Stock airbox, Arc box or Induction kits poll! - Page 4 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
View Poll Results: What kind of air filter do you run?
Stock airbox? 69 17.38%
ARC Airbox? 60 15.11%
Aftermarket Induction kits? 259 65.24%
You are insane, run no AFM's a draw air direct to the turbo...? 16 4.03%
Multiple Choice Poll. Voters: 397. You may not vote on this poll
Old 22nd April 2011, 06:11 PM   #61 (permalink)
Benizakura is unaware they can edit their status
Benizakura's Avatar
Cars owned: R33 GT-R
My current setup. ARC box and KTS suction piping.
Benizakura is offline   Reply With Quote
Old 28th April 2011, 10:48 PM   #62 (permalink)
wardiz is looking for rear suspension bar from v-spec
wardiz's Avatar
stock air box with nismo panel filter.
I think the stock air box is quite good as Mines and Nismo are basically using it.
wardiz is offline   Reply With Quote
Old 3rd June 2011, 09:35 AM   #63 (permalink)
madandy is Waiting for Work Emotion CR Ultimate wheels :)
madandy's Avatar
Cars owned: BNR32 GT-R Road Warrior & HP10 Primera Track Whore
HKS. 1 beast I know made 30hp chnging from ARC box to trust Airnx pods...
madandy is offline   Reply With Quote
Old 21st June 2011, 06:39 AM   #64 (permalink)
jhbnr32 is unaware they can edit their status
Cars owned: BNR32+RS13+RNN14
where to get arc filters? Or replacement ones? I have found that bigger one from kn catalog but the smaller one is tougher to find...any tips for it?
1990 BNR32
1992 RS13
jhbnr32 is offline   Reply With Quote
Old 21st June 2011, 10:07 AM   #65 (permalink)
Owner of the MSNSPS
Cris's Avatar
Cars owned: BNR32, RGV, 330i
If the Arc ones are foam then you can just clean them. My motorbike came with an oiled filter as standard and to service you'd wash it (in diesel) then re-oil it. If you are running MAFs then you might not want to oil it but there are alternatives you can use.
On the other hand if the K&N filter is cotton they (apparently) filter better. I'm sure K&N could help out if you dropped them a line.
Old 21st June 2011, 02:58 PM   #66 (permalink)
yea, the original ARC filters are foam and you can wash them, but i dont have those in my box. I bought it with some crappy paper panels. So there gotta be a replacement filters but the smaller one (170x120mm) is hard to find. Or you could just buy a originals but i dont know where
1990 BNR32
1992 RS13
Old 24th June 2011, 02:19 PM   #67 (permalink)
godzilladom is making you an offer you can't refuse
godzilladom's Avatar
Cars owned: Top Secret R32 GTR
Originally Posted by fontane View Post
Twin HKS filters but I worry they dont get enough air as one sits against the washer bottle. I want a headlight duct but it isnt street legal surely?
the ones with lights in are... I think
I have HKS pods on mine but after reading up loads on the air temp circulating the pods vs the air temp in the ARC box, I bought an ARC box and will be fitting it soon.
I've also been told the way to make the box perfect, is to pipe a cool air feed to it, however you can
godzilladom is offline   Reply With Quote
Old 30th June 2011, 05:43 AM   #68 (permalink)
louis110 is like woah
I went from the HKS pods, to the ARC induction box, and now Apex'i cones.
The HKS made plenty noise, but it didn't get good numbers for filtration and airflow in an article I read. Which doesn't surprise me as the foam is pretty thin.
The ARC box looks good, was quiet, but did a terrible job of filtering. As mentioned before, the filter would bow out and get sucked into the filter, and there was a hole in the bottom of mine for which I assume was a water drain, but also doubled as a non-filtered intake section. It mucked up my MAFs and when I took it all off there was sand and dirt in the intake pipes past the MAFs. My car stuttered violently and ran like garbage.
Switched to Apex'i filters and changed my MAFs and now the car purrs, the filter element on the Apex'i system is way better than those other replaceable foam systems. Same noise volume as the ARC box.
louis110 is offline   Reply With Quote
Old 30th June 2011, 12:36 PM   #69 (permalink)
Benizakura's Avatar
Originally Posted by louis110 View Post
As mentioned before, the filter would bow out and get sucked into the filter...
I presume you ment it got sucked into the box? That's probably because it's not fitted properly. You need to get the filter in position so it sits on the edge in the back of the box, otherwise it caves in.
I found it's a bitch getting fitted, I used a screwdriver on the rubber, pushing it in over the edge.
Old 30th June 2011, 02:42 PM   #70 (permalink)
Yes I meant the box. The panel sat in the box properly, but as soon as the frame around it was screwed on, it would distort the seal between the filter and the box.
Old 17th July 2011, 07:55 AM   #71 (permalink)
penant78 is unaware they can edit their status
Cars owned: R32 GTR, Civic EP3, MR2 Turbo Rev3
I'm currently running on an Apexi induction kit, great piece of kit.
penant78 is offline   Reply With Quote
Old 4th October 2011, 01:56 PM   #72 (permalink)
hmm. still struggling to find filters, there must be bunch of arc users here so where do you get your filters for it?
1990 BNR32
1992 RS13
Old 4th October 2011, 05:16 PM   #73 (permalink)
matty32 is In tokyo
matty32's Avatar
Filters are not available in japan
Old 4th October 2011, 07:02 PM   #74 (permalink)
bummer. there must be some filters that are correct size for it, but its reeeally hard to find out. When i bought mine there were some filters used (no part numbers in them tho), i know that bigger one is available but that smaller one is tough to sort out
modding the box and filter frame is always a choice, but im sure there is some alternative one to use. so step out who knows
1990 BNR32
1992 RS13
Old 5th October 2011, 02:57 PM   #75 (permalink)
Niklas is going rb3026
The hole in the bottom is not for water drain but is used to screw the box into a bracket that sits underneath it.
Never had a problem with my box.
Have both black filters and Red ones with the ARC-logo on them, none of them get sucked in.
Niklas is offline   Reply With Quote
Old 21st October 2011, 05:20 PM   #76 (permalink)
Oh I see. I suppose I was just unlucky (nature of buying 2nd hand I suppose). I like the Apex'i filters much more though. There's more room to work with and easier to remove/install.
Old 8th March 2012, 04:23 AM   #77 (permalink)
Lubo69GTR is Is sporting a permanent smile courtesy of MGT racing
Lubo69GTR's Avatar
Cars owned: R32 GTR, Mercedes 220cdi
Mís induction kit on mine with Mís K&N filters. They were on the car when I bought it and they seem good to me although the filters could do with replacing
Lubo69GTR is offline   Reply With Quote
