Audi coils on RB26 - Page 4 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree18Likes
Old 31st July 2016, 09:55 AM   #61 (permalink)
Saifskyline is unaware they can edit their status
Saifskyline's Avatar
Cars owned: R33 GTR V-Spec
R35 GTR coils on the older Skylines with an RB26, with a replacement coil loom to run them so plug and play job! They are OEM Nissan so no issues with cheap Chinese fakes!
Saifskyline is offline   Reply With Quote
Old 18th September 2016, 06:32 PM   #62 (permalink)
etang789 is unaware they can edit their status
found another variation of the VAG Coils done by Ignition Projects , its basically Porsche Cayenne Turbo coils . Don't know how these Cayenne Turbo Coils vs R8 Coils vs LS2 Coils in firing power. It would be nice if someone can do some extensive testing on these. Seems like the biggest advantage using the LS2 Coils is sits much lower than the VAG Coils.
More info on the Cayenne Turbo Coil over plug setup here, A Spark Of Efficiency For Project GT-R - Speedhunters
Saifskyline likes this.
etang789 is offline   Reply With Quote
Old 18th September 2016, 07:22 PM   #63 (permalink)
teetee is unaware they can edit their status
teetee's Avatar
Why you need lower coils? I have vag coils and plug cover sits nice to its place.
teetee is offline   Reply With Quote
Old 19th September 2016, 01:48 PM   #64 (permalink)
HCR32Chris is unaware they can edit their status
Hey guys digging this back up.. AGIAN ( im GTSr32 reincarnated forgot my old email address)
Can we confirm the standard Dwell Time for the Rb coils? (phase 1)
R8 coils 06E905115E or NGK 48041 suggest to like around 2.5-3.0MS and can go up to 3.5MS but 3.5 can cause problems
Supertec likes this.
HCR32Chris is offline   Reply With Quote
Old 19th September 2016, 02:15 PM   #65 (permalink)
Supertec is unaware they can edit their status
Registered User
Oem and splitfires are between 1.8-2.2 ms @14v.
So when people start coming up with new coils from every car known to man then one must make sure the dwell times are adjusted for the new coil setup.
Supertec is offline   Reply With Quote
Old 19th September 2016, 03:36 PM   #66 (permalink)
Find that the Non R8 coil or the TSFI coil looks closer to the OEM Dwell time!
0221604115 "long" TFSI
charge time (Dwell) -> 1,8ms @ 14V (15 Ampere)
energy (1000V zener load) 55mJ
pinout 1: +12V (switched)
2: ECU ground
3: signal (TTL)
4: engine ground
add 0,2-0,3ms charge time for wiring resistance (0,1 Ohm)
Old 19th September 2016, 03:43 PM   #67 (permalink)
Also
Can someone tell me what Voltage and Amps run to the coils?
Old 12th October 2016, 12:30 PM   #68 (permalink)
aMpir3 is unaware they can edit their status
Cars owned: R32 GTR, E39 540i
Hi everyone.
I'm running the NGK 48051 since April.
I was sick of misfires out of the blue with the Splitfires i ran before.
Got a new Coil Harness, tried a different ignitor, plugs, added grounds, lowered the coil mounts 2mm to make up for the 3mm shorter plugs, NGK Iridium BKR8EIX, compared to Japanese Spec Plugs.
Nothing helped.
So i made my own wiring harness to fit the NGK Coils.
Running power straight from the battery over a relay, triggered by the power source of the stock coils.
Used 4mm^2 to the relay, 2.5mm^2 from the relay to the coils. 2.5mm^2 for ground as well and 1.5mm^2 for signal.
It sure takes some work but it was mad worth it. The engine runs a lot smoother and i haven't experienced a misfire since, not even exceeding 2 Bar going into boost.
I did have to adjust Timing a little as i had a little higher knock Level around 6500rpm, may have been an issue due to quicker/stronger spark?
I honestly am really pleased with this ignitoin setup and even if a coil burns out, who cares!
A new one is less than 30***8364; shipped to my door. Probably the best ~250***8364; i've spend on that car so far.
Setup:
Built rb26, PowerFC, Borg Warner S366 Single Turbo, 666hp/850Nm @ 1.7bar.
EDIT:
FYI, from what i know, the only VAG Coils that are actually lasting are supposedly the NGK 48051, the short versions as well as other manufactors than NGK are known to go quickly.
HCR32Chris likes this.
aMpir3 is offline   Reply With Quote
Old 5th November 2016, 08:46 PM   #69 (permalink)
brillo is unaware they can edit their status
NGK part number & pugs/sockets
I am interested in doing this conversion, but having looked up the NGK part number you have quoted NGK 48051 it appears to be a rail with 4 coil packs mounted on it.
Did you mean NGK 48015 which is a single plug mount coil pack, also where did you source the connectors that fit onto the coil packs i don't know if you would call them plugs or sockets.
any info or clarification would be appreciated
brillo is offline   Reply With Quote
Old 22nd November 2016, 09:55 PM   #70 (permalink)
Jimbostir's Avatar
Cars owned: Datsun
Try again mate. I just searched and it came up with a pencil coil.
Old 22nd November 2016, 09:57 PM   #71 (permalink)
Jimbostir's Avatar
Cars owned: Datsun
Ok so a quick question about working out the required dwell. Would you have to factor in for any delay the old ignition amp also?
Old 8th January 2017, 05:22 AM   #72 (permalink)
meathead is unaware they can edit their status
meathead's Avatar
Cars owned: R33 gtr v-spec
Bit of a con those IP/Okada kits, lots of colourful words and pseudoscience spin. they compare there Porsche Cayenne coil to an "oem" one whereby they overcharge (overflux) to 13 odd amps whereas the other one plateaus at 7 odd amps (inbuilt current limiter) you can see the dogleg (saturation point) on the IP plot occurs when the other one goes horizontal. Ignition Projects
The speed hunter guy must have got them free
Stay OEM !!! save your money
MEATHEAD
meathead is offline   Reply With Quote
Old 8th January 2017, 08:16 AM   #73 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Absolutely my thought on them also. They take stock coils as indicated by their R35 versions. Pics below show stock and an Okada coils. See markings and their red embossed logo/cap what ever you want to call it.
Not the first person to say speedhunter gets all his parts free. I heard he does get everything free to then review and give them coverage in their magazine. So parts mentioned and reviewed you got to be careful and do your own research so not to fall for their bias.
meathead likes this.
Old 8th January 2017, 05:01 PM   #74 (permalink)
gaz_86 is RB30 7175
Soo what sort of power or boost levels are people maxxing out on the standard/upgraded rb26 coil packs?, or is this more of a reliability mod?
gaz_86 is offline   Reply With Quote
Old 11th January 2017, 08:02 AM   #75 (permalink)
gzilla_ is gzilla_
I currently have these. Recommended by a friend but from what I hear, you can't run the center plate when you have the R8 coils installed? So I might send them back at this point. I was planning on running the center plate.
gzilla_ is offline   Reply With Quote
Old 11th January 2017, 08:16 AM   #76 (permalink)
teetee's Avatar
No problem with fsi coils: Z-Power
Old 11th January 2017, 08:56 AM   #77 (permalink)
Registered User
Never seen them with a centre plate they appear push on.
You could always go for the R35 setup.
