GT-R Register - Nissan Skyline and GT-R Drivers Club forum - View Single Post - My R32 GTR pics
Thread: My R32 GTR pics
Old 14th October 2014, 06:51 PM   #508 (permalink)
speedingpanther
speedingpanther is Playing with R34 RB install
speedingpanther's Avatar
Cars owned: MNP R33 GTR, White Spec2 Stagea
My R32 GTR pics
Originally Posted by mambastu View Post
Good to see you continuing with budget solutions. The GReddy replica plenums are a good thing if you're prepared to spend some time on them. With mine I found that the quality of the casting is as good as the proper GReddy RB25 manifold I've used in the past but the machining isn't great and they do need a bit of work to seal.
I found that all the flanges needed to be flatted. The worst face was between the plenum halves. On mine I struggled to get a local machine shop to take it on for a reasonable price due to the curved shape of the plenum outer so I bought a cheap glass table locally off Gumtree. Threw away the metal frame and G-clamped it to a flat wooden bench. Stuck a wide, cut up, sanding belt to it and spent a few hours re-facing the two halves.
The o-ring groove around the perimeter wasn't the same width or depth all the way around so I corrected that a bit and then used a 3.5mm seal made with a universal O-ring kit. Then made up a pressure test rig and blew 35psi through it and found that the three metal pipes that stick out of the plenum also leaked a little so they were sealed on the inside and outside.
The runners needed to be port matched at the throttle body face to correct the alignment but then my GReddy RB25 plenum also needed that when I used it.
I then spent a fair bit of time porting it and ended up with this:
Attachment 58025
Also checked the volume of the standard plenum against the GReddy replica and found the following:
Standard plenum 3750cc
GReddy replica 5750cc
GReddy replica ported 6750cc
Hope that helps
Stu
I love this type of helpful and informative post. Well above the "I wouldn't buy that as its a copy" type crap. Make it work, get some enjoyment out of what you have achieved and share it for the real enthusiasts instead of bragging about all the brands your car is now advertising.
I'm not saying this can always be the case, or that it's always cost affective... But I am saying enthusiasm and some effort really can ream results
speedingpanther is offline   Reply With Quote
