Audi coils on RB26 - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree18Likes
Old 7th January 2015, 09:50 PM   #1 (permalink)
Ok`n is unaware they can edit their status
Ok`n's Avatar
Audi coils on RB26
I have seen som guys run on audi coils on their straight six engines, mostly rb26.
Im woundering if anyone have experience with this setup and what coilpack to choose since there are so many vag coils to choose from.
And is there anything i should be awere of when setting up the system?
Ok`n
R32 GTR Nismo
Ok`n is offline   Reply With Quote
Old 8th January 2015, 01:18 AM   #2 (permalink)
Gojira-R32 is Drifting mode
Gojira-R32's Avatar
i run pencil coils with a AEM CDI.
Audi coils are also OEM, why should they be better then OEM nissan ones ?
Gojira-R32 is offline   Reply With Quote
Old 21st January 2015, 09:42 PM   #3 (permalink)
D-Ranged is building a twin turbo LS3 RX7!
D-Ranged's Avatar
Cars owned: R33 GTR
Because Nissans design is over 20years old.
D-Ranged is offline   Reply With Quote
Old 21st January 2015, 10:02 PM   #4 (permalink)
Gojira-R32's Avatar
has nothing to do with design.
Nissan OEM coils are very good, it's the age that doesn't any good.
if you buy a new set of OEM's, they are better then most aftermarket ones.
And if you whant aftermarket ones for better spark.
Worlds nr1 coil is WeaponX
2nd best are Denso's.
Proven dyno's and research on the coil sparking etc... there's somewhere a website about them compare coils together of all kind of brands, testing with all kinds of methodes and equipment.
that's why i run now Denso Pencil coils that kan handle 14K Rpm, 3x better spark etc...
WeaponX importing from usa is a little expensive for the little better spark
Old 21st January 2015, 11:14 PM   #5 (permalink)
Jayman is Owner of R34 GTR 720 hp
i disagree with you on this front, as this question was asked on one of the facebook pages and was covered in depth by the sweedish guys, if i remember correctly the VAG coils made a strong difference as they have to endure much higher spark loads due to the TFSI engine or the R8 engine, that and the design has changed within the coils. i will see if i can find it, but there was an advantage in going down this route. i shall either be going down the VAG route or the Okada plasma coil option.
hope this helps the answer to your question.
James
omnigear likes this.
Jayman is offline   Reply With Quote
Old 22nd January 2015, 07:16 PM   #6 (permalink)
Umar is saying Nissans til the End
Umar's Avatar
Cars owned: BREAKING R32 GTR, view my thread Please
very interested to know what you come up with James.
Subscribed this thread
NissanFreak!!
Umar is offline   Reply With Quote
Old 22nd January 2015, 08:11 PM   #7 (permalink)
BenR is unaware they can edit their status
What setup will you be trying new coils with?
I would personally go with an oem solution that's easy and relatively cheap to obtain if you get into a pinch.
Be a PITA if you had a coil go down and had to order some bespoke expensive items.
I'd like to get rid of my amplifier if possible without spending a fortune on something like an IP coil kit.
BenR is offline   Reply With Quote
Old 22nd January 2015, 11:06 PM   #8 (permalink)
D-Ranged's Avatar
Cars owned: R33 GTR
Never heard of weapon x.
And the Nissan ones new are only better than any other replica coil because their, errr, new.
Old 25th January 2015, 09:53 PM   #9 (permalink)
Ok`n's Avatar
Yes as jayman says ive seen the vag coilpacks mostly on sweedish cars. Talked to local tuner friend of mine and his opinion are that oem and splifire coil pack are just the same. He did not say any details other than he checkd them in physical and output are similar to oem.
My research if you are going to use a vag oem coilsetup and in the prosess remove the amplifier, in wont cost you more than 100 to 200pounds.
Anyway i just got a oem coilpack and will stick with them to my 700hp setup until i can prove them wrong.
R32 GTR Nismo
Old 25th January 2015, 11:23 PM   #10 (permalink)
Is it as simple as removing the amp?
I've not done much research to see if it's simple enough to swap from s1 to s2 type coils, and if it's merely a simple wiring change.
Old 8th February 2015, 06:37 PM   #11 (permalink)
Taiquri is JPN-Racing
Taiquri's Avatar
Cars owned: R33 GTR V-Spec -96 Midnight Purple, R32 GTR -90 (EX), R33 GTSt -93 (EX)
Very common update in finland, you can get plug&play kit in 399eur and works good over 1000hp
bosch part number is 0986221023
R33 GT-R Vspec 1996
Taiquri is offline   Reply With Quote
Old 11th February 2015, 10:30 AM   #12 (permalink)
markM3 is GTRless!
so the coils are a direct fit with Nissan ignition amp, or do you need a new ignition loom?
markM3 is offline   Reply With Quote
Old 11th February 2015, 10:35 AM   #13 (permalink)
Taiquri's Avatar
They have built in transistors so you dont need amplifier. Coils fit bolt on to head but you need to do new wiring. Not such a big job.
Old 9th June 2015, 08:49 AM   #14 (permalink)
jinkhai is unaware they can edit their status
Sorry for being off topic..
Does anyone install r35 coils on their car? I have the Gtr magazine and some of the tuners in Japan been doing it.
jinkhai is offline   Reply With Quote
Old 9th June 2015, 09:20 PM   #15 (permalink)
Natbrat300 is wondering if any other car can live up to theR32GTR! The answer is no :-(
Natbrat300's Avatar
Cars owned: R32 GTR & Qashqai+2.
Any good mechanic will tell you that the most common cause of VAG engine breakdown is coil failure. These are the last coils that I would advise anyone to fit to their engine, the only advantage is that they are relatively cheap, which is probably why some people opt for them!
Marine coils / MSD coils are best suited to high boost turbocharged engines, as these give a high voltage spark like plasma coils, but over a longer duration.
Nathaniel
GTROC SOUTH EAST REGIONAL REP
Natbrat300 is offline   Reply With Quote
Old 9th June 2015, 09:25 PM   #16 (permalink)
keithmac is a lurking GTO-TT owner..
I remember not long back VAG had a major issure with coil failure and a shortage of replacements!, people were waiting weeks for replacements under warranty.
Wouldn't be my 1st choice either..
cooljustin and r33-sky like this.
keithmac is offline   Reply With Quote
Old 9th June 2015, 10:22 PM   #17 (permalink)
Kurumajin is uwanare they can edit their statue
Don't experiment with unfamiliar setups unless you have to, stick with OEM or reputable aftermarket brands that have extensive R&D behind their product. Always has been my rule of thumb for any car I've had, and has always proven correct.
FRRACER and zimmersquirt like this.
Kurumajin is offline   Reply With Quote
Old 25th June 2015, 02:36 PM   #18 (permalink)
Hic
Hic is unaware they can edit their status
NGK makes same coils as VAG. Much better quality, same price. And cheap as hell. Better than old nissan design in any case. Worth of hassle!
Hic is offline   Reply With Quote
Old 17th March 2016, 02:47 PM   #19 (permalink)
Gaz. is going to live in his R32 GTR
Gaz.'s Avatar
Cars owned: 1994 R32 GTR
I've just done this conversion to my 32GTR, but only have a standard ECU. Seems to run fine but I'm a little concerned about dwell times etc, can those of you using these Audi coils shed any light? Everything i've read seems to suggest they're fine but it pays to check!
Gaz. is offline   Reply With Quote
Old 17th March 2016, 03:30 PM   #20 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Agreed!
meathead likes this.
