Audi coils on RB26 - Page 2 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree18Likes
Old 17th March 2016, 02:38 PM   #21 (permalink)
Hic
Hic is unaware they can edit their status
I don't agree. I use audi coils on every each project in last 10 years.
NEVER had a failure.
First, DON'T buy audi.
Buy NGK.
Second. Dwell time is what kills them.
If u can't have dwell time controlled at 1.8ms to 2ms, u will kill these in a long run.
4 coils light up methanol powered 2.0 4cyl engine with ease. 1100hp.
Hic is offline   Reply With Quote
Old 17th March 2016, 04:19 PM   #22 (permalink)
Gaz. is going to live in his R32 GTR
Gaz.'s Avatar
Cars owned: 1994 R32 GTR
Buy NGK.
I've got NGKs fortunately, I always trust them for plugs so figured I could for the coils. Does the standard ECU go above 2ms dwell time at all?
Gaz. is offline   Reply With Quote
Old 17th March 2016, 04:50 PM   #23 (permalink)
Hic
That is what I don't know
Old 17th March 2016, 04:53 PM   #24 (permalink)
Gaz.'s Avatar
Yeah I can't really find anything elsewhere either. Seems to be a good few people running them on other standard Nissan ECUs (RB20/25, CA, SR, KA)
Old 17th March 2016, 04:56 PM   #25 (permalink)
Hic
At least u can buy it for a nickel in any shop. Not like oem nissan.
Old 18th March 2016, 09:03 PM   #26 (permalink)
D-Ranged is building a twin turbo LS3 RX7!
D-Ranged's Avatar
Cars owned: R33 GTR
I think i am going to go down a slightly different route and try the LS2 truck coils which have the heatsinks built in. A few guys over at SAU have been using these with great success and the are also cheap.
D-Ranged is offline   Reply With Quote
Old 28th March 2016, 01:24 PM   #27 (permalink)
UKPAISLEY is unaware they can edit their status
UKPAISLEY's Avatar
Cars owned: GRANADA COSWORTH
Standard dwell is 1.7ms , I am looking to upgrade my coils as I have had an issue in the past. I have cleaned and insulated them now and they are 100% better. I run a 0.6 gap and its fine but I think I can improve this with new coils. I have a link G4+ and intend to use LS or R8 coils.
DP
Old 7th April 2016, 02:55 PM   #28 (permalink)
cooljustin is Oppan Gangnam Style Skyliner
cooljustin's Avatar
If you want to upgrade spark coil pack, why don't you go for Okada Projects? Now that's a proper upgrade IMO. BTW, has anyone switched from Stock to Okada ones? If so, what's it like?
cooljustin is offline   Reply With Quote
Old 7th April 2016, 03:16 PM   #29 (permalink)
UKPAISLEY's Avatar
I am going for AEM Smart coils.
DP
Old 7th April 2016, 03:22 PM   #30 (permalink)
GTSr32 is Hunting for brakes
GTSr32's Avatar
going to jump onto this also....
Would like to upgrade the coils but has anyone a wiring Diagram for removing the coil amp and rewiring in the R8 coils? OEM nissan are 3 pin and R8 are 4 pin
They also sit up miles compared to the OEM nissan units, so there might be a better OEM unit from a different car that would work better and keep the OEM coil cover.
Okada Projects Coil like most aftermarket units unless very high end nearly always use an off the shelf part put a sticker on it and increase the margin for 400% now this is only my view BUT when you look at the below images it suggests it might have some truths ?
They look very like Split Fire coils?
Also they seam to do coils for the vw range also , they look very much like the NGK items above with a flashy badge
GTSr32 is offline   Reply With Quote
Old 7th April 2016, 03:43 PM   #31 (permalink)
teetee is unaware they can edit their status
teetee's Avatar
I have vag fsi coils(bosch), these are right lenght so I can put coilpack cover back. Never had any problems with these.
teetee is offline   Reply With Quote
Old 7th April 2016, 04:03 PM   #32 (permalink)
GTSr32's Avatar
O are they are same style as the r8 ?
VAG numbers i found are:
0 221 604 115
0 221 604 113 Superseded by above
0 221 604 109 Superseded by above
They all seam to be the same NGK IGNITION COIL 48041
Anyone have a simple wiring diagram for this conversion?
Old 7th April 2016, 04:18 PM   #33 (permalink)
teetee's Avatar
0 221 604 115
i don't know, i have coil set with bolt-on wiring loom. z-power in Finland sell these kits.
Old 7th April 2016, 04:41 PM   #34 (permalink)
Hic
+, -, sig, -
rocknrolla33 likes this.
Old 7th April 2016, 04:53 PM   #35 (permalink)
UKPAISLEY's Avatar
If I can mount directly on the spark plug with the AEM coils I will try, If this fails I will use HT leads. I like the AEM coils as they have good reviews and dont suffer from the "Copy" issue LS2 and LS9 . The testing and set-up is good as the manufacturer gives the optimum dwell etc. The down side they are a big coil. Cost is ok at £70 ish each.
DP
Old 7th April 2016, 07:47 PM   #36 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Don't know why people are still wasting time with Audi or LS coils. Think a bit carefully and you could have a setup which is much better and not overhang the the plug recess and can still use your plug cover.
Old 7th April 2016, 10:22 PM   #37 (permalink)
GTSr32's Avatar
This is what i plan on doing... Ferrari 360 coils are pretty good and i can get them without the long extension and use the OEM nissan boot but need to figure the wiring...
FRRACER likes this.
Old 7th April 2016, 10:38 PM   #38 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
My solution:
Old 7th April 2016, 10:46 PM   #39 (permalink)
GTSr32's Avatar
Very interesting!
Old 7th April 2016, 10:46 PM   #40 (permalink)
Hic
Maybe because those are cheap and work great? Just maybe...
