double Overhead Cam 24 valve,
Engine Aspiration: Intercooled Turbo,
Engine Valve Technology: NEO Variable Valve Cam Timing Technology
Engine Bore ◊ Stroke: 86mm ◊ 71.7mm
Engine Displacement: 2498 cc
Engine Compression Ratio: 9:1
Engine Max Power 206kW (276 bhp) @ 6400rpm
Engine Max Torque 343Nm (253 ft-lb) @ 3200rpm
Fuel tank capacity: 65 litres
Fuel type: Unleaded premium (RON 98+)
Fuel consumption: 9.4 litres per 100 km
Transmission: Type 5 speed manual
Drive layout FR: Limited slip differential (as standard)
Steering system: HICAS 4-Wheel Steering
Steering type: Power Assisted Rack & Pinion
Front suspension: Independent suspension multiple link system
Rear suspension: Independent suspension multiple link system
Front brakes: Ventilated disk
Rear brakes: Ventilated disk
Front tyres: 225/45ZR17
Rear tyres: 225/45ZR17
Turning circle: 10.2 m
Dimensions: Exterior length 4580mm
Exterior width 1725mm
Exterior height 1340mm
Interior length 1780mm
Interior width 1400mm
Interior height 1105mm
Wheelbase 2665mm
Front track 1480mm
Rear track 1470mm
Ground clearance 140mm
Weight: 1410 kg
Trevor is offline   Reply With Quote
Old 20th July 2002, 07:54 PM   #2 (permalink)
andyf is unaware they can edit their status
Cars owned: Nissan 200SX (S14)
Re: R34 GTT Detailed Specifications
andyf is offline   Reply With Quote
Old 20th July 2002, 11:26 PM   #3 (permalink)
Dan_BlitzedS14 is unaware they can edit their status
Dan_BlitzedS14's Avatar
Cars owned: Wide Body S2000
Yeah, I wondered about that too!
Tel: 01375 392777
Fax: 01375 391044
Performance Parts Distribution
Dan_BlitzedS14 is offline   Reply With Quote
Old 21st July 2002, 12:47 AM   #4 (permalink)
phatty is unaware they can edit their status
phatty's Avatar
Cars owned: Vertex S14a
Hi Trevor , Incase u wondered what these sarcy 200 owners ment , It's a straight 6
phatty is offline   Reply With Quote
Old 22nd July 2002, 10:08 PM   #5 (permalink)
Trevor's Avatar
Thanks Phil,
STRAIGHT SIX!!!
doh!
T
