1991 BNR32 Rust Free Clean Example - GT-R Register - Nissan Skyline and GT-R Drivers Club forum
Go Back   GT-R Register - Nissan Skyline and GT-R Drivers Club forum > For Sale & Wanted > Private: For Sale - CARS ONLY > R32 - All models
Like Tree1Likes
Old 31st March 2015, 07:07 PM   #1 (permalink)
Raj32 is Still lusting over his R34 GTR
Cars owned: R32 GTR, R34 GTR
Wink 1991 BNR32 Rust Free Clean Example
Nissan Skyline R32 GTR (BNR32)
November 1991
2.6 litre, twin turbo
5 speed, manual
340HP, 267ft/lb at the fly
302HP, 246ft/lb at the wheels
Imported August 2013
MOT till 26/07/2015 - no advisories.
First owner in UK
ENGINE COMPRESSION
(done March 2015)
Dry (PSI):
1: 159
2: 158
3: 158
4: 159
5: 157
6: 163
Wet (2 drops of oil):
1: 162
2: 159
3: 167
4: 161
5: 163
6: 163
When imported, it was:
- fully undersealed
- 4 wheel laser aligned
- timing belt change
- Serviced: oil, oil filter, spark plugs
Since owning the car I have:
- Rewired one of the AFM
- Replaced coilpacks (for OEM ones)
- Cleaned out the AAC valve (idles nicely at 1000rpm)
- Wired in a 4WD/RWD switch
- Fitted auto side mirror fold module
SERVICE HISTORY
Current mileage: 105000
- 89600 (when imported - service items as above)
- 95600 (service by garage(SVA) - oil, oil filter)
- 102000 (serviced myself - Nissan oil filter, Fuchs racing titan pro oil, greddy magnetic sump plug)
MODIFICATIONS
Powertrain:
- Apexi powerflow air filters
- Baffled twin turbo pipe
- Greddy(Trust) down pipe (have original downpipe)
- 5zigen exhaust
- Decat (have original catalytic converter)
- Nismo clutch slave cylinder
- Deatschwerks 200 fuel pump
- Z32 Fuel filter
HANDLING
- Nismo coilovers
- Nismo front strut brace
VISUAL
- Nismo front bonnet lip
- Nismo rear spoiler lip
- Nismo rear spats
INTERIOR
- Nismo drivers seat (rarer one of the 2 available for this car)
- Nismo gear knob
- Nismo boost gauge
- Momo steering wheel
AUDIO
- Vibe 6.5" rear component speakers (have original speakers)
- Pioneer MP3 headunit (have original headunit)
KNOWN PROBLEMS
- Rear window rubber corners lifting slightly but does not leak - just doesn't look great
- Handbrake lights on - front pads need replacing
- Slight shake from the rear of the car - not sure what this is but has been there since import and has not worsened over the 2 years
- Small bubble on the dash - like almost all R32's. Size wise it is roughly the size of a hand but 3 fingers in width
PICTURES
Main image:
Rear:
Side:
Under:
Rear left under:
Rear right under:
Front right under:
Front left under:
Dyno result:
Dash:
Priced at £8500.
I am located in the midlands - Loughborough.
If you have any questions or want any specific photos, please let me know and I can email.
More interior photos are coming!
Raj32 is offline   Reply With Quote
Old 31st March 2015, 08:50 PM   #2 (permalink)
deek1182 is unaware they can edit their status
Hi mate just wondering if mileage noted in miles or km? Also who imported it?
deek1182 is offline   Reply With Quote
Old 31st March 2015, 08:55 PM   #3 (permalink)
Hi mate,
Mileage is in miles - but the engine compression and HP suggests otherwise!
Bottom tolerance of engine compression is shown to be 128psi in the manual.
Importers are SVA Imports.
Old 1st April 2015, 05:04 PM   #4 (permalink)
JTJUDGE is 70% there
JTJUDGE's Avatar
Cars owned: R33 GTR X2, next is the r32 (stockish)
when you say a "slight" shake from the rear, is this a constant feeling ? can you get it up on a ramp with some pics of the underside rear ?
JTJUDGE is offline   Reply With Quote
Old 1st April 2015, 05:07 PM   #5 (permalink)
Yeah more noticable at lower speeds but almost disappears at higher speeds.
I will get it jacked up on Friday to take loads of photos. Im going to drain the old fluid in the rear diff and put some fresh oil in to see if its diff related.
Old 1st April 2015, 05:11 PM   #6 (permalink)
JTJUDGE's Avatar
Has hicas been locked out and I take it the rear diff is std ?
Pics aren't loading up but I'm on tapatalk which sucks
Old 1st April 2015, 05:14 PM   #7 (permalink)
No it's all completely standard. I have a brand new hicas lockout kit but haven't fitted - didn't want to veer away from stock condition too far..
