R32 RB26 head identification - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Like Tree1Likes
  • 1 Post By Asim R32GTR
Old 1st February 2015, 12:09 PM   #1 (permalink)
Kpt. Trumm is unaware they can edit their status
Kpt. Trumm's Avatar
Cars owned: Datsun 240Z soon to be RB26
Hello
I need HELP. I'm building an engine piece by piece for my 240Z. I bought a second hand head that some idiot has taken apart. As I have come to understand how much of the idiot the seller was, i now doubt that all the parts are RB26 ones. So here are my problems:
1) All the cam caps are unmarked (I always mark everything when I take something apart) I thought that maybe Nissan was so smart that alla the caps are identical. But no. First try and the cam is stuck.
2) And here comes the second problem. Are those caps even RB26 ones. I see on the pictures that all the other RB26 caps have markings on top of them. And my first caps won't line up with the bottom part. Here is the pic.
Can anyone help me out in here?
Kpt. Trumm is offline   Reply With Quote
Old 3rd February 2015, 10:45 AM   #2 (permalink)
Chris32R is unaware they can edit their status
Chris32R's Avatar
R32 GTR cam caps don't have markings on them. Nissan began engraving markings on the cam caps on the R33 GTR series.
Also, the cam cap bolts on the R32 RB26 models tend to wedge themselves into the bore of the cam cap hole. Try use some WD40 to lubricate the hole so that it can turn easier in the cap. R33 GTR and later models don't have this problem
Chris32R is offline   Reply With Quote
Old 3rd February 2015, 10:47 AM   #3 (permalink)
Chris32R's Avatar
It is important that you do mark the cam caps, I1, E1, I2, E2, etc... they are machined to the head so it is important that they go back in the same spot, as well as the same direction as they came off previously
Old 3rd February 2015, 02:14 PM   #4 (permalink)
Kpt. Trumm's Avatar
Thanks for the info. I managed to measure everything for 6 hours to get every thing sorted out. Previous owner didn't mark the caps and shuffled with them like a deck of cards. I have now 0,1mm oil clearance all the way around for every cap. It took some time but I'm sure now that all is good and there shouldn't be problem with that anymore.
Old 3rd February 2015, 03:44 PM   #5 (permalink)
Asim R32GTR is Looking for a hakosuka GT / GTX
Asim R32GTR's Avatar
Cars owned: R32GTR LHD
I have worked on several R32GTR engines, and all of them had marking on the camshaft caps...
IMGOD32 likes this.
Old 3rd February 2015, 05:08 PM   #6 (permalink)
Kpt. Trumm's Avatar
Now that's interesting. So who is lying
Old 3rd February 2015, 05:47 PM   #7 (permalink)
I dont think anyone is lying. There can be truth to both alternatives.
Old 3rd February 2015, 10:10 PM   #8 (permalink)
Chris32R's Avatar
R33 GTR motors in them maybe? Or the later model R32 GTRs with the longer crank nose could have got the same caps as the R33 GTR.
I've worked on two 89 GTRs with no markings and the bolts were wedged in the cap hole.
The R33 GTR caps i worked on had markings and the bolts were very easy to remove from the cap in comparison.
I've also had this confirmed to me by another person.
Old 4th February 2015, 06:22 AM   #9 (permalink)
Kpt. Trumm's Avatar
That makes sence. Short nose crank is in early r32 models. Then last R32 models (92 and up) got R33 engines. I thought they fixed only the oil pump problems. Live and learn every day.
Old 4th February 2015, 07:09 AM   #10 (permalink)
FRRACER's Avatar
Cars owned: R32.4.5
Both my engines one a narrow crank r32 engine and a long nose crank r33 engine had markings on the cam caps.
Old 7th February 2015, 10:36 PM   #11 (permalink)
R33JONO is is aware he can edit his status but cant think of anything to put.
The late, long nose 32 engine I put in my car had the caps marked.
Although the 33 engine that came out had the cam cap bolts stuck in the holes!!
Go figure lol.
R33JONO is offline   Reply With Quote
Old 15th February 2015, 09:52 AM   #12 (permalink)
Corsa1 is unaware they can edit their status
Corsa1's Avatar
Some didn't some did I would think that it's one of the first 32 heads.
Corsa1 is offline   Reply With Quote
Old 15th February 2015, 07:12 PM   #13 (permalink)
Kpt. Trumm's Avatar
Retro RB26 Is there any difference between first gen and last gen R32 (or R33) engines. I mean design wise. I know the long nose crank. But is that it?
I'm gona use just the bare minimum from the engine. Short block with custom mods. Just interested from that point of view. Did they used better materials, better casting, different head flow or different squish area design. That sort of thing. Aim is 600hp (should be good for 1000kg car)
Old 15th February 2015, 11:34 PM   #14 (permalink)
Corsa1's Avatar
They all flow the same mate.
Old 26th May 2015, 01:02 PM   #15 (permalink)
AaronR33 is unaware they can edit their status
How about block, is it easy to ID?
AaronR33 is offline   Reply With Quote