Old 1st April 2015, 05:21 PM   #8 (permalink)
JTJUDGE's Avatar
update us when you change the diff oil then. Pics are working for me now and it looks clean for a 60k car never mind a 105k car. That mileage is 100% in miles and not sva converting from km to ml then not adjusting the mileage correctly ?
Old 1st April 2015, 05:24 PM   #9 (permalink)
Will do JT. Thank you for the complement.
I have no way to prove what SVA did but this is their standard procedure when they import cars to avoid any confusion. In any case I pictures and videos to show the compression readings and this is the main thing that determines health in my opinion
Old 1st April 2015, 08:32 PM   #10 (permalink)
Just like to add, I have also had the injectors ultrasonically cleaned (with video), and flow tested (with report).
I also have fitted a brand new battery with 5 year warranty.
Old 1st April 2015, 08:42 PM   #11 (permalink)
Site Admin.
Mookistar's Avatar
Silly question. How come you've had all these tests and reports done on the engine (way more than most people) but have never investigated the wobble from the year or changed the diff fluid in the 2 years? Not picking, just curious.
Autoguide.com
Old 1st April 2015, 08:46 PM   #12 (permalink)
It's okay, it's a good question.
I concentrated on working my way through the ignition system to make sure it was super solid. Harder to recover a blown up engine than a shagged differential or propshaft or whatever it may be.
Oh and yeah I never changed the diff fluid!
But genuinely?... The shake really never bothered me! My commute to work is 95% motorway in which you can't tell!
Last edited by Raj32; 1st April 2015 at 08:52 PM.. Reason: Diff fluid change reference
Old 2nd April 2015, 07:08 PM   #13 (permalink)
Euroexports is BUYING ALL SKYLINES
GTR Register Trader
Euroexports's Avatar
Are you kidding ? How can you say the shake is not noticable? Low speeds vibrates like mad and is still very noticeable at higher speed .
Say someone travels 300 miles to view the car do you not think they will be pissed if not as your describing
Euroexports is offline   Reply With Quote
Old 2nd April 2015, 07:36 PM   #14 (permalink)
Just to reference the above message - I said it is barely noticeable at high speeds in which I did most of for my commute to work.
Agreed it does shake at lower speed, but it does not bother me.
Please stop crapping on my thread - I know you are pissed because you lost half your deposit which we agreed was non-refundable before you paid.
And this "massive gash" you referenced previously - customers please judge yourself (note, I have used a £1000 camera to take the photos just to show I am not trying to hide anything):
I am not here to mask anything up, and I am not saying the car is perfect. If it was I would be asking for a lot more money. Fresh imports cost up to and in some cases above £10,000.
I am only asking for £8500 for a very clean, very strong overall car (apart from this vibration issue).
Thanks for looking.
Old 3rd April 2015, 01:55 PM   #15 (permalink)
amgcosworth is unaware they can edit their status
Swap
Interested in a swap for my 1994 supra tt automatic with a big t67 single turbo conversion, car use to be a supra twin turbo. Running 460 BHP at 0.72 bar.. A set of 750cc bigger injectors and a uprated ecu will see 650 bhp. Its got a gt300 kit on so the cars huge. Cars only done 42k miles has hks adjustable coilovers and lsd rear diff. Leather interior. A very rare example in this guise cars advertised for £12,000 my numbers 07557979926
amgcosworth is offline   Reply With Quote
Old 3rd April 2015, 03:15 PM   #16 (permalink)
Turbodailydan is unaware they can edit their status
Nice looking 32 at a reasonable price. good to see an advert with this much detail also
Turbodailydan is offline   Reply With Quote
Old 3rd April 2015, 04:25 PM   #17 (permalink)
Hi mate,
Supra is definitely on the list of cars I want to own and yours sounds awesome but not just yet! I've already put down a deposit on another car. Thanks for the offer though! Good luck with your sale.
Old 3rd April 2015, 04:31 PM   #18 (permalink)
Hi mate. When uve got the car jacked up could u take some pics of the jacking points on sills (front & rear please) cheers.
Old 4th April 2015, 11:35 AM   #19 (permalink)
No problem matey.
I'll do it all when I get the car up to change the diff oil - unfortunately the oil hasn't arrive yet despite paying extra for express! Easter holiday **** up me thinks..
Old 7th April 2015, 10:28 AM   #20 (permalink)
Antonius2389 is unaware they can edit their status
Hello. I'm very interested in this GTR. However I do have a couple of questions for you. Could I get your email? I have better access to messages through email.
Antonius2389 is offline   Reply With Quote
Tags
for sale, r32, r32 gtr, sale
